		| Author | Message |
		| bulut_01
				| A question about oled ssd1306 bitmap |
				|  Posted: Sat Mar 09, 2024 7:17 am |   |
				| Good day friends, I am not very experienced about CCS, I want to show the code I created on the Oled SSD1306 screen. I am using the x.115 version of CCS and I am using the 1306 library. The code below does not compile.. image_bits How can I send the code on the screen?
  	  | Code: |  	  | static const unsigned char image_bits[] = {0x00,0x00,0x00, 0x00,0x00,0x00,0xfe,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,0x3e,0x00
 ,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0xc0,0x01,0x00,0x00,0x00,0x00,0x00,0x00
 ,0x20,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x04,0x00,0x01
 ,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x18,0x00,0x03,0x00,0x00,0x00,0x00,0x08,0x00,
 0x00,0x20,0x00,0x0c,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x40,0x00,0x70,0x00,0x00,
 0x00,0x00,0x04,0x00,0x00,0x80,0x01,0x80,0x01,0x00,0x00,0x00,0x04,0x00,0x00,0x00,
 0x02,0x00,0x06,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x0c,0x00,0x18,0x00,0x00,0x00,
 0x02,0x00,0x00,0x00,0x10,0x00,0xe0,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x20,0x00,
 0x00,0x03,0x00,0x00,0x01,0x00,0x00,0x00,0x20,0x00,0x00,0x1c,0x00,0x00,0x01,0x00,
 0x00,0x00,0x40,0x00,0x00,0xe0,0x00,0x80,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00
 ,0x0f,0x80,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0xf0,0x80,0x00,0x00,0x00,0x00
 ,0x80,0x00,0x00,0x00,0x00,0x8f,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0xf0
 ,0x01,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x80,0xfe,0x00,0x00,0x00,0x80,0x00
 ,0x00,0x00,0x00,0x80,0x00,0x7f,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x80,0x00,0x80,
 0x7f,0x00,0x40,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x80,0xff,0x3f,0x00,0x00,0x00,
 0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00
 ,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00
 ,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00
 ,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
 ,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,
 0x00,0x00,0x00};
 The code I sent to the screen
  	  | Code: |  	  | oled_text57(1, 10, image_bits, 1, 1); |
		| E_Blue
				|  Posted: Sat Mar 09, 2024 9:18 am |   |
				| What is oled_text57(????) Where is the image size?
 To send data you should call that table byte by byte.
 Something similar like
  	  | Code: |  	  | unsigned int16 x;
 for(x=0;x<imageByteCount;x++)
 imageSenderSub(image_bits[x]);
 That's the basic idea. I don't see that in your code.
 Electric Blue
		| temtronic
				|  Posted: Sat Mar 09, 2024 9:28 am |   |
				| A 'link' to the 'driver' you're using would help. I'll assume the '57' in the function means a 5 pixel by 7 pixel character ?
 Probably need a variable that contains the length of the array,so when you make the call, it dumps the entire array to the screen ?
		| E_Blue
				|  Posted: Sat Mar 09, 2024 9:38 am |   |
				|  	  | temtronic wrote: |  	  | A 'link' to the 'driver' you're using would help. I'll assume the '57' in the function means a 5 pixel by 7 pixel character ?
 If that array is not one image and they are several he should use a 2 dimensional array or it could get messy really easy.
 Electric Blue
		| bulut_01
				|  Posted: Sat Mar 09, 2024 10:11 am |   |
				| I am not very knowledgeable on this subject. Can you tell me the code to send the above code to the screen? I am using the 1306 library. |  |
		| bulut_01
				|  Posted: Sat Mar 09, 2024 11:16 am |   |
				| can you help with this |  |
		| temtronic
				|  Posted: Sat Mar 09, 2024 11:42 am |   |
				| Post a 'link' to the '1306' library ! |  |
		| bulut_01
				|  Posted: Sat Mar 09, 2024 2:27 pm |   |
		| temtronic
				|  Posted: Sat Mar 09, 2024 2:33 pm |   |
				| OK, didn't know it was a CCS driver, which you're NOT supposed to post. So please delete it though one of the moderators may...
		| bulut_01
				|  Posted: Sat Mar 09, 2024 2:36 pm |   |
				| Please guide me on this issue, what should I do? |  |
		| temtronic
				|  Posted: Sat Mar 09, 2024 2:46 pm |   |
				| goto your post that has the ssd1306.c driver in and 'delete' the post |  |
		| bulut_01
				|  Posted: Sat Mar 09, 2024 2:53 pm |   |
				| Are you saying this should I delete the ssd1306 library and add another library? |  |
		| temtronic
				|  Posted: Sat Mar 09, 2024 3:53 pm |   |
				| NO, I'm saying you need to delete your POSTING that has the SSD1306 driver in it ! You're not allowed to POST 'drivers' that CCS supplies...it's in the 'rules'.
		| bulut_01
				|  Posted: Sat Mar 09, 2024 5:20 pm |   |
				|  	  | Code: |  	  | static const unsigned char wifi[] = {0x80,0x0f,0x00,0x60,0x30,0x00,0x18,0xc0, 0x00,0x84,0x0f,0x01,0x62,0x30,0x02,0x11,0x40,0x04,0x0a,0x87,0x02,0xc4,0x1f,0x01
 ,0xe8,0xb8,0x00,0x70,0x77,0x00,0xa0,0x2f,0x00,0xc0,0x1d
 ,0x00,0x80,0x0a,0x00,0x00,0x07,0x00,0x00,0x02,0x00,0x00,0x00,0x00};
  	  | Code: |  	  | //draw BMP stored in ROM void SSD1306_ROMBMP(uint8_t x, uint8_t y, rom uint8_t *bitmap, uint8_t w, uint8_t h)
 for( uint16_t i = 0; i < h/8; i++ )
 for( uint16_t j = 0; j < (uint16_t)w * 8; j++ )
 if( bit_test(bitmap[j/8 + i*w], j % 8) == 1 )
 SSD1306_DrawPixel(x + j/8, y + i*8 + (j % 8));
 SSD1306_DrawPixel(x + j/8, y + i*8 + (j % 8), 0);
  	  | Code: |  	  | SSD1306_Begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS); SSD1306_Display();
 SSD1306_ClearDisplay();
 SSD1306_ROMBMP(58, 17, wifi, 19, 15);
 I use the ROMBMP algorithm and a ridiculous shape appears on the screen. How can I send the above static const unsigned char wifi shape to the screen correctly?
		| temtronic
				|  Posted: Sat Mar 09, 2024 6:16 pm |   |
				| so.. what's stored in the array called 'bitmap'
 and
 you still haven't deleted the CCS driver in your previous post !!!
 If you don't do that soon, you'll be in trouble with the forum !!!
 | You cannot post new topics in this forum You cannot reply to topics in this forum
