Using CT For Measuring AC Current With 16F886
mcmsat
PostPosted: Sat Jul 09, 2022 1:36 am     Reply with quote
First of all I apologize for posting this topic in "Code Library". I noticed it lately and deleted it and bringing it here.
Please I was fiddling with a Current transformer to measure RMS Current. I used Arduino code without a driver header file. It is working in Arduino platform. But as I wanted to convert the code to CCS C platform I became confused in some areas, especially on:
int16_t GetpeakTopeak() {
  int16_t ctValueHigh = 0;
  int16_t ctValueLow = ADC_RESOLUTION;
  for (uint8_t i = 0; i < 40; i++) {
    if (analogRead(CTmonitor) > ctValueHigh)
      ctValueHigh = analogRead(CTmonitor);
    if (analogRead(CTmonitor) < ctValueLow)
      ctValueLow = analogRead(CTmonitor);
    delayMicroseconds(500);
//    Serial.print("High : ");  Serial.print(ctValueHigh);
//    Serial.print('\t');
//    Serial.print("Low : ");  Serial.println(ctValueLow);
  return (ctValueHigh - ctValueLow);
The above part of the code is entirely out of "setup" and "loop". As a low level apprentice in CCS C, I am confused as how to place it here. I believe this is the reason it fail to work for me in CCS C platform. Please Can someone correct me where i make mistakes in the conversion.
#include <16F886.h>
#device ADC = 10
#fuses INTRC_IO,NOWDT,MCLR,NOPROTECT
#use delay(clock = 8000000)
#use rs232(baud = 9600,xmit=PIN_C6,DISABLE_INTS,ERRORS)
#include <Flex_LCD2004.c>
#define ADC_RESOLUTION    1024
float avgResult=0;
float currentInmA=0;
long CTmonitor;
void init()
  setup_adc_ports( sAN0 |sAN1 | VSS_VDD);// Select Analog Inputs
  set_adc_channel(0); //Select AN0 as ADC Input for CTmonitor
  int16 GetpeakTopeak() {
  int16 ctValueHigh = 0;
  int16 ctValueLow = ADC_RESOLUTION;
  for (int i = 0; i < 40; i++) {
    if (CTmonitor > ctValueHigh)
      ctValueHigh = CTmonitor;
    if (CTmonitor < ctValueLow)
      ctValueLow = CTmonitor;
for(int i=0;i<10;i++){
  avgResult += GetpeakTopeak();
  avgResult = avgResult/10.00;
//  currentInmA = 0.0045 * avgResult;
  currentInmA = 0.053 * avgResult;
  avgResult = 0;
  init();                           // Configure peripherals/hardware
  lcd_init();                    // Initialize LCD module
  lcd_gotoxy(1,1);   //colum 1 row 1
  lcd_putc("CURRENT TEST");
  delay_ms(1);            //Wait 1 ms
  CTmonitor = read_adc(); //Read AN3 and store in MS2
   lcd_gotoxy(5,2);  // colum5 row 2
   printf(lcd_putc,"%3.1g ",currentInmA);
 printf("CURRENT = %3.1g   \n\r",currentInmA);
The original Arduino code is this:
#include "Arduino.h"
#include "LiquidCrystalWired.h"
#define LCD_ADDRESS (0x7c >> 1)
#define ROW_COUNT   2
#define COL_COUNT   16
#define CTmonitor A1
unsigned long previousMillis = 0;// will store last time LCD was updated
const long interval = 1000;// interval at which to refresh (milliseconds)
LiquidCrystalWired lcd = LiquidCrystalWired(
        ROW_COUNT, COL_COUNT, FONT_SIZE_5x8, BITMODE_8_BIT);
float avgResult=0;
void setup() {
  // put your setup code here, to run once:
    Serial.begin(115200);
    lcd.begin(LCD_ADDRESS, &Wire);
    lcd.turnOn();
void loop() {
  unsigned long currentMillis = millis();
//  Serial.println(currentInmA);
  avgResult = 0;
     if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
//111111111111111111111111111111111111111111111111111111111
  lcd.setCursorPosition(0, 0);
  lcd.print("L1:");
  lcd.setCursorPosition(0, 3);
  lcd.print(currentInmA,2);
if(currentInmA >= 100)
  lcd.setCursorPosition(0, 9);
  lcd.print("A      ");
//*******************************100
if(currentInmA > 10 && currentInmA < 100)
  lcd.setCursorPosition(0, 8);
  lcd.print("A       ");
if(currentInmA < 10)
  lcd.setCursorPosition(0, 7);
  lcd.print("A        ");
            Serial.print(" The Current RMS value is: ");
            Serial.print(currentInmA,2);
            Serial.println(" V ");
All is well even in the well!
