imatos2
| 18F67K22 - HELP SIMPLE ADC NOT WORKING |
Posted: Sun Mar 03, 2024 2:55 pm |
Hi.
This is the first time I try to use this chip. 18F67k22.
Im using CCS 5.070. I can setup ADC converter for other chips but never for this one. Even the Wizard cant. I only want to make one Channel read 0~5vts and send to portB. But there must be something that is not correct or the version of CCs is not ok. Can anyone PLEASE !! HELP ME before I get crazy !! Thanks in advance. |
Joined: 01 Jul 2010 Posts: 9588 Location: Greensville,Ontario
Posted: Sun Mar 03, 2024 4:30 pm |
| Please post your code ! A small test program will do. |
imatos2
Posted: Sun Mar 03, 2024 7:58 pm |
ADC works but the LED on RD1 was supposed to flash every 200ms but i tryied without success.
thanks
#include "18F67K22.h"
#fuses HSM,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOCPD,BORV18,NODEBUG,NOCPB,STVREN,NOPLLEN,NOFCMEN,SOSC_DIG
#device ADC=12
#BYTE PORTA = 0x0F80
#BYTE PORTB = 0x0F81
#BYTE PORTC = 0x0F82
#BYTE PORTD = 0x0F83
#BYTE PORTE = 0x0F84
#BYTE PORTF = 0x0F85
#BYTE PORTG = 0x0F86
#use delay(clock=16000000)
#define led pin_D1
int16 mm;
set_tris_a(0X01);
set_tris_b(0x00);
set_tris_c(0x00);
set_tris_d(0x00);
set_tris_e(0x00);
set_tris_e(0x00);
set_tris_f(0x00);
PORTA = (0x00);
PORTB = (0x00);
PORTC = (0x00);
PORTD = (0x00);
PORTE = (0x00);
PORTF = (0x00);
PORTG = (0x00);
setup_oscillator(OSC_PLL_ON);
SETUP_ADC_PORTS(sAN0||VSS_VDD);
setup_adc (ADC_CLOCK_DIV_16|ADC_TAD_MUL_20);
set_adc_channel(0);
delay_ms(30);
while(true) {
mm=read_adc();
output_b(mm);
if (mm>=300)
output_bit(LED,1);
delay_ms(200);
output_bit(LED,0);
delay_ms(200);
Posted: Mon Mar 04, 2024 2:31 am |
First thing. Learn to use the code buttons!....
Now, what happens???. Tell us what you get?.
The 67K22 is a 'fussy' chip on it's power supply. It will not wake up
correctly is the rise time of the power supply is too slow. Have you tested
with a simple 'flash an LED' program to verify the chip actually is starting?.
Then second comment. You should always have PUT enabled with a crystal.
Now I'd definately re-think how you code your setup. I think you are
trying to run a 4MHz crystal, and clock at 16Mhz with the PLL from this?.
If so, setup as:
#device ADC=12
#use delay(CRYSTAL=4MHz, CLOCK=16MHz)
#fuses HSM, NOWDT, NOPROTECT, PUT, NOBROWNOUT, NOCPD, BORV18
#fuses NODEBUG, NOCPB, STVREN, NOFCMEN, SOSC_DIG, NOXINST
//PUT should always be used when using a crystal.
//Explicitly setting HSM to handle chip erratum.
Makes it much more obvious what the clock actually is.
Now there is an obvious issue with your 'output_b(mm)'. I'd suggest
dividing by 16 for this.
Now do you have Avss and Avdd connected?. These are required.
Look carefully at this line:
There is a typo here.....
Your compiler is late enough, that this should work. So as I say, tell
us what you are actually seeing?. |
PrinceNai
Posted: Mon Mar 04, 2024 4:27 am |
| As Mr. Ttelmah said, you are trying to show a 16 bit variable on an 8 bit port, so divide mm by 16 before sending it to PORTB. Connect AVDD and AVCC or ADC won't work, Third, you have a 100ms delay after each reading so LED isn't going to blink 200ms on, 200ms off. Just delete that row. |
E_Blue
Posted: Mon Mar 04, 2024 12:45 pm |
Are you powering the microcontroller with 5V? _________________ Electric Blue |
imatos2
Posted: Mon Mar 04, 2024 4:06 pm |
Yes I am applying 5v to the Chip, To AVDD, AVSS
ADC works fine.
Just didn't know how to fix the oscillating frequency.
Thanks |
