sifirzero1
Posted: Mon Jan 16, 2023 12:57 am |
temtronic wrote: | Most 'frequency counters' using PICs that I 'Googled' ,
like https://www.best-microcontroller-projects.com/pic-frequency-counter.html
use BOTH Timer0 AND Timer1.
Now if BOTH timers are available, you should be able to modify one of the dozens of frequency counters already on the Internet.
You'll have to edit the code for whatever clock speed you're running and send the result , via RS-232, to a PC terminal program. With an 8 pin PIC, -2 for power gives 6 I/O, -1 for the incoming signal, leaves 5 pins,which means you can't use an LCD module , as they need 6 or 7. You also have limited memory (code space), but it should be possible to run in that PIC.
What is the maximum frequency that you need to read ? |
18khz and 20khz |
Posted: Mon Jan 16, 2023 3:18 am |
It is sometimes quite depressing seeing people wasting so much effort
trying to pack something into a chip, when the functions can be done
much easier in a later chip. The 629 & 675, are quite old chips. They
were replaced by chips like the 12F1840. Now in the UK, the 1840,
costs £1.34, while the 675 is 1.79. The 1840 also has better availability
(currently in stock at all the main wholesalers, while the 675 has a few
weeks back-order).
Now the 1840, has 3* the ROM, 4* the RAM, includes a PWM (which
makes generating a tone totally simple), and includes three timers,
making measuring a frequency much easier. It has several extra
peripherals as well. The capacitor sensing module, the signal modulator,
hardware UART, DAC & MSSP. Also has up to 32MHz operation on the
internal oscillator, and draws less power.
Difference between a 2002 chip and one from ten years later. |
sifirzero1
Posted: Mon Jan 16, 2023 3:25 am |
Current chip is 12f629 or 12f675. I would appreciate if you share more realistic results for the solution. If you have sample frequency measurement codes, can you share them? |
Posted: Mon Jan 16, 2023 3:52 am |
At the moment, you keep asking for things without enough data as to
what you are already doing. You say you have the chip generating a tone,
but without details of how this is generated?. If you are using a timer
to do this (the easiest way), then which timer?. This affects what
resources are available to measure a tone. If it is a timer then the
frequency will be what you are programming on the timer. Pointless
to measure this. |
Joined: 01 Jul 2010 Posts: 9115 Location: Greensville,Ontario
Posted: Mon Jan 16, 2023 8:36 am |
it's cold, overcast day, so I decided to 'google'...
found these..
http://www.ccsinfo.com/forum/viewtopic.php?t=21390
Both send the result via RS232 to a PC for display. You'll have to have some kind of 'serial input' to your PC.....
2nd is in CCS C, from 2004 !! He says it 'works' but has 'problems'. I suspect due to inaccurate timing, though I can't breadboard to test.
So, yes it IS possible to build a frequency counter using that PIC but as Mr. T points out, using a newer PIC is a better choice ! I understand that getting parts may be a challenge, depending on the country and location and English is not everyone's 1st language. heck at 70 I'm still trying to understand it !
Posted: Mon Jan 16, 2023 10:39 am |
Thing is that most methods need two timers. Now it therefore depends
on how he is doing the frequency generation he spoke about.
The chip is perfectly capable of doing one job, but putting together
multiple things runs the risk of running out of resources.... |
sifirzero1
Posted: Tue Jan 17, 2023 2:15 pm |
#include <12F683.h>
#fuses hs,mclr,nowdt
#use delay(clock=20m)
#use rs232(baud=9600,parity=N,xmit=PIN_A0,bits=8,stream=PORT1)
int16 zaman=0,say=0,sayi=0;
#int_timer0
void kes()
set_timer0(255);
zaman++;
#int_timer1
void zam()
set_timer1(34290);
say++;
if(say == 20 )
say=0;
DISABLE_INTERRUPTS(int_timer0);
SETUP_TIMER_0(T0_EXT_H_TO_L | T0_DIV_1);
set_timer0(255);
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8);
set_timer1(34290);
enable_interrupts(int_timer0);
enable_interrupts(int_timer1);
enable_interrupts (global);
while(true)
printf("\rFrekans : %lu \n",zaman);
It measures the frequency once. It may not cause frequency change. can you help me |
Posted: Tue Jan 17, 2023 7:54 pm |
a few comments...
You really need to add comments to the ends of your lines of code.
we don't know WHY you're setting 'timer0 to 255', what '34290' is supposed to mean? How '20' for the variable 'say' was chosen ?
you also should have a 'title comment section', with a brief explanation of what the program is supposed to do, as well as what the 6 I/O pins of the PIC are being used for.
comments don't cost you code space and they'll help others help you !
Yes, we can see both timers are set to interrupt, but we don't know at what rate, could be 22us, 165 ms, 1 hr ?? There are online apps that we can access to quickly confirm/deny that the numbers you've chosen are correct, if we're told the interrupt rate, timer options and clock speed.
I will assume the PIC is operating at the correct speed , as you've got serial data going to a PC.
The one problem I do see is that when Timer1 ISR is 1st executed, it disabled Timer0 interrupt, so from then on Timer0 ISR is never run again.
I'm fairly sure that is NOT what you want to happen. |
sifirzero1
Posted: Tue Jan 17, 2023 9:22 pm |
sifirzero1 wrote: | Code: |
#include <12F683.h>
#int_timer0
void kes() // pulsde kesme yapilacak.
set_timer0(255);
zaman++;
#int_timer1
void zam()
set_timer1(34290);
say++;
if(say == 20 ) // 1saniye kesme suresi
say=0;
set_timer0(255);
set_timer1(34290);
while(true)
Posted: Wed Jan 18, 2023 9:21 am |
OK, I see a couple comments, but not in English.
I understand English as a 2nd language is hard, but since the compiler is in English, it'd be nice if everything was in English as it makes understanding the program a lot easier.
this..
set_timer1(34290);
would be better as
set_timer1(34290); // value to create xxx us ISR
or whatever it's for.....
maybe others can help with better descriptions (comments) |
Posted: Wed Jan 18, 2023 9:51 am |
temtronic,
He wants us to write code for him, to generate a 19 KHz frequency.
His current program doesn't do that. So he wants us to do it for him.
That's his whole problem, not the comments.
He writes what he wants in an obscure way:
Quote: | It measures the frequency once. It may not cause frequency
This means he wants a frequency generator. He then says:
So forget the comments. If you want to write the frequency generator
code for him, go ahead. |
PrinceNai
Posted: Wed Jan 18, 2023 1:15 pm |
PCM programmer, where can I send my offerings? You are a god. |
Posted: Fri Jan 20, 2023 7:34 am |
Hmm.. after finding some 12f683s, I pretty sure those are 'special' and can't be programmed with a PICkit3 if using the internal oscillator...
for some reason the writing on those PICs is a lot smaller than I remember too. |
sifirzero1
Posted: Fri Jan 20, 2023 7:38 am |
What I wanted was to measure the frequency meter using the timer0 input, but no one helped. Doesn't anyone know? |
Posted: Fri Jan 20, 2023 10:04 am |
hmm.. I was under the impression you need a frequency GENERATOR of 19KHz.
So I've spent a lot of time actually getting my PICkit3-R1 to identify and finally program the 12F683 as a 19KHz generator......
What is the maximum frequency you need to measure ?
There are several programs for this, they will use Timer0 and timer1 of course |