PrinceNai
PostPosted: Sat Jul 09, 2022 7:13 am     Reply with quote
There are some problems with the way you translated it. For example, you wrote:
  avgResult = 0;
Code after return never gets executed. This part
  avgResult = 0;
is in the main loop of the original code. Second, one of your delays is half a second long and you are executing that 40 times. Third, in the original code ADC channel gets read in GetpeakTopeak() function, which your code doesn't do, you read it only once.
I confess that it is unclear to me why ADC channel is read so many times, but you said it works in Arduino so i guess it must be so. I took the liberty to rearrange your code a bit. It is not tested.
#include <16F886.h>
#device ADC = 10
#define ADC_RESOLUTION    1024   // max. ADC output
float avgResult=0;
long CTmonitor;               // in Arduino this is a pin or analog channel definition
void init()
// function to read ADC channell 0
   int16 ctValueHigh = 0;               // strange, 0 is high and 1024 is low
   int16 Analog_Result = 0;            //variable to store analog reads
   set_adc_channel(0);                  // probably not even needed, as the ADC channell was already set
      Analog_Result = read_adc();         // read ADC every time
      if (Analog_Result > ctValueHigh)
         ctValueHigh = Analog_Result;
      if (Analog_Result < ctValueLow)
         ctValueLow = Analog_Result;
//      delay_ms(500);                  // you wait more than 20s here!!!
      delay_us(500);
   return (ctValueHigh - ctValueLow);      // retutn value that was somehow averaged
//  CTmonitor = read_adc(); //Read AN3 and store in MS2.
  while(TRUE){
   for(int i=0;i<10;i++){               // you are reading ADC 400x!!!
     avgResult = 0;
PrinceNai
PostPosted: Sat Jul 09, 2022 9:51 am     Reply with quote
A suggestion. Get rid of the floats. By declaring float avgResult=0 as unsigned int16 the compiled code (without LCD parts) is hugely smaller. With float ROM 12%, RAM 9%, with int16 ROM 5%, RAM 7%. Understand that when reading ADC (or anything else inside a PIC) you are reading, writing and dealing with discrete numbers, in this case numbers from 0 - 1023. Even if you add them together 10 times, they still nicely fit into a 16 bit integer. So for all the mathematics with your displayed resolution floats are not needed.
It should work with while true() like this:
  while(TRUE){
   for(int i=0;i<8;i++){               // you are reading ADC 400x!!!
     avgResult = avgResult/8;
//      avgResult = avgResult >> 3;
      currentInmA = 0.053 * (float)avgResult;
      avgResult = 0;
//   lcd_gotoxy(5,2);  // colum5 row 2
//   printf(lcd_putc,"%3.1g ",currentInmA);
//   printf("CURRENT = %3.1g   \n\r",currentInmA);
Note that I changed i to 8, because it translates to only 6 RRF instructions in the final code (division by 8 and shifting produce exactly the same code) and is again faster than division by ten. Old hands here will tell if my casting is OK. It would also be nice to know what kind of signal you are sampling. The rate of change. GetpeakTopeak() function takes 20+ ms to return a result, then you do it 10 times before displaying the end result. So 200+ ms for one result plus 500ms waiting... If the signal change rate isn't very, very slow I have much doubt in the end result. If it's a 50 or 60Hz signal, the whole approach is wrong. But than again, I might have misread the code or the philosophy behind it. You are measuring AC signal, otherwise peak to peak has no meaning. With AC phase comes into play, but that doesn't matter in this case. But if I remember my lessons from more than 20 years ago, Nyquist and Shannon proved that if you want to reconstruct your signal, a sampling rate of at least twice the frequency is needed. Per period, of course.
mcmsat
PostPosted: Sat Jul 09, 2022 1:12 pm     Reply with quote
I am sorry for my late reply. It was a natural factor. I thank the contributor to my questions. let me check it out now
mcmsat
PostPosted: Sat Jul 09, 2022 2:00 pm     Reply with quote
@ PrinceNai, I beg you to help me translate this code the way it should be so that I will study it as part of my lessons. everything goes to Arduino but my fun started with CCS C. Though not as a professional. I do some small things in my garden as a hobby.
