AKA TENDO
| receiving data on pic16F from an accelerometer MPU6050 |
Posted: Wed Jan 25, 2023 4:37 pm |
Hi ! I'm currently working on a project on a pic16f877A and i must have data from an accelerometer mpu6050 on 3 axes (X,Y,Z). I'm receiving data in i2c burst mode but for some reasons, my data are not accurate and sometimes my i2c bus receive same numbers on 2 axes. I post my code here, pls don't focus on "write_slave()" this is for communication with my friend but this is not the problem I'm posting for ^^:
#include <16F877A.h>
#use i2c(MASTER, sda=PIN_C4, scl=PIN_C3)
#define READ_ADDR 0xD1
#define WRITE_ADDR 0xD0
#define REG_GYRO_X1 0X43
#define REG_GYRO_X2 0X44
#define REG_GYRO_Y1 0X45
#define REG_GYRO_Y2 0X46
#define REG_GYRO_Z1 0X47
#define REG_GYRO_Z2 0X48
#define GYRO_CONFIG 0x1B
#define ACCEL_CONFIG 0x1C
#define PWR_MGMT_1 0x6B
#define POWER_MNGMNT 0x6B
#define CONFIG 0x1A
#define SAMPLE_DRATE 0x19
#define INT_ENABLE 0x38
#define FIFO_EN 0x6A
#define FIFO_CONFIG 0x23
#define REG_ACCEL_X1 0x3B
#define REG_ACCEL_X2 0x3C
#define REG_ACCEL_Y1 0x3D
#define REG_ACCEL_Y2 0x3E
#define REG_ACCEL_Z1 0x3F
#define REG_ACCEL_Z2 0x40
#define FIFO_BUFFER 0x74
#define WHO_AM_I 0x75
#define INT_PIN_CFG 0x37
#define INT_STATUS 0x3A
void write_slave(int val)
printf("\n\r 1111 ");
i2c_start();
printf("\n\r 2222 ");
i2c_write(0x10);
printf("\n\r 3333 ");
i2c_write(val);
printf("\n\r 44444 ");
i2c_stop();
// WRITE//
void write_reg(int Reg, int val)
i2c_start();
i2c_write(0xD0);
i2c_write(Reg);
i2c_write(val);
i2c_stop();
// READ//
int read_reg(int Reg)
//unsigned int data = 0;
int buffer;
i2c_start();
i2c_write(0xD0);
i2c_write(Reg);
i2c_start();
i2c_write(0xD1); //start with the address in read mode
buffer = i2c_read(0); // read and store the data in a variable
i2c_stop();
return buffer;
//INIT//
void MPU6050_Init()
write_reg(PWR_MGMT_1, 0x01);
write_reg(CONFIG, 0x00);
delay_ms(10);
write_reg(GYRO_CONFIG, 0x18); // Pourquoi configurer Gyro et pas Accé
delay_ms(10);
write_reg(ACCEL_CONFIG, 0x00); // test 24/11
delay_ms(10);
write_reg(SAMPLE_DRATE, 0x07);
delay_ms(10);
write_reg(INT_ENABLE, 0x01);
delay_ms(10);
write_reg(FIFO_EN, 0x40);
delay_ms(10);
write_reg(FIFO_CONFIG, 0x08);
delay_ms(10);
write_reg(INT_PIN_CFG, 0x10);
delay_ms(10);
//MPU READ//
void Read_Sensor (int8 REG_add)
int MSB1;
int LSB1;
int MSB2;
int LSB2;
int MSB3;
int LSB3;
int16 AxeX;
int16 AxeY;
int16 AxeZ;
float fAxeX, fAxeY, fAxeZ;
i2c_start();
i2c_write(0xD0);
i2c_write(REG_add);
i2c_start();
MSB1 = i2c_read();
LSB1 = i2c_read();
MSB2 = i2c_read();
LSB2 = i2c_read();
MSB3 = i2c_read();
LSB3 = i2c_read(0);
read_reg(INT_STATUS);
AxeX = make16(MSB1, LSB1);
AxeY = make16(MSB2, LSB2);
AxeZ = make16(MSB3, LSB3);
i2c_stop();
fAxeX = (float)AxeX/16384.0;
fAxeY = (float)AxeY/16384.0;
fAxeZ = (float)AxeZ/16384.0;
printf("\n\r axe X: %f",fAxeX);
printf("\n\r axe Y: %f",fAxeY);
printf("\n\r axe Z: %f",fAxeZ);
//Check addr//
/*int check_addr (int reg_addr) //check if the slave's address is right
//read_reg(0xD0,buffer_Receive); //0x75 is the REG: WHO_I_AM
if (buffer_Receive == 0x68)
return (1);
return (0);
void main (void)
int TestRS = 0;
MPU6050_Init();
do
Read_Sensor(FIFO_BUFFER);
write_slave(0x15);
output_d(testRS);
TestRS=TestRS+1;
while(true);
all ideas are welcome, thanks. |
Posted: Wed Jan 25, 2023 4:41 pm |
| are you running a 5 volt PIC and a 3 volt sensor ? |
AKA TENDO
Posted: Wed Jan 25, 2023 4:45 pm |
| They're both on 5V. |
Posted: Wed Jan 25, 2023 5:33 pm |
Try running the I2C port as 'slow' ? I don't use the MPU6050 but it has a maximum speed, 'somewhere' on it's datasheet.
