Blackjackmaster
Serial Port |
Posted: Sun May 14, 2023 1:05 pm |
This is the code I am using to turn on the Green and Yellow LED from the Serial Monitor from the CCS IDE and works as it should. I run this code in a C# program and it does not work. The LED does turn on but does not toggle, will not turn off. Is there any Sample Code between CCS and C# Serial Port?
#include <16F877A.h>
#use delay (clock = 20000000)
#use rs232(baud=9600,xmit=PIN_C6, rcv=PIN_C7)
#define Green pin_a5
#define Yellow pin_B5
unsigned int8 x;
output_b (0b00000000);
printf("\n\r Hit a key (1-4) to toggle LED");
x=getc();
printf("\n\r You Hit "); putc(x);
if (x=='1') output_toggle(Green);
else if (x=='2') Output_toggle(yellow);
C# Code: Button 1 Send, Button 2 Receive
private void button1_Click(object sender, EventArgs e)
SerialPort1.WriteLine(textBox1.Text);
textBox1.Text = "";
private void button2_Click(object sender, EventArgs e)
try
textBox2.Text = SerialPort1.ReadLine();
catch(TimeoutException)
textBox2.Text = "Timeout Exception";
Posted: Mon May 15, 2023 12:55 am |
No,
they are fundamentally different languages. C# is an event driven language,
C is not.
If you have problems with C# you really need to ask on a C# forum, not here.
However looking at what you post, I see nothing in either button event,
doing anything to an LED. So how is it meant to work?. |
jeremiah
Posted: Mon May 15, 2023 8:00 am |
It's a poorly worded question. They are trying to say they want to use a C# program to control the micro and are showing the micro code that receives serial commands and the C# code that sends serial commands.
Side note, C# is not an event driven language explicitly. It definitely has a lot of native support for events, but it also does structural programming among other programming styles. C does support events (ISRs for example are events), however, it doesn't have language built ins that facilitate it more easily like C# does. Just adding clarity for folks for later on when this thread is read years later.
For the OP:
I would start with print statements to ensure your C# code is firing the correct lines, then use an oscilloscope to verify the serial data is on the line and at the correct baud. |
Posted: Mon May 15, 2023 9:13 am |
He seems though to be saying that he has the C code working, and the
C# program does not do the same.
However he is not doing the same things in the handlers for the buttons
that he does in the C program. No wonder it does not do the same....
C# fundamentally has event handlers for things like buttons, that are
called when these events happen. The core of C does not have this. You can
generate similar behaviour with interrupts (he could have his buttons
interrupt driven), but as shown the two programs are not even remotely
equivalent.
If he wants to learn C# programming then he really does need to be
asking on a C# forum, not here. |
Posted: Mon May 15, 2023 9:51 am |
I see what you are saying.
The same comments still apply though. If you look at his C program this
expects to receive '1' or '2' sent. If he wants the C# program to control
this, then the button1 handler has to send '1', and the button2 handler send
'2'. Not what is being done :( |
jeremiah
Posted: Tue May 16, 2023 7:52 am |
In their C# code, they have a button click handler with:
Code: | SerialPort1.WriteLine(textBox1.Text); |
which takes a value from a text box and sends it over serial. My thoughts are that they use this to send the values, especially since the CCS code is looking for ASCII 1 and 2 instead of raw 1 and 2.
It might be wrong code and you are correct they should be looking at a C# forum for that part.
I think my suggestions above are worth trying though. |
Posted: Tue May 16, 2023 9:39 am |
That means he would have to go to that specific textbox, type '1' into it,
then hit button 1. Or for the other LED type '2' into it, and then hit button 1
again.
Doesn't really make sense.... |
Joined: 01 Jul 2010 Posts: 9120 Location: Greensville,Ontario
Posted: Tue May 16, 2023 9:47 am |
I've always used a 'terminal program' like RealTerm for 'basic-see-if-it-works' communication to-from a PC. When that works, THEN tackle the 'fancy' code cutting. |
Posted: Tue May 16, 2023 11:44 am |
temtronic, the OP has done that. From his first post:
Quote: | This is the code I am using to turn on the Green and Yellow LED
from the Serial Monitor from the CCS IDE and works as it should. |
In other words, he has tested the PIC code by sending chars to it with
the CCS SIOW.exe program. |
Posted: Tue May 16, 2023 3:50 pm |
hmm, I misinterpretted the statement, thinking it was some internal custom software like the debugger uses, not that he'd used SIOW.
Since that does work, then it's just incorrect C# program. |
Posted: Wed May 17, 2023 1:15 am |
Exactly.
And the point his the C# program makes no sense at all. It doesn't look
for the serial message till you push 'button2', and then as already outlined
you have to type the right value into a textbox, and then press button1
to do the toggle.
It really should be using the serial receive event, to clear the text box
when a line feed is received, and then write the message into this.
Then two buttons, one simply sends '1' and the other '2'.
Result a program that can work.
Nothing at all to do with CCS C, he needs basic help in writing a C#
program. He confuses things more by talking as is he wants to translate
code between the two languages. |
