dspic33EP with external clock source
nazoa
PostPosted: Wed Sep 04, 2024 9:31 am     Reply with quote
We need to clock a dspic33pe from an external clock source and I am looking for suggestions on the fuse settings. We have a 20MHz external clock and we plan to connect this to the OSC1 pin. The question is how do I set the EC (external clock) mode but also use the internal PLL to give the 140MHz for the internal instruction clock. Will the following work?
#FUSES EC
#FUSES PR_PLL //??
gaugeguy
PostPosted: Wed Sep 04, 2024 9:51 am     Reply with quote
I don't have that part, but probably use the setup_oscillator function and let it set the fuses.
setup_oscillator(OSC_CLOCK, 20M, 140M);
PostPosted: Wed Sep 04, 2024 10:04 am     Reply with quote
You don't.
The key is that the PLL operation is not done in fuses. It has to be setup
by the code at the start of the boot. So the #use delay has to specify the
oscillator and required clock frequencies, and this then programs the PLL
#use delay(OSCILLATOR=20MHz, CLOCK=140MHz)
OSCILLATOR keyword says the clock is coming from an external oscillator.
