BMP280 humidity doesn't work
Goto page Previous  1, 2, 3, 4  Next
dyeatman
PostPosted: Tue Sep 12, 2023 12:02 pm     Reply with quote
did you change the speed?
What does the I2C scanner give you?
Google and Forum Search are some of your best tools!!!!
pekka1234
BME280 error
PostPosted: Tue Sep 12, 2023 12:16 pm     Reply with quote
OK I changer the CPU to PIC18F2620 and it workded
I2C Device found at address 0xec
Pekka
gaugeguy
PostPosted: Tue Sep 12, 2023 12:22 pm     Reply with quote
reread what you have been told about your code.
1000000 does not equal 100000 does not equal 10000
pekka1234
PostPosted: Tue Sep 12, 2023 12:29 pm     Reply with quote
OK. I took copy of library
#ifndef BME280_I2C_BAUD
//spec says max i2c clock is 3.4MHz, but I wasn't getting anywhere near that fast.
// #define BME280_I2C_BAUD 1000000
Then I took coy of my main program
#use delay(internal = 1MHz)
Can they be faults?
Pekka
dyeatman
PostPosted: Tue Sep 12, 2023 12:41 pm     Reply with quote
Baud rate setting for I2C and the #use delay are different.
A line like this sets the I2C baud rate:
#use I2C(MASTER, I2C1, FAST = 10000)
pekka1234
BME280 error
PostPosted: Tue Sep 12, 2023 12:48 pm     Reply with quote
I thing that they can be different.
I2C is quite different than CPU speed.
#include <18F2620.h>
#DEVICE ADC=10
#FUSES PUT //Power Up Timer
#FUSES NOMCLR //Master Clear pin not enabled
#FUSES NOWRT
#use rs232(baud=9600, parity=N, UART1, errors, bits=8, BRGH1OK) // RS232 settings
What I must change?
Pekka
dyeatman
PostPosted: Tue Sep 12, 2023 12:55 pm     Reply with quote
Nothing it that code.
Way back in this thread TTelmah told you to do this:
#include <BME280.c>
The Baud rate definition above is used in this line to set the baud rate:
#use i2c(MASTER, SCL=PIN_BME280_SCL, SDA=PIN_BME280_SDA, STREAM=STREAM_I2C_BME280, NOINIT, FORCE_HW, FAST=BME280_I2C_BAUD)
pekka1234
BME280 error
PostPosted: Tue Sep 12, 2023 1:02 pm     Reply with quote
OK
I changed this
#include "BMe280.c"
But it doesn't help.
Pekka
dyeatman
PostPosted: Tue Sep 12, 2023 1:06 pm     Reply with quote
Change the quotes to brackets so it uses the original driver (if you haven't modified it)
<BMe280.c>
pekka1234
BME280 error
PostPosted: Tue Sep 12, 2023 1:14 pm     Reply with quote
OK
I changed it
#include <BMe280.c>
Here is the result
Vesion check 0
Error reading BME280 sensor!
Vesion check 0
Do you have some other my error.s ?
This senor works normally, but do not give humidity value.
With BMP280 library
It work 8MHz and normal I2C
Pekka
dyeatman
PostPosted: Tue Sep 12, 2023 1:19 pm     Reply with quote
Sounds like you modified the BME280 driver in the CCS Driver directory which
should never be done. Always make a copy and change the name if you want
to make changes to a CCS supplied driver. You need to restore the original.
pekka1234
BMe280
PostPosted: Tue Sep 12, 2023 1:32 pm     Reply with quote
OK, I took a new copy from CCS drovers and installed to to same place
I compiler it , and move to my sensor,
No change.
This was a result
Version check 0
You have helped me much, but now I have to go sleep,
The clock is about 22:30 here
Pekka
PostPosted: Wed Sep 13, 2023 7:38 am     Reply with quote
The obvious thing would be that you actually have the BMP280, rather than
the BME280. Can you look at the top of the chip with a magnifying glass?.
The part number on this would be what says it is the BME rather than the
BMP. Possibly the board you have was built with the wrong chip for
what is printed on the silk screen.....
You could also read the chip ID. This is 0x60 for the BME, and 0x58 for
the BMP.
The CCS driver does work. I have it reading these sensors. Use 400KHz,
which is the maximum that you should use without active pull-ups.
pekka1234
BME280 error
PostPosted: Wed Sep 13, 2023 11:13 am     Reply with quote
Thelmah
It may be BMP280, although it says clearly BME280, because my program with BMP280.c works well, with SCO ground or without SCO ground.
The only problem is that can't measure humidity.
It now outside for measuring, but tomorrow I will try it with CCS BMP280.c library again.
Pekka
PostPosted: Wed Sep 13, 2023 11:51 am     Reply with quote
I think you mean SDO.
This must never be allowed to float. It can be pulled up or down.
If it is pulled up and the code still works, then this implies the chip
is not a real BMx280. This would change the I2C address and the code
as has been posted will no longer work.
Page 3 of 4
