silly question FOR LOOP
bschriek
PostPosted: Mon Dec 12, 2022 2:42 am     Reply with quote
I have some silly questions and hopefully an experts can give me a short answer.
1)
For (i=10; i>=0; --i)
printf("%u",i); // Result is 10,9,8,7,6,5,4,3,2,1 So far so good.
- Why use "i>=0" for expr2 of the FOR LOOP and not "i>0"?
- Sometimes I see "--i" for expr3 of the FOR LOOP and sometimes i--, what's the difference?
2)
printf("%u",i); // Now I want the following results 10,9,8,7,6,5,4,3,2,1,0
// (ofcourse i>=0 doesn't work here, but what will work?)
Is there a simple solution to use the FOR LOOP without additional code?
As I told you before, stupid questions but I'm just curious.
Thanks you in advance,
PostPosted: Mon Dec 12, 2022 6:39 am     Reply with quote
The point about --i versus i--, is that in the first case the decrement is done
_before_ the value is passed. In the second afterwards. This matters when
a value decremented like this is being used in mathematics, but not here.
So:
With i=10;
j=i--;
j receives 10, and i is 9 after the operation.
But:
j=--i;
j receives 9, and again i is 9 afterwards.
In the loop, the test is done on the result of the operation, so it makes
no difference.
Now there is a huge caveat in what you post here. It will not work if 'i' is
not a signed variable. An unsigned number can never go less than 0.
You are printing the variable as an unsigned, while the actual value needs
to be a signed to work.
So:
      signed int i; //Critical
      for (i=10; i>=0; --i)
         printf("%d,",i); // Will print 10,9,8,7,6,5,4,3,2,1,0
I've added a ',' so it prints exactly what you are asking for.
PostPosted: Mon Dec 12, 2022 6:42 am     Reply with quote
ok, I was never taught C but...
..my understanding....
1) When the PIC decrements the variable 'i' from '1', it could become 00 or FF ,depending on when the 'if' statement is executed ( kind of a 'race' condition ? ) and HOW it's done. Actually have to see the assembler. for '0' you could check the ZERO flag after the comparison is done.
2) --i means to subtract from i BEFORE the interior for-loop code is executed, and i-- means subtract AFTER...that stuff is executed. One way you get 1 extra for..loop....well ,pretty sure..
What I am sure of is someone will reply and tell us !
bschriek
PostPosted: Mon Dec 12, 2022 6:58 am     Reply with quote
Dear all,
Hihi, oh it's that simple.
I never thought about using a signed int but you are right. Thanks.
And about --i or i--. I understand there is no difference in case of a FOR LOOP.
Thank you for your clear answer.
Best regards,
