I need help to fix an error in my small code
Ibrahim_kh
PostPosted: Thu May 11, 2023 11:25 am     Reply with quote
*** Error 51 "labC3.c" Line 43(15,20): A numeric expression must appear here
#DEVICE PIC16F628A
#use delay(clock = 4000000)
#fuses INTRC_IO, NOWDT, PUT
#include "LCD.h"
#include "16F628A.h"
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
void scrollText1(char* text) {
    int len = strlen(text);
    int i, j;
    // Loop to scroll the text
    for (i = 0; i <= len - 16; i++) {
       lcd_init();
      lcd_gotoxy(1,1);               // Set cursor position to the beginning of the first line
       // Write the current 16 characters of the text to the LCD
for (j = 0; j < 16; j++) {
    lcd_putc(text[i + j]);
delay_ms(10);
// Replace the above code with the following:
char substring[17];
strncpy(substring, text + i, 16);
substring[16] = '\0';
lcd_putc(substring);
        delay_ms(500);                // Delay to control scrolling speed
  const char* SENTENCE = "Thank you  for programming me!!";
delay_ms(10);
  scrollText1(SENTENCE); ////////////LINE51 WHERE THERE IS ERROR
while(1){};
dyeatman
PostPosted: Thu May 11, 2023 11:58 am     Reply with quote
By cleaning up your header lines (deleting the #include 628A.h line, fixing the
#DEVICE line and fixing the LCD.h line).
#DEVICE PIC16F628A <<<<<<<<<< One Device line (deleted the .h file line)
#include <LCD.c>  <<<<<< Changed to LCD.c <<<<<<<
Made no other changes in the rest of the code and it now compiles under 5.115
Didn't look for any other issues.
Google and Forum Search are some of your best tools!!!!
PostPosted: Fri May 12, 2023 2:09 am     Reply with quote
Better really to use the #include line.
But put it where shown by dyeatman:
#include  "16F628A.h" //The include has the device definition in it
Using the #include adds the definitions for lots of things, and if you don't
have these there will be problems with anything more complex.
The key point though is that the processor definition _must_ always come
before almost anything else. Otherwise the compiler does not know what
you actually want it to do, and the processor can only be set _once_.
Even with the code as shown, if you don't have the #include, you don't
have models for any form of debugging.
