PIC16F18326 internal OSC
aldina
PostPosted: Wed May 03, 2023 10:19 am     Reply with quote
I'm using PIC16F18326.
I need to read some ADC (AN0) inputs and according to the input value I have a green (PIN_A1) or red (PIN_A5) signal output.
I think I have some problem with Osc or clock frequency because my delays are wrong.
Other thing is: I only need to make one test (one program main), but it was always running as I have a while(true).
May I have some help from you?
#include <16F18326.h>
#device ADC=10
#FUSES LVP      // Should be NOLVP
#FUSES WDT                      //Watch Dog Timer
#FUSES RSTOSC_LFINTRC
#FUSES NOCLKOUT
#FUSES BROWNOUT, LPBOR, PUT, BORV27     // Power up Timer and Brownouts
#FUSES NOPROTECT  // Should be NOPROTECT
#fuses NOEXTOSC   // *** ADD THIS LINE RIGHT HERE ***
#use delay(internal=32000000) //,restart_wdt)
#BYTE OSCCON1 = 0x919  // OSCCON register (pg 47 datasheet)
#BYTE OSCCON2 = 0x91A  // OSCCON register (pg 47 datasheet)
#BYTE WDTCON = 0x97 // WDTCON (pg 33 datasheet)
//#use standard_io (ALL)
#include <stdio.h>
#include <stdlib.h>
// LEDs intensity
float LDR()
    int8 i;
    float intlum;
    float intlum_sum;
    float intlum_average;
    intlum = 0;
    intlum_sum = 0;
    intlum_average = 0;
    i = 0;
    set_adc_channel(0);
    delay_us(5);
    for(i=0;i<100;i++)
       intlum = read_adc();
       delay_us(5);
       intlum_sum += intlum;
       delay_us(5);
    intlum_average = intlum_sum/100;
    return intlum_average;
void presenca()
   restart_wdt();
   float Position;
   Position = 0;
        // POSITION
    output_high(PIN_C0); // Position ON
    Position = LDR();
   if(Position <= 70) // && Position >= 20)  // Position: 0.14 ~ 0.34 V (Read 0.242V)
      //output_high(PIN_A1); // ON green
      //delay_ms(100);
      //output_low(PIN_A1);
      output_low(PIN_C0);
      //delay_ms(100);
   else if(Position > 70) // || Position < 20)
      output_high(PIN_A5); // ON Red
void STOP()
   restart_wdt();
   float Stop;
   Stop = 0;
   output_high(PIN_C1); // Stop ON
   Stop = LDR();
   if(Stop <= 165) // || Stop >= 110)
      //output_high(PIN_A1); // green
      //delay_ms(100);
      output_low(PIN_C1);
      //delay_ms(100);
   else if(Stop > 165) // || Stop < 110)
      output_high(PIN_A5); // ON red
void DI()
   restart_wdt();
   float Pisca;
   Pisca = 0;
   output_high(PIN_C2); // DI ON
   Pisca = LDR();
   if(Pisca <= 155)
      //delay_ms(100);
      output_low(PIN_C2);
      //delay_ms(100);
   else if(Pisca > 155)
void Fog()
   restart_wdt();
   float Nev;
   Nev = 0;
   output_high(PIN_C3); // fog ON
   Nev = LDR();
   if(Nev <= 205)
      //delay_ms(100);
      output_low(PIN_C3);
      //delay_ms(100);
   else if(Nev > 205)
void Reverse()
   restart_wdt();
   float MA;
   MA = 0;
   output_high(PIN_C4); // reverse ON
   MA = LDR();
    if(MA <= 185)
      output_low(PIN_C4);
    else if(MA > 185)
   setup_adc_ports(SAN0);
   //set_tris_c(0x00);
   //set_tris_b(0x00);
   output_low(PIN_C0);  // Position
   output_low(PIN_C1);  // Stop
   output_low(PIN_C2);  // DI
   output_low(PIN_C3);  // Fog
   output_low(PIN_C4);  // Reverse
   output_low(PIN_A1);  // Green sign
   output_low(PIN_A5);  // Red sign
   //while(true)
      //restart_wdt();
      //delay_ms(500);
      presenca();
      STOP();
      DI();
      Fog();
      Reverse();
      //delay_ms(500);
PostPosted: Wed May 03, 2023 7:42 pm     Reply with quote
The 16F18326 data sheet says in the WDT section:
After a Reset, the default time-out period is two seconds.
You have several 5 second delays. The WDT is going to reset after 2 secs.
I'd advise you to disable WDT during development of your program.
Change the fuse to NOWDT.
