multi file compilation
ralph79
PostPosted: Thu Feb 22, 2024 11:40 am     Reply with quote
Hi all,
It could be a basic question, but I really need to know if there is any way to make a multi file compilation ( for example two (2) ".c" files and two (2) or more ".h" ), obviously with only one main function...is possible? I'm using the Mplabx V6.05 and CCS 5.112
thanks in advance
PostPosted: Thu Feb 22, 2024 11:49 am     Reply with quote
Just #include them in the right order. If you look at least half the examples
and many of the posts in the code library have multiple files.
My current main project has 47 files.
ralph79
PostPosted: Thu Feb 22, 2024 11:53 am     Reply with quote
Normally i have big files with several .h files (10/12 units) but i never could it working with several .c files ....
PostPosted: Fri Feb 23, 2024 12:00 am     Reply with quote
.c and .h are just exensions. They make no difference. It depends what
is in them. If you look at the supplied CCS drivers, these usually have
the actual driver as a .c file, and the prototypes and declarations as the
.h file. The main .c file includes these. So multiple .c files. What you can't
have is multiple projects (so sets of fuses, clock settings and processor
includes). Each of these is a separate build, and will generate a separate
main.
PostPosted: Fri Feb 23, 2024 6:31 pm     Reply with quote
I've never understood the .c vs .h extensions....as it's ALL C code.
to me a 'driver' should have .dvr , setup stuff .hdr , dotc for 'main()'
OK, I've never taken a C course or fully read any C books( 1/2 of one for 8088 though...)
I do use 'pictype.FZS' for a file that contains all the 'fuses'. Silly PIC18F46K22 has more fuses than instructions, so 'offloading ' the fuses to a separate 'include' file made sense to me. Shortens the real program, save me hours of typing the typos from 2 finger typing.
PostPosted: Fri Feb 23, 2024 11:00 pm     Reply with quote
THe 'standard' used to be that actual code was in .c files, and the .h
files had the prototypes and data definitions. However a huge amount
of code gets these confused.
Yes, a quick read shows this is in The C Programming Language.
