How to Start a Second Instance of the CCS IDE
soonc
PostPosted: Tue Jun 13, 2023 10:08 am     Reply with quote
How to Start a Second Instance of the CCS IDE.
I know it can be done but forgot how to do that..
thanks
PostPosted: Wed Jun 14, 2023 12:43 am     Reply with quote
If you have a second copy installed in a separate directory, you can open this.
It is only the PCW, that you actually need duplicated, so you can just have
a duplicate of this. However this potentially has problems because some
of the temporary files etc., may use the same copies as the other instance,
so full duplication is really safer.
soonc
PostPosted: Wed Jun 14, 2023 6:59 pm     Reply with quote
Thanks... I know it's possible to open a second instance but I forgot how to do that.
When I did that It allowed me to debug two sets of code. Of course with two ICD-U64 ...
I'll call CCS and ask.
This is a problem when getting old (81+) :-)
PostPosted: Thu Jun 15, 2023 12:51 am     Reply with quote
The only method I have ever seen, was by duplicating PCW. So you copy
PCW.exe, rename this PCW2.exe, and launch this. However I have known
this have fractional issues when doing certain things, which complete
duplication doesn't seem to suffer from.....
The other way you could do it would be by using a Windows 'trick'. You can
launch a program as a different user. Shift right click on it, and select 'run
as a different user'. If you haven't got multiple users on the system, you will
have to create one.
soonc
Here is the Oficial way
PostPosted: Mon Jun 19, 2023 9:17 am     Reply with quote
have to create one.
OK I called and asked how to start a second instance:
Desktop Shortcut/Properties/ at the end of the Target Line put a Space and then +FORCE_NEW
"C:\Program Files (x86)\PICC\pcw.exe" +FORCE_NEW
The second time you click the shortcut a new instance appears.
When using both with ICD-U64 you need to make the choice of which ICD-U64 is to be used for each instance.
Thanks for the help.
PostPosted: Mon Jun 19, 2023 10:09 am     Reply with quote
I have found it referenced here:
[url]
http://www.ccsinfo.com/newsdesk_info.php?newsdesk_id=263
[/url]
Note the limitations they refer to though. Caveat....
