12F675 software UART
Goto page Previous  1, 2
PrinceNai
PostPosted: Fri Jun 10, 2022 10:59 am     Reply with quote
I took the liberty to simplify your code a bit, namely testing the u_off part. It executes every time '1' is received, so you can handle that directly there when you get that '1'.
   int32 loop_usb = 0;
//   char  u_off = 10; ?
   while(true)
      if (command != 0)
//Only execute the outputs if a new command arrives. Is this working? Do you come here? toggle a2 here to test if you receive commands.
         if(command == '0')
            output_high(PIN_A0);      // is this part working?
         else if(command == '1')
// I'd    hook a diode here and turn it on and off to be sure I ever come here. For testing purposes PIN_A2   is used
            output_toggle(PIN_A2);      // change the state of the diode every time you receive an "1". Debugging purpose only, to see if you even come here.
//            u_off = 0;               // not needed any more, you can do it all here if you have command "1"
            if(loop_usb == 65535)
//               output_high(PIN_A2);
               loop_usb = 0;
            else if(loop_usb == 131070)
//               output_low(PIN_A2);
               loop_usb = 0;
         command = 0;               // reset for new command
PrinceNai
PostPosted: Fri Jun 10, 2022 11:29 am     Reply with quote
The idea is to "see" how far down the tests you get and where it stops (if it does). Start with the leftmost "if" and go down the line with toggling the diode.
vtrx
PostPosted: Fri Jun 10, 2022 3:44 pm     Reply with quote
This is the whole code.
#include <12F683.h>
//#fuses INTRC_IO,NOWDT,NOBROWNOUT,NOPROTECT,NOMCLR
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
//#FUSES CPD                    //No EE protection
//#FUSES PROTECT                //Code not protected from reading
#FUSES NOMCLR                     //Master Clear pin enabled
//#FUSES NOPUT                    //No Power Up Timer
//#FUSES NOBROWNOUT               //No brownout reset
#FUSES PUT                         //Power Up Timer
#FUSES BROWNOUT                 //Brownout reset enabled
//#byte OSCTUNE = 0x90
//#use delay(clock=4000000)
//#use rs232(baud=9600, rcv=PIN_A3)
#use delay(clock=8000000)
#use rs232(baud=9600, rcv=PIN_A3, SAMPLE_EARLY)
#use fast_io(a)
char  command=0; //start with command empty
int32 loop_usb=0;
char  u_off;
void resetPorts(void) ;
#INT_RA
void int_ra_isr(void)
 if(input_state(pin_A3)==0)   //it only works with this command.
   command = getc();
   output_low(PIN_A0);
   output_low(PIN_A1);
   output_low(PIN_A2);
   output_low(PIN_A4);
   output_low(PIN_A5);
//   OSCTUNE = 0x01;
 //  setup_oscillator(OSC_4MHZ);
   setup_oscillator(OSC_8MHZ);
   setup_comparator( NC_NC_NC_NC ); // disable comparators
   setup_adc_ports(NO_ANALOGS); // disable analog inputs
   setup_adc(ADC_OFF); // disable A2D
   enable_interrupts(INT_RA3);
   set_tris_a(0b00001000);
   resetPorts();
   u_off = 10;
   while(true)
      if (command!=0)
         if(command=='0')
         if(command=='1')
            output_low(PIN_A0);  //reset = 0
         if(command=='2')
            output_high(PIN_A1);
         if(command=='3')
            output_low(PIN_A1);  //reset = 0
         if(command=='4')
            output_high(PIN_A2);  //USB OK = 1
         if(command=='5')
            output_low(PIN_A2);  //USb OFF = 0
            u_off = 0;
         if(command=='6')
            output_high(PIN_A4);
         if(command=='7')
            output_low(PIN_A4);   //reset = 0
         if(command=='8')      //aviso tempo < 10 sec (duração 1 segundo)buzzer
            output_high(PIN_A5);
            output_low(PIN_A5);
         if(command=='9')  //reset = 0
            output_low(PIN_A5);
         if(command=='s')
           output_high(PIN_A5); //aviso tempo < 10 sec (duração 1 segundo)buzzer
         if(command=='r')  //reset (saidas = 0)
            resetPorts();
         if(command=='f')  //usb off - stand alone
            u_off = 0;
         command=0; //clear the command byte, so output stops till
         //a new command arrives.
//========== while end ==========
      loop_usb++;
  if(u_off == 0)
          output_low(PIN_A2);
          loop_usb = 0;
Everything works, but the u_off variable only works if it is initialized.
PostPosted: Fri Jun 10, 2022 4:15 pm     Reply with quote
OK....
subject line...
1st line of latest program...
#include <12F683.h>
..so now I'm confused....
Jay
vtrx
PostPosted: Fri Jun 10, 2022 4:34 pm     Reply with quote
Sorry for the confusion, I decided to use the cheaper one.
I did some tests here and it worked like this:
//========== while ==========
   //   loop_usb++;
  if(u_off == 0)
     loop_usb++;
          output_low(PIN_A2);
          loop_usb = 0;
PostPosted: Sat Jun 11, 2022 1:16 am     Reply with quote
"the u_off variable only works if it is initialized."
What do you think u_off will contain if it is 'not initialised'?.
Generally RAM contents are _undefined_ on boot. It could contain
anything.
1, 75456, 23567891, etc. etc..
With an int32, could be anything up to 4294967295.
You can never assume a variable 'starts' with a value, unless you either
initialise it, or use #zero_ram.
Add one qualifier to that statement. 'Unless it is declared as static'. A
static variable by default is always initialised to zero, unless you declare
something else.
Page 2 of 2
