Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Bootloaded firmware has missing instructions at ISR [Solved]
E_Blue
PostPosted: Thu Aug 11, 2022 3:23 pm     Reply with quote
I created an USB bootloader for a PIC18F67J50 and it works ok but a couple of instructions are missing on the compilation of the bootloaded program and seems to affect the USB port of the main (bootloaded) program.
Here a couple of pictures to compare the same program compiled to start at 0x0000 and the bootloaded version that start at 0x3000.
I'm using this to redirect the ISR
#define LOADER_END 0x2FFF
#int_global
void isr()
   jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
The ISR vectors created on the bootloader firmware seems to be OK.
Why the ISR vector is so different between the normal 0x0000 and the 0x3000 bootloaded version of the same firmware?
What I'm doing wrong or missing?
Electric Blue
PostPosted: Thu Aug 11, 2022 10:39 pm     Reply with quote
Post the build line used for the bootloaded program.
It is this that sets up how the ISR is created in this program, not the
bootloader.
The bytes at 4 though do nothing. They are just unused garbage. The
interrupts jump to address 8 or 18 on a PIC18. Not 4.
0000 boot vector
0008 high priority/default interrupt
0018 low priority interrupt if priorities are enabled
What is wrong with the USB?. How are your fuses/clock set in the bootloader
and main program?.
E_Blue
PostPosted: Fri Aug 12, 2022 7:07 am     Reply with quote
Are you talking about this?
#include<18F67J50.h>
#fuses none
#define BOOTLOADER_AT_START 0x3000
#include <bootloader.h>
Fuses in the USB bootloader are this.
#include <18F67J50.h>
#fuses INTRC_PLL,PLL2,NOCPUDIV,NOIESO,NOFCMEN,STVREN,CCP2E7,NOWDT,WDT2048,PROTECT //WDT8Seg. No crystal
#use delay(clock=48M)
#use fast_io(ALL)
#define _BOOTLOADER
#define MaxRom 65532
The USB starts ok and start to be every second more "clumsy" and slow until the desktop app get halted.
Electric Blue
PostPosted: Fri Aug 12, 2022 9:56 am     Reply with quote
This part:
#fuses none
#use delay(clock=48M) //must have this
Compiled code always needs a clock statement. Otherwise any delays in
the code will/may have the wrong values coded in them.
This may be what is making the USB code hiccup. The delays may be
excessive.
E_Blue
PostPosted: Fri Aug 12, 2022 10:31 am     Reply with quote
It works! Thank you a lot! 🙏
You just saved me.
Electric Blue
PostPosted: Fri Aug 12, 2022 10:56 am     Reply with quote
That makes total sense. I'd have to compile and test to see what the
default clock value is if you don't specify. Either too slow (so the delays
are shorter than needed), or too fast so delays are longer.
Definitely a 'FYI' one!...
Glad it worked. Very Happy
PostPosted: Sat Aug 13, 2022 6:08 am     Reply with quote
I thought I'd test and see what the compiler does without a clock statement.
I'm actually amazed it does compile. Everything I tried had it complaining,
unless the clock was specified.
E_Blue
PostPosted: Mon Sep 12, 2022 8:09 pm     Reply with quote
That's not all, the compiled code without clock definition runs ok the UART at 115200 as expected, but not the USB module. I don't know how the UART library solve it and the USB library don't.
Electric Blue
PostPosted: Tue Sep 13, 2022 3:36 am     Reply with quote
Your code must be getting a clock statement from somewhere. UART setup
calls all fail if they don't have a clock statement.
Possibly getting it somewhere after the USB library is loaded....
