SSD1306
MCUprogrammer
SSD1306
PostPosted: Sat Apr 06, 2024 6:30 am     Reply with quote
Hello.
PIC18F26Q71
CCS 5.117
There are 2 logos. I want to print the logo I want. If I try to print one by one, there is no problem. But if I want to choose which logo to print in the function, the whole screen is filled with white pixels.
Where am I going wrong?
Let me share the relevant parts of the code.
rom uint8_t Logo1[64][16] = {................} // There's hex data inside.
rom uint8_t Logo2[96][12] = {................} // There's hex data inside.
Function prototype
void pDisplay(uint8_t startX, uint8_t startY, uint8_t width, uint8_t height,uint8_t *printLogo);
The function I sent.
  pDisplay(0, 0, 128,64,Logo1);
   uint8_t x, y;
   uint8_t displayX, displayY;
   uint8_t value, i;
   uint8_t screenWidth = 128;
   uint8_t screenHeight = 64;
   // Exit the function if the image exceeds the screen size
   if (startX + width > screenWidth || startY + height > screenHeight)
       return;
   displayY = startY;
   for(y=0;y<height;y++)
      displayX = startX;
      for(x=0;x<width;x++)
         if((x % 8) == 0)
            value = printLogo[(height - 1) - y][x/8];
            i = 7;
         oled_pixel(displayX, displayY, bit_test(value, i) == 0);
         displayX++;
         i--;
      displayY++;
Best Regards...
MCUprogrammer
_______________________________
Work Hard
PostPosted: Sat Apr 06, 2024 6:45 am     Reply with quote
what you give isn't a program to chose which of the 'logos' to print.
assuming that each 'logo' does display properly, it's not the 'display' function problem.
MCUprogrammer
PostPosted: Sat Apr 06, 2024 6:51 am     Reply with quote
I don't understand what you mean.
Best Regards...
MCUprogrammer
Work Hard
gaugeguy
PostPosted: Mon Apr 08, 2024 7:50 am     Reply with quote
When you pass the address of a pointer, you are only passing the start address.
It does not have any inherent knowledge of whether it is a multi-dimensional array. You will need to treat it as a one-dimensional array and calculate the location based on the size of the array.