What value are the I2C bus pullup resistors ? They have to be selected on BOTH VDD and speed. |
AKA TENDO
Posted: Thu Jan 26, 2023 2:32 am |
ok thank you i'lln try but i don't have the math.h library, have you got a sure link where i can take it? |
AKA TENDO
Posted: Thu Jan 26, 2023 2:35 am |
| temtronic wrote: | Try running the I2C port as 'slow' ? I don't use the MPU6050 but it has a maximum speed, 'somewhere' on it's datasheet.
i think this part doesn't have an issue, my teacher has the code who works on it ^^' he had put it in front of me and it works. so i think my problem isn't on hardware part. |
Posted: Thu Jan 26, 2023 2:37 am |
| AKA TENDO wrote: | | They're both on 5V. |
Er. The MPU6050, is not a 5v device. 3.46v _max_ rating. If you
have run it off 5v, you have probably killed the chip....
If you are using a board from something like an Arduino, that has a 5v
regulator for the chip, you have the problem of signalling levels. The
Arduino accepts a 2.4v signal as 'high' for it's I2C connection. The PIC
does not. Needs 4v. |
AKA TENDO
Posted: Thu Jan 26, 2023 2:46 am |
| Ttelmah wrote: | | AKA TENDO wrote: | | They're both on 5V. |
I use this sensor :
https://www.hotmcu.com/gy521-mpu6050-3axis-acceleration-gyroscope-6dof-module-p-83.html
and it accepts 5V.
And how could i solve the problem that you are talking about?
Do you mean that i should try to put my i2c in SLOW MODE? |
Posted: Thu Jan 26, 2023 2:58 am |
That is what I guessed. That has a 3.3v regulator, so you won't have
damaged the chip, but the problem is that your PIC I2C peripheral wants
4v for a logic high, so will be intermittent on receiving things.
Try changing the I2C setup and add 'SMBUS' to this. This should turn
the input voltage required down low enough to work.
#use i2c(MASTER, sda=PIN_C4, scl=PIN_C3, SMBUS) |
AKA TENDO
Is normal that the math.h doesn't compile? Did i forget something?
[/img] |
AKA TENDO
Posted: Thu Jan 26, 2023 3:03 am |
| Ttelmah wrote: | That is what I guessed. That has a 3.3v regulator, so you won't have
ok thank you very much i will try later but first i would try the code from pcm prgrammer. if it works i would use it for my project and continue to work on my own code as well.
Can you help me about the math.h library? |
Posted: Thu Jan 26, 2023 3:08 am |
Switch the setup to SMBUS anyway. It needs this setting to work with this
chip. |
AKA TENDO
Posted: Thu Jan 26, 2023 3:17 am |
| Ttelmah wrote: | Switch the setup to SMBUS anyway. It needs this setting to work with this
chip. |
i tried but it doesn't change anything.. |
AKA TENDO
Posted: Thu Jan 26, 2023 4:02 am |
| Anybody has a solution to compile math.h? |
