18F45K50 Timers
vtrx
18F45K50 Timers
PostPosted: Tue May 10, 2022 5:51 pm     Reply with quote
Could someone show me how to start some Timer to trigger an event every one second, using the settings below?
#include <18F45K50.h>
#use delay(int, clock=48MHz, USB_FULL, act=USB)
PostPosted: Tue May 10, 2022 6:35 pm     Reply with quote
None of those have anything to do with what you describe...
Have a look at the software RTC in the 'code' library. The 'core' of it uses a timer to generate a 1Hz 'clock' that then does 'stuff'.
vtrx
PostPosted: Wed May 11, 2022 8:23 am     Reply with quote
Thank you again.
I used the information in the topic and it worked very well.
https://www.ccsinfo.com/forum/viewtopic.php?t=26177
