		| View previous topic :: View next topic   |
			daveh
				| US2066 OLED I2C Driver 04x20 - NHD-0420CW-AB3 |
				 Posted: Mon Dec 05, 2022 11:02 am     |
				The following is code to initialize and use the US2066 OLED display driver using I2C.  Code tested on NewHaven Display NHD-0420CW-AB3 display.
 	  | Code: | 	 		  #include <33EP512MC504.h>
#FUSES NOWDT                    //No Watch Dog Timer (must be off to control from firmware)
#FUSES NOJTAG                   //JTAG disabled
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES PROTECT
#FUSES FRC_PLL
#build (stack=1024)
#use delay(internal=40MHz)
#include <STDLIB.H>     // for rand()
// PIN - DESCRIPTIONS
// 01 - Vss - 0v
// 02 - Vdd - 3.3v
// 03 - REGVdd - 0v
// 04 - SA0 - 0v    - Changing to Vdd changes the address from 0x3C to 0x3D
// 05-06 - NC - 0v
// 07 - SCL - PIN_B4
// 08 - SDAin  - PIN_A8
// 09 - SDAout - PIN_A8
// 10-15 - NC - 0v
// 16 - /RES - PORTB.10
// 17 - BS0 - 0v    - I2C = BS:010
// 18 - BS1 - 3.3v
// 19 - BS2 - 0v
// 20 - Vss - 0v
#byte PORTB = 0xE12
#bit LCD_RES = PORTB.10      // /RES pin on LCD
// Define I2C Master Module - Hardware
#define i2c2_SCL PIN_B4
#define i2c2_SDA PIN_A8
#bit I2C2EN_BIT = 0x0216.15      // I2CEN bit to enable/disable hardware I2C module
#define i2cM_Baud 400000    // Primary baudrate for I2C
#use i2c(MASTER,STREAM=i2cM,I2C2,FAST=i2cM_Baud,FORCE_HW)  // Master I2C module 2 read sensors MCP9600-100kHzMAX
#define NHD_0420CW_ADR 0x78         // if SA0=0 ADR=0x3C (0x78 shifted by 1), if SA0=1 ADR=0x3D (0x7A shifted by 1)
void initLCD_US2066();              // Initialize US2066 Display
void LCD_Data(int8 ByteVal);
void LCD_Command(int8 ByteVal);
void main() {
    set_tris_a(0b1111101111100101);
    set_tris_b(0b0100001011110011);
    set_tris_c(0b1111111100110000);
    initLCD_US2066();
    printf(LCD_Data,"Hello World");
    printf(LCD_Data,"\4Print on line4");
    printf(LCD_Data,"\2     Print on line2");
    printf(LCD_Data,"\3Random Number %u",rand());
    while(true){
void initLCD_US2066(){
    LCD_RES=1;
    delay_ms(1);
    // Initialization commands from NHD-0420CW-AB3 example code
    LCD_Command(0x2A);    //function set (extended command set) SET RE=1 IS=0
    // IS=0 RE=1 SD=0 - EXTENDED
     LCD_Command(0x71);    //function selection A
      LCD_Data(0x00);    // disable internal VDD regulator (2.8V I/O). data(0x5C) = enable regulator (5V I/O)
    LCD_Command(0x28);    //function set (fundamental command set) SET RE=0 IS=0
    // IS=0 RE=0 SD=0  - FUNDAMENTAL
     LCD_Command(0x08);    //display off, cursor off, blink off
    LCD_Command(0x79);    //OLED command set enabled SET SD=1
    // IS=0 RE=1 SD=1 - OLED
     LCD_Command(0xD5);    //set display clock divide ratio/oscillator frequency
      LCD_Command(0x70);    //set display clock divide ratio/oscillator frequency
    LCD_Command(0x78);    //OLED command set disabled SET SD=0
     LCD_Command(0x09);    //extended function set 3or4-lines display / 5-dot font width / disable inverting cursor /
     LCD_Command(0x06);    //COM SEG direction
     LCD_Command(0x72);    //function selection B
      LCD_Data(0x08);     //ROM CGRAM selection - Select ROM C
//    LCD_Command(0x2A);    //function set (extended command set) SET RE=1 IS=0     // not neeed, RE already set
