PIC18F47Q43 Fuse problems
dmitrboristuk
PostPosted: Thu Dec 14, 2023 2:37 pm     Reply with quote
Cannot set bits for XT, LP, NOEXTOSC, ECL, ECM, ECH in configuration word 1 with any combination I only get HS (Versions 5.101 and 5.115)
I also tried manual using #fuses 1=0xXXXX unsuccessfully
Are there other installation methods using #org or #rom ?
#FUSES LP, RSTOSC_HFINTRC_1MHz
Configuration Fuses:
   Word  1: FFFA   HS RSTOSC_EXT NOCLKOUT PRLOCK1WAY CKS FCMEN
gaugeguy
PostPosted: Thu Dec 14, 2023 3:21 pm     Reply with quote
#include <18F47Q43.h>
#device ADC=12
#use delay(internal=1MHz)
      //TODO: User Code
Word 1: FFEC NOEXTOSC RSTOSC_HFINTRC_1MHZ NOCLKOUT PRLOCK1WAY CKS FCMEN
dmitrboristuk
PostPosted: Thu Dec 14, 2023 3:28 pm     Reply with quote
That is, the value is taken from #use delay () and it doesn’t matter what happens in #fuse ?
PostPosted: Thu Dec 14, 2023 3:33 pm     Reply with quote
Maybe it might be the programmer changing the settings and/or you have 'debug' enabled ??
gaugeguy
PostPosted: Thu Dec 14, 2023 3:35 pm     Reply with quote
You wanted an example of the compiler setting it to something other than HS. That was the simplest. Tell the compiler what you want to use and let it pick the fuse settings.
gaugeguy
PostPosted: Thu Dec 14, 2023 3:37 pm     Reply with quote
#device ADC=12
#use delay(clock=1MHz)
      //TODO: User Code
Word 1: FFFF ECH RSTOSC_EXT NOCLKOUT PRLOCK1WAY CKS FCMEN
gaugeguy
PostPosted: Thu Dec 14, 2023 3:44 pm     Reply with quote
Also if you plan to use this device be sure to read the errata.
PIC18F27/47/57Q43 Silicon Errata
Especially the SRAM readback
SRAM Readback
Following a device power up sequence, there is a possibility that some SRAM locations will not return the expected
written value but will read back '00' instead.
Work around
None. The device can only recover by power cycling.
dmitrboristuk
PostPosted: Fri Dec 15, 2023 12:44 am     Reply with quote
With //#use delay() disabled, all bits are set normally. I don’t understand why this was done. In addition to the source of oscillations, the CPU frequency is affected by the PLL and frequency postscaler.
PostPosted: Fri Dec 15, 2023 6:51 am     Reply with quote
Not true.
Three ways of working:
1) You set the fuses yourself, and just select 'clock' with #use delay
This will only override your fuses if they don't support the clock being
selected.
So:
#device ADC=12
#FUSES NOWDT, XT                   //No Watch Dog Timer, XT osc
#use delay(CLOCK=1MHz)
//gives
   Word  1: FFF9   XT RSTOSC_EXT NOCLKOUT PRLOCK1WAY CKS FCMEN
   Word  2: DFF7   MCLR NOPUT NOMVECEN IVT1WAY NOLPBOR BROWNOUT BORV19 ZCDDIS PPS1WAY STVREN NOLVP NOXINST
   Word  3: FF9F   WDTSW NOWDT WDTWIN_SW WDTCLK_SW
   Word  4: FFFF   BBSIZ512 NOBOOTBLOCK NOSAF NODEBUG NOWRTB NOWRTC NOWRTD NOWRTSAF NOWRT
   Word  5: FFFF   NOPROTECT
Merrily selects XT.
2) Set the clock _before_ you set the fuses. Here what you tell the fuses
to be will override what #use delay says.
So:
#device ADC=12
#use delay(CLOCK=10MHz) //This will have selected HS
//But this in then over-riden by your setting - wrong, but proves the point.
3) Don't set clock fuses at all. Let the #use delay control these.
So:
#device ADC=12
#FUSES NOWDT
#use delay(INTERNAL=1MHz)
//Will give
The use of the right keywords with #use delay, and the _order_ of the
settings allows every possibility.
dmitrboristuk
PostPosted: Fri Dec 15, 2023 2:58 pm     Reply with quote
Thank you, I didn't pay attention to this before
PostPosted: Sat Dec 16, 2023 4:58 am     Reply with quote
Oh, and one extra little thing. The reason the compiler defaults to HS mode
much more than you'd expect is in the errata for the chip. The XT oscillator
doers not work reliably above 2MHz on this chip family..... Sad
