i2c_transfer(), i2c restart, i2c stop
GL82
PostPosted: Mon May 30, 2022 8:00 am     Reply with quote
Hi all,
I have some doubts with the new i2c_transfer() function used in the i2c dedicated modules implemented in family K42 PICs.
This i2c_transfer() function excute the complete sequence of an i2c transaction: start, write, read and stop operations.
But, what if we want to do a restart operation? or if we want to do only a write and stop sequence (trying to exit an slave from a hang up state)?
Is it possible to do it?
Thanks in advance,
PostPosted: Tue May 31, 2022 12:15 am     Reply with quote
It does a restart already in a read transaction.
The restart is normally used to turn the bus round after writing the
address. i2c_transfer does this. This is why you have a separate
write count and read count. Between the write transaction and the
read, it does a restart.
The sequence to release a slave is not a write and stop. All that is needed
is to clock the SCL line. Normally you would just turn off the I2C device
and manually clock the SCL line, then re-enable the device. You have to
do this even with the standard MSSP peripheral, otherwise it can get
confused by the absence of ACK/NACk if the device is hung.
GL82
PostPosted: Tue May 31, 2022 1:48 am     Reply with quote
Hi Ttelmah,
Thanks for you reply!
I show you below the transaction required to communicated with a Texas Instrument fuel gauge. As you can see the restart condition (Sr) is not needed between write and read operations, it is needed between two write operations
[img]https://ibb.co/QkPdKQQ[/img]
How can I emulate this with i2c_transfer()?
PostPosted: Tue May 31, 2022 3:17 am     Reply with quote
That is legal. That is a read, not a write. It says 'one byte read'.
That is how a restart for read works.
You send the address (with bit 0 clear), to say this is a write, then send some
data, then send a restart, followed by the address with bit 1 set, and then
read.
That is a standard read command.
The first byte after a start is always a write. It is the address. It is
this that then determines the direction for the bytes that follow.
GL82
PostPosted: Wed Jun 01, 2022 11:48 pm     Reply with quote
Hi again Ttelmah,
I understand what you are saying but I do not find how to implement this with i2c_transfer() function. I have my function written as shown below
int16 readDataBQ(int8 cmd)
    int8 byteMS;
    int8 byteLS;
    i2c_start(BQ);            // Start command when in I2C master mode.
    i2c_write(BQ,0xAA);     //Byte de direccionamiento + bit de escritura (0)
    i2c_write(BQ,cmd);      // Sends a single byte over the I2C interface.
    i2c_start(BQ);             // Restart command when in the I2C master mode.
    i2c_write(BQ,0xAB);     //Byte de direccionamiento + bit lectura (1)
    byteLS = i2c_read(BQ,0); // read data
    i2c_stop(BQ);             // Stop command when in the I2C master mode.
When looking at the the i2c_transfer() function structure
i2c_transfer([stream], address, wData, wCount, [rData], [rCount]);
I do not see how to send the address with bit 0 clear/set depending on write/read operation.
Thanks in advance,
PostPosted: Thu Jun 02, 2022 2:05 am     Reply with quote
You don't have to handle that. Just give it the i2c slave address
(0xAA in your case) and the function and the PIC will handle it.
PostPosted: Thu Jun 02, 2022 4:11 am     Reply with quote
Yes. The point is the transfer command takes the top seven bits of
the address, and automatically set the 8th bottom bit to 1 for the read
transaction, and to 0 for the write transaction.
GL82
PostPosted: Tue Jun 07, 2022 2:48 am     Reply with quote
Thanks both of you.
However I still have not solve the issue
With the following code (the old one)
    int8 byteMS;
    int8 byteLS;
    i2c_write(BQ,cmd);      // cmd=0x02 .single byte over the I2C interface.
I have this frames and the communication is correct
[img]https://ibb.co/2j6dgXF[/img]
But with the new code
i2c_transfer(BQ,0xAA,0x02,1,SoC,1);
I obtain the following frames and the data receive is not correct.
[img]https://ibb.co/1ms3V0W[/img]
As you can see the slave is not doing the ACK and the sent data is not the appropriate.
Any idea about the cause?
PostPosted: Tue Jun 07, 2022 3:04 am     Reply with quote
You're sending 0x02 as the write data. But you're doing it wrong.
Did you read the manual? You need to give i2c_transfer() the address
of a write data array. The array holds the 0x02.
Read the manual.
