Rigolon
CCS Compiling problems with i2c |
Posted: Fri Nov 11, 2022 11:19 am |
Hi guys, first post here.
I tried to find a solution, but I haven't got far.
I have a project that uses PIC18F452 and PCF8563 for RTC.
The thing is I made some small changes and when I tried to run my uC froze. I discovered the problem was with the RTC_init() function. After commenting this function my program runs normally (without RTC).
#ifndef __PCF8563_C__
#define __PCF8563_C__
#ifndef PIN_RTC_SDA
#define PIN_RTC_SDA PIN_C4
#define PIN_RTC_SCL PIN_c3
#use i2c(MASTER, sda=PIN_RTC_SDA, scl=PIN_RTC_SCL, stream=STREAM_PCF8563)
typedef struct
unsigned int8 year; //years since 2000
unsigned int8 month; //1..12
unsigned int8 day; //1..31
unsigned int8 dow; //0..6
unsigned int8 hour; //0..23
unsigned int8 min; //0..59
unsigned int8 sec; //0..59
//int1 valid;
} TIME_STRUCT;
#define PCF8563_I2C_ADDR 0xA2
// registers //
#define PCF8563_CONTROL1 0x00 //control/status 1
#define PCF8563_CONTROL2 0x01 //control/status 2
#define PCF8563_CLKOUT 0x0D //CLKOUT control
#define PCF8563_TCONTROL 0x0E //timer control
#define PCF8563_TIMER 0x0F //timer countdown value
#define PCF8563_SECONDS 0x02 //0..59 BCD (bit7 is VL)
#define PCF8563_MINUTES 0x03 //0..59 BCD
#define PCF8563_HOURS 0x04 //0..23 bcd
#define PCF8563_DAYS 0x05 //1..31 bcd
#define PCF8563_WEEKDAY 0x06 //0..6
#define PCF8563_MONTHS 0x07 //0..12 (bit7 is Century, leave clear for 20xx)
#define PCF8563_YEARS 0x08 //0..99 bcd
#define PCF8563_MINUTE_ALARM 0x09 //0..59 BCD
#define PCF8563_HOUR_ALARM 0x0A //0..23 BCD
#define PCF8563_DAY_ALARM 0x0B //0..31 BCD
#define PCF8563_WEEKDAY_ALARM 0x0C //0..6
static unsigned int8 _get_bcd(unsigned int8 data)
unsigned int8 nibh;
unsigned int8 nibl;
nibh=data/10;
nibl=data-(nibh*10);
return((nibh<<4)|nibl);
static unsigned int8 _rm_bcd(unsigned int8 data)
unsigned int8 i;
i=data;
data=(i>>4)*10;
data=data+(i&0x0F);
return data;
void rtc_init(void)
i2c_start(STREAM_PCF8563);
i2c_write(STREAM_PCF8563, PCF8563_I2C_ADDR);
i2c_write(STREAM_PCF8563, PCF8563_CONTROL1);
i2c_write(STREAM_PCF8563, 0x00);
i2c_stop(STREAM_PCF8563);
void rtc_set_datetime(TIME_STRUCT *pTs)
TIME_STRUCT ts;
memcpy(&ts, pTs, sizeof(ts));
i2c_write(STREAM_PCF8563, PCF8563_SECONDS);
i2c_write(STREAM_PCF8563, _get_bcd(ts.sec));
i2c_write(STREAM_PCF8563, _get_bcd(ts.min));
i2c_write(STREAM_PCF8563, _get_bcd(ts.hour));
i2c_write(STREAM_PCF8563, _get_bcd(ts.day));
i2c_write(STREAM_PCF8563, _get_bcd(ts.dow));
i2c_write(STREAM_PCF8563, _get_bcd(ts.month));
i2c_write(STREAM_PCF8563, _get_bcd(ts.year));
void rtc_get_datetime(TIME_STRUCT *pTs)
TIME_STRUCT ts;
unsigned int8 val;
i2c_start(STREAM_PCF8563, 2);
i2c_write(STREAM_PCF8563, PCF8563_I2C_ADDR | 1);
val = i2c_read(STREAM_PCF8563, 1);
//ts.valid = !bit_test(val, 7);
ts.sec = _rm_bcd(val & 0x7F);
ts.min = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x7F);
ts.hour = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x3F);
ts.day = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x3F);
ts.dow = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x07);
ts.month = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x1F);
ts.year = _rm_bcd(i2c_read(STREAM_PCF8563, 0));
memcpy(pTs, &ts, sizeof(ts));
#endif |
But nothing I did fixed the problem. Then I tried the following:
* I programmed an old version of the HEX on my uC and it ran perfectly;
* I copied the project of this old version, and without changing any code, I just compiled and used the new HEX file to program the uC, and again it got stuck at the same place;
* I tried the same with 2 other projects I know it's working and uses the same PIC and code for the PCF8563. Both projects when I compile/build a new HEX file the same problem happens, but with the old HEX is running perfectly.
I haven't put the code here, since it looks like the compiler is the problem.
But if needed I can post it here.
Edit:
Important to say that the old versions were compiled with and old version of CCS: 5.015.
The version I'm using now is 5.105
Could be the ccs version or does anyone know why this could be happening? |
Posted: Fri Nov 11, 2022 11:57 am |
Try specifying a speed in the I2C setup.
The default has changed on later compilers.
This should really always be specified, rather than relying on defaults. |
Rigolon
Posted: Fri Nov 11, 2022 12:46 pm |
I've tried specifying a speed and it didn't work.
But after researching for a while I found a solution.
My setup configurations have the following:
I commented it and now it's all working.
Not sure what is the problem and why before it wasn't a problem |
Posted: Fri Nov 11, 2022 5:18 pm |
There is only one MSSP module in the 18F452 and it runs both i2c and SPI.
The compiler configures the i2c in the startup code in main(). Example:
..... void main()
0026: CLRF TBLPTRU
0028: BCF RCON.IPEN
002A: BSF TRISC.-
002C: BSF TRISC.-
002E: MOVLW 09
0030: MOVWF SSPADD
0032: MOVLW 28
0034: MOVWF SSPCON1
0036: BSF SSPSTAT.SMP
0038: BCF SSPSTAT.CKE
003A: BSF ADCON1.PCFG0
003C: BSF ADCON1.PCFG1
003E: BSF ADCON1.PCFG2
0040: BCF ADCON1.PCFG3
But setup_spi(FALSE) comes after the startup code shown above.
So it will disable the MSSP module. Example:
Code: | ...... {
...... setup_spi(FALSE);
0042: CLRF SSPCON1
Posted: Sat Nov 12, 2022 8:56 am |
Makes total sense.
As PCM says, the MSSP module handles both the I2C, and the SPI.
So you were turning the module off after it was setup. :(
Worth 'avoiding' mixing the two 'types' of setup.
Historically, the early compilers had SPI setup with setup_SPI. Now it
has #USE SPI, just as it does for I2C. So you are mixing an old format
SPI setup. |
Rigolon
Posted: Mon Nov 14, 2022 5:37 am |
Oh now I understand
Thank you both. |
