rs232 communication
MCUprogrammer
rs232 communication
PostPosted: Thu Dec 28, 2023 9:17 am     Reply with quote
How can I create a control code to detect if the connection is lost during communication via RS232? Would you help me with this topic?
Best Regards...
MCUprogrammer
_______________________________
Work Hard
PostPosted: Thu Dec 28, 2023 9:27 am     Reply with quote
Of itself, serial does not have any detection of the 'state' of the connection.
A lot depends on the nature of what is being sent, and how the wiring is done?.
So (for example), you can wire a connection so that if the connection is not
present the receiver is biased to the 'break' state. This will then give
continuous received zero characters with the framing error bit set.
Alternatively, your friend is the timeout. If you know a packet should arrive
every second, then have a timer interrupt set to timeout at (say) 1.2 seconds,
and reset this whenever a packet arrives. If this triggers the connection has
been lost.
MCUprogrammer
PostPosted: Thu Dec 28, 2023 9:57 am     Reply with quote
There are 3 connections on the device. RX,TX,GND. For example, can I do something like the following? or what can i do.
       if (kbhit(UART1)) {
          printf("There is a connection\r\n");
       } else {
          printf("No connection\r\n");
Best Regards...
MCUprogrammer
Work Hard
gaugeguy
PostPosted: Thu Dec 28, 2023 10:55 am     Reply with quote
What you posted would probably not work well on its own. You are really missing the point of the advice Ttelmah was giving.
The answer relies on information you did not provide. How does your device define a working connection? Are the messages formatted or random? Are messages sent at a regular interval or can the arrive at any random time?
MCUprogrammer
PostPosted: Thu Dec 28, 2023 11:04 am     Reply with quote
I solved the problem with timeout. thanks
Best Regards...
MCUprogrammer
Work Hard
