How to declare a bit from a variable....
E_Blue
PostPosted: Wed Oct 12, 2022 9:18 pm     Reply with quote
How to declare a bit from a variable that is inside of an Structure?
Example
struct Alarm_St1{
   unsigned int8 ratioOne;
   unsigned int8 ratioZero;
   int1 ratioOV;
   int1 NewPacketReady;
   int1 ReadBits;
   unsigned int8 TimerPacket;
   unsigned int8 BitCount;
   unsigned int32 LastPacket;
   unsigned int8 LastData;
   unsigned int8 LastCRC;
   unsigned int8 CRC_result;
   unsigned int8 CurrentPacket[6];
   unsigned int8 CurrentData;
}Alarm;
#bit TamperX = DSC.CurrentData.0
unsigned int8 Dummy;
#bit DummyZero = Dummy.0
DummyZero is ok but TamperX returns the following error
A numeric expression must appear here
I also tried adding some parentheses or brackets with similar results.
I want to able to do something like
if(TamperX)
   Alarm();
   TamperX=FALSE;
Electric Blue
PostPosted: Thu Oct 13, 2022 1:56 am     Reply with quote
Use a union and if you want a short name, a define. So:
union bits {
   unsigned int8 whole;
   int1 bits[8];
struct Alarm_St1{
   union bits CurrentData;
   //comment here. You will find the compiler tends to prefer
   //int1 declarations are done after other types.
   int1 ratioOV;
   int1 ReadBits;
}Alarm;
//You now have access to the bits in currentdata, as bits[0]..7
//give this a short name if required
#define TamperX  Alarm.CurrentData.bits[0]
   //you can now test as a simple variable.
   if (TamperX)
      //do what you want
      //TODO: User Code
Note that since the location is fixed, the compiler optimises this totally, so
the test compiles as:
....................    if (TamperX)
0001E:  BTFSS  15.0
Where 'Alarm' here is stored in 0x4..0x16.
Note that what was CurrentData, is now CurrentData.whole
E_Blue
PostPosted: Thu Oct 13, 2022 11:03 am     Reply with quote
So, that way, is not needed to call bit_test function?
if(bit_test(TamperX))
Also to compare Alarm.CurrentData with another 8 bit variable or value I must use
if(Alarm.CurrentData.whole==A5)
Electric Blue
PostPosted: Thu Oct 13, 2022 11:49 am     Reply with quote
You were trying to declare a bit, so not using a bit_test.
Yes on using .whole.
If you are prepared to use bit_test, then you can just leave the data
declared as a byte not a union, and use bit_test on this.
E_Blue
PostPosted: Thu Oct 13, 2022 1:27 pm     Reply with quote
I got this error on CurrendData definition
Expecting a {
My compiler version is 5.091
Electric Blue
PostPosted: Thu Oct 13, 2022 1:47 pm     Reply with quote
Need to see the code.....
E_Blue
PostPosted: Thu Oct 13, 2022 1:57 pm     Reply with quote
The code is the same of Ttelmah made.
The whole code has around 22K lines and I'm not allowed to show it.
Electric Blue
PostPosted: Fri Oct 14, 2022 1:32 am     Reply with quote
The code I posted, with a suitable chip header, compiles as runs. It was
cut and pasted from my test.
Here you have posted CurrendData, not CurrentData. Are you sure you
haven't got some similar typo?.
E_Blue
PostPosted: Fri Oct 14, 2022 10:36 am     Reply with quote
Yes, there's not any typo in the code.
I just decided to declare the variables outside the struct.
unsigned int8 CurrentData,LastData;
#bit Alarm_Tamper = CurrentData.0
#bit Alarm_Rest = CurrentData.1
#bit Alarm_BatErr = CurrentData.3
#bit Alarm_SenOpen = CurrentData.5
#bit Alarm_HearBit = CurrentData.6
#bit Alarm_OldTamper = LastData.0
#bit Alarm_OldRest = LastData.1
#bit Alarm_OldBatErr = LastData.3
#bit Alarm_OldSenOpen = LastData.5
#bit Alarm_OldHeartBit = LastData.6
Electric Blue
