Gabriel
| loading Txt File to EEPROM |
Posted: Mon Jul 25, 2022 10:11 am |
Hi guys,
anyone have a method of pre-loading into EEPROM a file with data that will be later read by the program as a structure?
The data will be something like:
Phone number
serial number
1 config byte
1 flag byte
ive got close to 100 of these "entries". on the txt
i will make the data entry be a power of 2 for easier "fit".
i just dont want to manually type it all in. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Mon Jul 25, 2022 10:38 am |
Are you talking about the internal EEPROM or an external chip?
If the former, I can't think of any that would hold 100 entries like this.
However if it is the former, look in the programming specification for
the chip. You can then use #ROM to store data at the address for
programming (getenv can also fill this in for you).
If the latter, then you would either have to use an external programmer,
or add a program to automatically write the data from perhaps serial. |
benoitstjean
Joined: 30 Oct 2007 Posts: 595 Location: Ottawa, Ontario, Canada
Posted: Tue Jul 26, 2022 5:37 am |
The second option - through serial - is what I do using an FTDI USB to serial converter.
It's as simple as hooking-it up to the PIC's serial port then you can use a program like Tera Term to upload the file or write your own program on your PC.
I use Tera Term to upload firmware but I also wrote my own Windows app to upload files stored on my device's SD card, over FTDI, to my PC (reverse of what you do but it's simple the other way around).
If you have an SD card adapter on your device with the proper SD driver, then you could go that way as well reading data off the SD card.
There are many ways to do this, it's just a matter of time, tools and money.
Good luck.
Ben |
Posted: Thu Jul 28, 2022 12:47 am |
It's worth perhaps just saying that a bit of 'thought' in the layout of the file
can simplify the coding, and improve the likelihood of it working reliably.
So (for instance), having the actual main elements split by a LF is good,
but it is worth considering if the sub components can be split by perhaps
a comma instead. So:
Phone number, serial number, nnn, nnn <LF>
Makes it easy to write the code to be confident where a new element starts
(at the LF), and to separate the parts of this (with the commas).
Both easy for human readability, and computer scanning.
I did a massive database transfer some years ago, and had the old system
output the data into a huge text stream like this, then the new system just
read this, entered it and indexed it into the new database. Took a few days
to transfer over 80000 records, some with thousands of characters, but the
impressive thing was that everything ended up in the correct places, and
nothing was lost. |
