picj1984
| reassign Tx on #use rs232 as general purpose IO? [SOLVED] |
Posted: Tue Apr 17, 2018 1:22 pm |
I'm not using the TX pin on my UART module. Can I reassign that for general IO usage? Right now I'm just trying to do the output_low() function but it's just always staying high.
Joel
Joined: 01 Jul 2010 Posts: 9601 Location: Greensville,Ontario
Posted: Tue Apr 17, 2018 1:47 pm |
yes, you should be able to, but you need to post which PIC and compiler version , so that others can test to confirm .
It could be a simple premade function or you may have to code yourself, that's why compiler version is nice to know. |
picj1984
Posted: Tue Apr 17, 2018 2:28 pm |
| temtronic wrote: | yes, you should be able to, but you need to post which PIC and compiler version , so that others can test to confirm .
oops sorry about that. It's a PIC16F1825 and I'm using PCM Compiler V4.140. |
Posted: Wed Apr 18, 2018 12:41 am |
You have to do a little bit more fiddling. Thing is that for the code to use the hardware UART it has to be told to use _both_ pins. This then leaves the TX pni being driven by the UART. So the key is to turn this off:
//Processor include
//fuses
//clock declaration
#use RS232(UART1, BAUD=9600, ERRORS)
//Standard UART enable on the default hardware pins
//Then
#BIT TXEN=getenv("BIT:TXEN")
//This now gives us access to the UART TXEN bit
TXEN=FALSE; //Turn off the UART transmit
//You can now read and write the TX pin normally
As you can see it is very easy. All you do is enable the UART normally, and then turn off the transmit 'side' of the hardware. |
picj1984
Posted: Fri May 04, 2018 3:41 pm |
| Ttelmah wrote: | You have to do a little bit more fiddling. Thing is that for the code to use the hardware UART it has to be told to use _both_ pins. This then leaves the TX pni being driven by the UART. So the key is to turn this off:
//Processor include
//fuses
//clock declaration
//Then
Just realized I never came back to say "thanks!" this is working for me now  |
gjs_rsdi
| rs232 on/off |
Posted: Mon Nov 28, 2022 5:09 am |
I know this topic is very old but I want to thank you Ttelmah for explaining how to enable/disable the TX pin
Best wishes
Joe |
Posted: Mon Nov 28, 2022 8:04 am |
Well done that you found this.
99% of things like this have been answered here, which is why using the
search is such a powerful tool.
For some answers things have later 'evolved'. So (for example) there are
threads a few years ago on how to manually set ANSEL, which have now
been made redundant with CCS adding this to set_adc_ports). However
most of the answers still apply as they did when originally made.
Glad you have it doing what you want. |
gjs_rsdi
Posted: Mon Nov 28, 2022 9:21 am |
Definitely the forum search is one of the best tools available.
You spend some time, but you save much much more
Best wishes
Joe |
