kgng97ccs
Stopping and re-starting a timer |
Posted: Sat May 14, 2022 1:46 am |
The PIC18LF46K22 datasheet has this paragraph in Section 12.5.1 (READING AND WRITING TIMER1/3/5 IN ASYNCHRONOUS COUNTER MODE):
"Reading TMRxH or TMRxL while the timer is running from an external asynchronous clock will ensure a valid read (taken care of in hardware). However, the user should keep in mind that reading the 16-bit timer in two 8-bit values itself, poses certain problems, since the timer may overflow between the reads. For writes, it is recommended that the user simply stop the timer and write the desired values. A write contention may occur by writing to the timer registers, while the register is incrementing. This may produce an unpredictable value in the TMRxH:TMRxL register pair."
Questions:
1. How does one stop and re-start Timer1, or for that matter, any other timer, without accessing the register directly and without affecting the other settings of the timer?
2. Is it correct that if we use the get_timer1() function, which returns a 16-bit integer, the above read problem will never happen?
3. Similarly, is it correct that if we use the set_timer1() function to write a value to Timer1, the above write problem will never happen?
Re: Stopping and re-starting a timer |
Posted: Sat May 14, 2022 12:13 pm |
For question #2:
kgng97ccs wrote: |
Look at the code for 18F46K22:
...... setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1 | T1_ENABLE_SOSC);
00022: MOVLW 8F // Set RD16 bit (bit 1)
00024: MOVWF T1CON
00026: CLRF T1GCON
...... temp = get_timer1();
00028: MOVF TMR1L,W
0002A: MOVWF temp
0002C: MOVFF TMR1H,temp+1 |
The method above follows the 18F46K22 data sheet in section:
12.6 Timer1/3/5 16-Bit Read/Write Mode
So yes, this method should safely get the 16-bit value without
risk of rollover between bytes.
The compiler also sets the RD16 bit =1 if the internal oscillator is used
as the Timer1 clock source:
...... setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
00022: MOVLW 07 // Set RD16 bit (bit 1)
00024: MOVWF T1CON
00026: CLRF T1GCON
00028: MOVF TMR1L,W
0002A: MOVWF temp
You should be able to get the answer to your 3rd question just by
following the same method as above. |
Posted: Mon May 16, 2022 12:28 am |
And, on '1', this depends on the timer, and what you actually 'mean'.
For example if you look at Timer3, there is an 'on' bit, but it makes the
comment (for off), "Clears Timer1/3/5 Gate flip-flop". So turning this
'off' (which will stop the timer), also clears this flip-flop. Means you cannot
stop it without this changing.
Timer0, does not have this problem, and this has a T0_OFF setting.
Generally, you don't stop timers. Just reset them, read and write them.
If you want to stop their 'effect', just disable the interrupt from them. |
kgng97ccs
Posted: Wed May 18, 2022 10:10 pm |
Thank you, PCM Programmer, for the link and for directing me to the assembly code. I am not familiar with assembly language but will make an effort to understand the code.
Thank you, Ttelmah, for your advice regarding stopping a timer and for highlighting its effect on the Timer1/3/5 gate flip-flop. I have taken note of that.
If you know of any good resources for learning assembly language relevant to PIC MCU programming, please do let me know. Thank you. |