This is the original Arduino that I have compiled in my Arduino IDE and it is working on my Uno R3. My curiosity is how can I make it work on this 16F886 I have it's board laying around.
float avgResult=0;
void setup() {
void loop() {
  avgResult = 0;
Please any one who can translate it here for me
PrinceNai
PostPosted: Sat Jul 09, 2022 5:54 pm     Reply with quote
Some three posts back there is a complete code. That compiles without any problem.
mcmsat
PostPosted: Sat Jul 09, 2022 11:36 pm     Reply with quote
@PrinceNai, the code is working now! So much thanks! I am so much happy for this!
Now, I have to study the code to see my mistakes in case for another translation. Thanks Again!
The Code works exactly like this:
#include <16F886.h>
#device ADC = 10
float avgResult=0;
void init()
      delay_us(500);
  while(TRUE){
     avgResult = 0;
You later said this:
  while(TRUE){
      avgResult = 0;
As part of learning I will still do this to see something for myself.
PrinceNai
PostPosted: Sun Jul 10, 2022 8:33 am     Reply with quote
I'm glad it works. I suggested division by 8 because it is slightly faster. But the biggest difference is defining avgResult as unsigned int 16. That way you always manipulate only two bytes instead of four (float variable takes four bytes).
mcmsat
PostPosted: Sun Jul 10, 2022 9:24 am     Reply with quote
I thank you for your help PrinceNai. You are such a good concerning my request. I have refined some definitions and adapted it for ZMPT101B AC voltage sensor and it worked like magic. It's better for me than Emonlib in Arduino. I control. I don't know if it can be used with ADS1115 unlike Emonlib in Arduino in which ADC pin is static in the header file itself. I will try the ADS1115 as I have 2pcs of the module.
Thanks so much.
PostPosted: Mon Jul 11, 2022 1:55 am     Reply with quote
Well done.
Change the title of the thread to include (solved), if you are happy. Very Happy
PrinceNai
PostPosted: Mon Jul 11, 2022 9:46 am     Reply with quote
I have to correct myself when I said the end result won't be good. Went through the code again and for a 50Hz signal it makes perfect sense. GetpeakTopeak() function scans the analog input for exactly one period (40 x 500us equals 20ms, which is one whole period at 50Hz) and finds out the difference between highest and lowest sample. Then this difference is averaged from 10 results and converted to current .
mcmsat
Solved
PostPosted: Mon Jul 11, 2022 2:47 pm     Reply with quote
I thank PrinceNai again.
PostPosted: Tue Jul 12, 2022 12:19 am     Reply with quote
There are a couple of tweaks/comments.
First on the PIC, you should not use ADC_CLOCK_INTERNAL above 1MHz
CPU clock. Doing so results in poor ADC accuracy. You should instead be
using the master oscillator divided to give the correct sample time. The
datasheet has a table of the recommended divisions for different master
clock rates.
The second thing is that the timing of the sampling is going to be slightly
slow. The ADC takes time to read, and the loop itself takes time, so as
currently written that sample loop does not take 20mSec, instead it is
sampling for more like 22mSec. This will potentially give slight errors in
the result.
So. Change the ADC to use a fixed divisor, and then work out how long
the ADC readings will take. Then subtract this (and a few uSec more for
the loop), from the delays for the loop.
This should improve the results slightly.
mcmsat
PostPosted: Tue Jul 12, 2022 12:28 am     Reply with quote
clock rates.
the result.
Thanks Ttelmah for the advice. I am doing every thing I could to learn pic in CCS C.