     LCD_Command(0xDA);    //set SEG pins hardware configuration
      LCD_Command(0x10);    //set SEG pins hardware configuration
     LCD_Command(0xDC);    //function selection C
      LCD_Command(0x00);    //function selection C
     LCD_Command(0x81);    //set contrast control
      LCD_Command(0x7F);    //set contrast control
     LCD_Command(0xD9);    //set phase length
      LCD_Command(0xF1);    //set phase length
     LCD_Command(0xDB);    //set VCOMH deselect level
      LCD_Command(0x40);    //set VCOMH deselect level
     LCD_Command(0x01);    //clear display
     LCD_Command(0x02);    //set DDRAM address to 0x00 'HOME'
     LCD_Command(0x0C);    //display ON
void LCD_Data(int8 ByteVal){
    switch (ByteVal)
        case '\a'   :               // Home
            LCD_Command(0x02);        // Return Home
        case '\f'   :
            LCD_Command(0x01);        // Clear Display
        case '\n'   :
            LCD_Command(0xA0);        // Goto Line2 (0x20 | 0b10000000)
        case '\2'   :
        case '\3'   :
            LCD_Command(0xC0);        // Goto Line3 (0x40 | 0b10000000)
        case '\4'   :
            LCD_Command(0xE0);        // Goto Line4 (0x60 | 0b10000000)
        default     :
            i2c_start(i2cM);
            i2c_write(i2cM,(NHD_0420CW_ADR)|0);     // NHD-0420CW
            i2c_write(i2cM,0x40);
            i2c_write(i2cM,ByteVal);
            i2c_stop(i2cM);                    // Restart
            delay_us(20);
void LCD_Command(int8 ByteVal){
    i2c_start(i2cM);
    i2c_write(i2cM,0x00);
    delay_us(20);
			MartinOl
  Joined: 10 Aug 2023 Posts: 1 Location: Prague, Czech Republic
				| It works with PIC16F also :) |
				 Posted: Thu Aug 10, 2023 1:44 am     |
				Hi. I used your code with small modifications for PIC16F18877 and it works well. Thank you very much. Just do not forget pull-up (approx. 4k7) resistors on the SDA and SCL.
#include <16F18877.h>
#device ADC=10
#use delay(internal=8000000,restart_wdt)
#use FIXED_IO( D_outputs=PIN_D1 )
#define LED   PIN_D1
#define RES   PIN_A0
#pin_select SDA1=PIN_C4
#pin_select SCL1=PIN_C3
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3,restart_wdt,force_hw)
// OLED PIN - DESCRIPTIONS
// 01 - Vss - 0v
// 02 - Vdd - 3.3v
// 03 - REGVdd - 0v
// 05-06 - NC - 0v
// 07 - SCL - PIN_C3 with 4k7 pull-up resistor to 3V3
// 08 - SDAin  - PIN_C4 with 4k7 pull-up resistor to 3V3
// 09 - SDAout - PIN_C4
// 10-15 - NC - 0v
// 16 - /RES - 3v3
// 18 - BS1 - 3.3v
// 19 - BS2 - 0v
// 20 - Vss - 0v
#byte PORTB = 0xE12
void main() {
    initLCD_US2066();
    printf(LCD_Data,"\2Print on line2");
    printf(LCD_Data,"\3Print on line3");
    while(true){
    output_high(RES);
    delay_ms(1);
    switch (ByteVal)
        case '\a'   :               // Home
        case '\f'   :
        case '\n'   :
        case '\2'   :
        case '\3'   :
        case '\4'   :
        default     :
            i2c_start();
            i2c_write(NHD_0420CW_ADR|0);     // NHD-0420CW
            i2c_write(0x40);
            i2c_write(ByteVal);
            i2c_stop();                    // Restart
            delay_us(20);
    i2c_start();
    i2c_write(0x00);
    i2c_write(ByteVal);
    delay_us(20);
