AlbertCharles
| ex_use_capture.c - capture of a semi-cycle Pulse Width |
Posted: Tue Aug 13, 2024 5:09 pm |
Hi Guys!
i'm using a ex_use_capture.c - PIC16F877A -Ccs PCM 5.115
Second: 4935.6
First: 4459.2
Second-First= Period: 476.4 us
Second: 7107.2
First: 6630.8
Second: 10231.4
First: 9755.0
I created fixed pulse train through scope's pulse generator, like this:
// sorry about figure...
_ _ _ _
| |_|
<-------> 476.4 us = perĂod
In the scope, i read the HIGH pulse at ~433us and LOW pulse at ~43us.
Boths add up ~476.4us. Its correct.
But the problem is that I need to know the exact value of each high and low pulse.
The variables that capture these values in the program receive variant values, as I published above. Why?
I appreciate and appreciate any help, as I've been at this for 15 days Thanks.
Below is the program:
#include <16F877A.h>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(crystal=20MHz)
#define GENERATE_PWM_SIGNAL
#define RS232_XMIT PIN_C6
#define RS232_RCV PIN_C7
#define CAPTURE_PIN PIN_C2
#define CAPTURE_TIMER 1
#define PWM_PIN PIN_C1
#define PWM_TIMER 2
#define __CCS_USE_TIMER_PERIPH 0
#use rs232(xmit=RS232_XMIT, rcv=RS232_RCV, baud=9600) //Text through the UART
#use capture(input=CAPTURE_PIN,timer=CAPTURE_TIMER, CAPTURE_FALLING)
#ifdef GENERATE_PWM_SIGNAL
#use pwm(output=PWM_PIN, timer=PWM_TIMER, frequency=2kHz, duty=50)
#define TICK_IS_16BITS
#include <tick.c>
#define GetTickDifference(a,b) (a-b)
#endif
#if getenv("INSTRUCTION_CLOCK") >= 1000000
#define PERIOD_DIVISOR (getenv("INSTRUCTION_CLOCK") / 1000000)
#else
#define PERIOD_DIVISOR 1
#endif
unsigned int16 FirstCapture, SecondCapture;
int1 NewCapture = FALSE;
#INT_CCP1
void Capture_Interrupt(void)
static int1 First = TRUE;
unsigned int16 dummy;
if(!NewCapture)
if(First)
FirstCapture = get_capture_time(); //Read first capture event.
SecondCapture = get_capture_time(); //Read second capture event.
NewCapture = TRUE;
First++;
dummy = get_capture_time();
#define GetCaptureDifference(a,b) (b-a)
//The following are values used to generate 6 different PWM signals for
//the Capture to measure. The periods are 500us, 333.3us, 250us, 125us,
//62.5us, 31.2us.
//obs: i'm not using
unsigned int32 PwmFrequency[6] = {2000, 3000, 4000, 8000, 16000, 32000};
#endif
TICK CurrentTick, PreviousTick;
#endif
unsigned int16 Time,Time1;
unsigned int8 i = 0;
printf("\n\rex_use_captur.c - %s\n\n\r", getenv("DEVICE"));
//enable the Capture interrupt
enable_interrupts(INT_CCP1);
PreviousTick = CurrentTick = TickGet();
#endif
while (TRUE)
// obs: i'm not using......
if(GetTickDifference(CurrentTick, PreviousTick) >= (5*TICKS_PER_SECOND)) //change PWM period every 5 seconds
if(++i >= 6)
i = 0;
pwm_set_frequency(PwmFrequency[i]);
pwm_set_duty_percent(500);
PreviousTick = CurrentTick;
#endif
if(NewCapture)
Time = GetCaptureDifference(FirstCapture, SecondCapture);
printf("Second: %8.1w us\n", ((unsigned int32)SecondCapture * 10) / PERIOD_DIVISOR);
printf("First: %8.1w us\n", ((unsigned int32)FirstCapture * 10) / PERIOD_DIVISOR);
printf("Period: %8.1w us", ((unsigned int32)Time * 10) / PERIOD_DIVISOR);
NewCapture = FALSE;
delay_ms(5000);
gaugeguy
Posted: Wed Aug 14, 2024 6:15 am |
Your code is currently capturing every rising edge of the signal. If you want to measure the time high or time low you will need to capture both the rising edge and the falling edge.
You can either switch the CCP mode in each interrupt or set one CCP for rising capture and the other CCP for falling capture. |
AlbertCharles
Posted: Wed Aug 14, 2024 7:35 am |
Okay, thanks for your areply. I added the following lines after the line 120
if (v==0)
setup_ccp1(CCP_CAPTURE_RE);
v=1;
setup_ccp1(CCP_CAPTURE_FE);
v=0;
and the result was only the period reading changed, starting now with the rising edge and now with the falling edge. But the main thing is to obtain only the value of the high time, separate from the low time. I don't need the period, but each separate semicycle. |
gaugeguy
Posted: Wed Aug 14, 2024 8:29 am |
A full cycle has three time readings, not just two.
Rising edge, falling edge, & rising edge
or falling edge, rising edge, & falling edge. |
AlbertCharles
Posted: Wed Aug 14, 2024 9:25 am |
| So, based on your answer, I say that I need to know the time (us) in which the high pulse was active, and then, the time (us) in which the low pulse was active. That's the real problem.Do you have any suggestions via code? |
gaugeguy
Posted: Wed Aug 14, 2024 9:37 am |
I am not giving you code, just some direction.
capture a rising edge, save as Rising1
capture a falling edge, save as Falling1
capture a rising edge, save as Rising2
time high = Falling1 - Rising1
time low = Rising2 - Falling1 |
Joined: 01 Jul 2010 Posts: 9600 Location: Greensville,Ontario
Posted: Wed Aug 14, 2024 12:19 pm |
| If CCS doesn't have an example, I KNOW there's a chapter devoted to 'how-to-do-it in the Microchip databook,though actual code will be in Assembler, converting to C is easy. |
AlbertCharles
Posted: Wed Aug 14, 2024 5:24 pm |
| In the future I can try to convert, but today, in ccs, I would recover my time, as I have been in this fight for 15 days. If u have something in C, it would help me a lot. |
Posted: Thu Aug 15, 2024 12:09 pm |
to add to gaugeguy's post..
if you reset( zero) the timer's 'count' register before the 1st rising edge detection.you'll see better numbers, providing you don't overflow( exceed the max count ) |
AlbertCharles
Posted: Thu Aug 15, 2024 12:55 pm |
| At lunch time I was meditating.. thinking about this hypothesis.. I will test it and report back here. Thanks |
