Help Please! Expression must evaluate to a constant (Solved)
NWilson
PostPosted: Thu Nov 16, 2023 8:37 am     Reply with quote
PCWHD Version 5.116
Hi all,
I’m trying to produce a hardware clone of an old instrument based on a siemens SAB-C165 microprocessor and port the code over to a PIC24FJ128GC006.
The instrument has dozens of menus with lots of messages and associated actions. TBH, being a hardware engineer, I am struggling to get the menu system ported over.
Can anyone help me out with the following error?
*** Error 27 "C:\Development\Hardware Clone\main.c" Line 69(4,5): Expression must evaluate to a constant
Here is a simplified snippet of code that shows the problem.
// main.c
// Rev         : 1.0
// Start Date  : 16th November 2023
// Author      : Neil Wilson
#EXPORT (FILE=Menu_Test.hex)
#include <24FJ128GC006.h>
#device  ANSI
#device  ADC=12
#device  ICD=TRUE
#device  ICSP=1
#use delay(internal=32000000)
#FUSES   NOWDT                    //No Watch Dog Timer
#FUSES   CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#define  MENU_INTRO 0
#define  MENU_MAIN  1
#define  MENU_FILE  2
#define  MENU_SYS   3  //Lots of menus ........
#define  BLANK      0
#define  MESS_ACC1  1
#define  MESS_ADC1  2
#define  MESS_ADC2  3
#define  MESS_CLE1  4
#define  MESS_CHE2  5
#define  MESS_BATLOW  6   // Lots of messages......
// a snippet of dictionary entries - lots of them!
const char *message [] =
   "                      ",     // 0 BLANK
   "Acceptable Range",           // 1 MESS_ACC1
   "ADC Setup",                  // 2 MESS_ADC1
   "ADC Test",                   // 3 MESS_ADC2
   "Clearing Memory ....",       // 4 MESS_CLE1
   "Check PSU",                  // 5 MESS_CHE2
   "** Battery Low ! ** "        // 6 MESS_BATLOW
struct zMenu
   int cText[8];                 // dictionary index for each display line
   unsigned char cAction[8];     // action code for each display line
   unsigned char cCsr;           // initial line for cursor to start from
   unsigned char cEscape;        // action on escape key
   unsigned char cTitle;         // title inverted flag
   void (*func)(void);           // function associated with this menu
const struct zMenu   sMenu0  =   // Menu 0 MENU_INTRO
   MESS_CLE1,
   MESS_CHE2,
   MESS_BATLOW
const struct zMenu   sMenu1  =   // Menu 1 = MENU_MAIN
   MESS_ACC1,
   MESS_ADC1,
   MESS_ADC2
const struct zMenu   *g_sMenu [] =
   {&sMenu0},  {&sMenu1}
void showMenu (unsigned char cPage)
   unsigned char cLine;
   int8 cIndex;
   char chText[5], chBuff[25];
   cLine  = 0;                               // reset line pointer
   cIndex = g_sMenu[cPage]->cText[cLine];    // find dictionary entry
   strcpy(chBuff, message[cIndex]);          // format string on display line
   //display_string_xy(1, cLine, chBuff);    // display string on LCD
   return;
   showMenu(MENU_MAIN);
It's this bit, that it doesn't seem to like.
Thanks in advance
Neil
PostPosted: Thu Nov 16, 2023 12:42 pm     Reply with quote
Start by getting rid of the const declarations.
You should find that things then work.
Then do a search here for why const is different in CCS from the ANSI
usage. It is fundamental and matters massively. There are ways partially
round this, but a lot of thought is needed, and the simplest will be to not
use const.
NWilson
PostPosted: Thu Nov 16, 2023 1:26 pm     Reply with quote
Thanks Ttelmah,
I'll try that tomorrow when I get to work.
NWilson
PostPosted: Thu Nov 16, 2023 1:34 pm     Reply with quote
I've just removed all the const declarations from the above code and it still gives me the same error.
I'm open to suggestions if anyone can help.
Best wishes
Neil
PostPosted: Fri Nov 17, 2023 2:32 am     Reply with quote
OK. The const part was going to give you problems later.
struct zMenu *g_sMenu [2] = {&sMenu0,&sMenu1};
NWilson
PostPosted: Fri Nov 17, 2023 2:39 am     Reply with quote
Brilliant! Thanks Ttelmah
