TC74 Temperature Sensor Driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
TimC
PostPosted: Wed Oct 09, 2024 8:34 pm     Reply with quote
Hi All,
Here is a driver for the Microchip TC74 Temperature Sensor.
I am posting this because it adds a power saving standby mode.
Also results in C or F, below freezing, and a Status request.
If you are having problems getting this driver to work:
First run a I2C scanner to see if the 0x9A address comes back.
Check the I2C speed, it should not be faster than 100K.
Don't mix a 5V TC74 with a 3.3V uP, SMBUS is more sensitive to voltage differences.
Sample Code Snip-it:
#use I2C(master, I2C1, SMBUS)
//#define TC74_ADDR   0x9A   // Default I2C slave address for TC74 (u5 or v5 markings)
#include <TC74_driver.c>
   signed int dataC, dataF;
      dataC = TC74_Temp();
      dataF = TC74_Temp(1);
      printf ("Temp: %d f    %d c\r\n", dataF,dataC);
Here is the TC74 Driver:
#ifndef _TC74_DRIVER_C_
#define _TC74_DRIVER_C_
// The TC74 is a SMBUS / I2C 8bit digital temperature sensor.
// Accuracy at best is + or - 2 deg C
// Conversion rate is a nominal 8 samples/sec
// 200uA operating.  5uA Standby.
// You need pull ups on SDA and SCL, 4.7K to 10K
// Written by TimC Oct 9 2024  version 1.0
// Make sure you have a line similar to this in your code
//#use I2C(master, I2C1, SMBUS)   // SMBUS has timeouts but works without
// SOT-23 Package Marking Codes show address u0-u7 or v0-v7
// TO-220 Package Marking Information show  TC74A0-TC74A7
// Default I2C slave address for TC74 is 0x9A. Marking Code u5,v5 or A5
#define TC74_STANDBY   0x80
#define TC74_OPERATE   0x00
#define TC74_CONFIG_REG   0x01
#define TC74_TEMP_REG   0x00
void TC74_Config(unsigned int control) {
// Control byte should equal 0 for normal, or 0x80 for lower current standby
// In standby the temperature will not change or will be 0 C  after restart
   if(control != TC74_STANDBY)
      control = TC74_OPERATE;   // only other valid value
   i2c_start();
   i2c_write(TC74_ADDR);
   i2c_write(TC74_CONFIG_REG);   // Config register = 1
   i2c_write(control);// 0=Power on state, 0x80=standby Temp with return 0 deg C
   i2c_stop();
int TC74_Status() {
// Returns the Control Byte - Control bit 7 should equal 0 for normal, or 1 for lower current standby
// if Bit 6 = 1 then data is ready  if Bit 6 = 0 then data is NOT ready
   int data;
   i2c_start();
   i2c_start();      // Restart to change Direction
   i2c_write(TC74_ADDR+1);   // Ask to read the Status
   data = i2c_read(0);   // after reading we NACK
   i2c_stop();
   return data;
signed int TC74_Temp(boolean format=0) {
// Gets the one byte signed value in C or format 1 for deg F
// works below freezing with neg values.
   i2c_start();
   i2c_write(TC74_TEMP_REG);   // Temperature register = 0x00
   i2c_write(TC74_ADDR+1);   // Ask to read the Temperature
   dataC = i2c_read(0);   // after reading we NACK
   i2c_stop();
   if(format == 0)      // If all we want is C then we are done
      return dataC;
   // Convert to Deg F
   dataF = (9 * (signed int16)dataC) / 5;
   dataF += 32;
   return dataF;
#endif   //_TC74_DRIVER_C_
allenhuffman
PostPosted: Tue Dec 17, 2024 8:19 am     Reply with quote
Thanks for sharing. I did a TC72 a few years ago, and I am guessing this might have made that task easier ;-)
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
