Flexible LCD driver
Goto page Previous  1, 2, 3, 4, 5, 6, 7
Post new topic   Reply to topic    CCS Forum Index -> Code Library
dxdxdx
PostPosted: Tue Jan 18, 2011 2:55 pm     Reply with quote
dear PCM,
I'm having this problem while compiling the code.
Error 128 "flex_lcd.c" Line 28(1,42): A #DEVICE required before this line
int8 const LCD_INIT_STRING[4] =
I have tried to checked in other post regarding to this issue, but perhaps I'm not good in programming, I don't understand. Could you please give me some advice in what to modify to make the code successfully compile?
regards
PostPosted: Wed Jan 19, 2011 2:12 pm     Reply with quote
You're trying to compile the "flex_lcd.c" driver file as the main C project file.
But it's a driver file. It's intended to be included in your main C project file
with an #include statement.
If you look at the first post in this thread, you will see the "flex_lcd.c"
driver file, and you will see another shorter file called the Test Program.
The Test Program file should be compiled as your main .c program
in your project. The compiler will automatically include the flex_lcd.c
file in the project, provided that you specify it with an #include statement.
This is done in the posted Test Program file.
If you have any more questions on how to put together a project that
consists of a main file and a driver file, please ask in the main forum
not the Code library forum.
dxdxdx
PostPosted: Fri Jan 21, 2011 12:12 pm     Reply with quote
oh i understand now, thanks PCM programmer!
but now i have done what you do so, but my jhd162A is not displaying anyhing. i wonder where is gone wrong? can anyone give me the connection schematic?
im connecting as in the flex_lcd, and the db0,db1,db2,db3 is connected into ground.
PostPosted: Fri Jan 21, 2011 5:48 pm     Reply with quote
Ask this type of question in the main CCS forum.
newpic
flex_lcd.c driver
PostPosted: Fri Feb 04, 2011 3:16 pm     Reply with quote
Hello PCM?
I've try your driver and test program on the old PIC Demo 2 Plus board, my issue is the text display on the LCD was flickering like timing or freqency issue. I can see first 5 letters on the first line and then the rest just flickering.
Do you have any suggestion how to fix this?
Thanks.
PostPosted: Fri Feb 04, 2011 3:41 pm     Reply with quote
Ask this type of question in the main CCS forum !
DonWare
Thanks for this.
PostPosted: Fri Jun 17, 2011 1:36 pm     Reply with quote
PCM Programmer
I'm not religious by nature but God bless you for writing this. It saves me untold time and aggravation. It works fine on my old (red) 2002 PICDEM 2 PLUS board.
gumust
edit
PostPosted: Mon Sep 05, 2011 7:56 am     Reply with quote
If you replace this part
#define LCD_DB4 PIN_D0
#define LCD_DB5 PIN_D1
#define LCD_DB6 PIN_D2
#define LCD_DB7 PIN_D3
#define LCD_E PIN_A1
#define LCD_RS PIN_A3
#define LCD_RW PIN_A2
with this part
#ifndef LCD_DB4
#ifndef LCD_DB5
#ifndef LCD_DB6
#ifndef LCD_DB7
#ifndef LCD_E
#ifndef LCD_RS
#ifndef LCD_RW
you can include flex_lcd.c in all project easily.
to use:
#include "main.h"
#define LCD_DB4   PIN_C4
#define LCD_DB5   PIN_C5
#define LCD_DB6   PIN_C6
#define LCD_DB7   PIN_C7
#define LCD_RS    PIN_B0
#define LCD_RW   PIN_B2
#define LCD_E      PIN_B1
#include "flex_lcd.c"
   lcd_init();
   delay_ms(250);
   lcd_putc("\fExample");
   while(TRUE) {
      output_high(PIN_B3);
      delay_ms(200);
      output_low(PIN_B3);
gmua
LCD 2x16 Driver for MikroElektronika EasyPic v7 Board
PostPosted: Wed Jan 25, 2012 10:07 pm     Reply with quote
PCM programmer wrote:
Why use it ?
2. If you're a newbie and your board isn't configured to use the CCS driver, and you don't
know how to modify it or Mark's driver, then this driver can get you up running quickly.
I modified the following lines to make the LCD work with the EasyPic v7 and CCS C and is working great.
// These pins are for the MikroElektronika EasyPIC v7 Board
#define LCD_DB4   PIN_B0
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_B2
#define LCD_DB7   PIN_B3
#define LCD_E     PIN_B5
#define LCD_RS    PIN_B4
// #define LCD_RW    PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
// #define USE_LCD_RW   1
Thanks a lot PCM programmer.
wordizlife
PostPosted: Tue Apr 17, 2012 2:34 pm     Reply with quote
Just wanted to thank you for this great post. Very user friendly coding, very appreciated! Smile
Velraj
8 bit flex_lcd
PostPosted: Tue Mar 11, 2014 5:21 am     Reply with quote
Can anyone code for 8bit flex_lcd ??
cyril.carlita
drive for lcd 1602
PostPosted: Thu Jul 20, 2023 7:00 am     Reply with quote
Hello, i try the first driver for 2x16 ligne but lcd_gotoxy function don't work for me.
I can't go to the ligne 2 with lcd_gotoxy(1,2) , Why?
Can you show me a driver that work for 2x16 lignes?
cyril.carlita
PostPosted: Thu Jul 20, 2023 11:53 am     Reply with quote
Finnaly, it work for me
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 7 of 7
