Can I use a Load n Go together with serialize?
Woody
PostPosted: Mon Mar 11, 2024 7:06 am     Reply with quote
I have a LoRa device that needs a unique 32 byte Appkey programmed in every unit. I managed to make this work with #serialize, the ICD-U80 and a file containing the keys. Kudos to CCS for having thought of this functionality albeit probably meant for serial numbers Very Happy
Thinking about how I would do an upgrade in the field I tried to get this working with the Load N Go but that failed. Programming the .hex file in "Memory 1" with the keyfile available gets me a 'failed to write serial number"
error.
Is this at all possible?
PostPosted: Mon Mar 11, 2024 7:59 am     Reply with quote
I suggest you ask CCS.
The #serialize option normally needs ccs_load. However they really should
offer a way to do this on the load'n'go, so if they don't, you need to
persuade them to add this!....
Woody
PostPosted: Mon Mar 11, 2024 9:09 am     Reply with quote
Will do. They'll probably ask me to renew my license first as that timed out last October, but that will be worth it Very Happy
