		| Author | Message |
		| hmmpic
				| RVREG bit in PCCON1 to be low on some restart? |
				|  Posted: Wed May 04, 2022 2:22 am |   |
				| Any logic reason for the RVREG bit in PCCON1 to be low on some restart of a 18F27Q10 ?
 -The code runs as expected after a reboot, only thing i see is the RVREG bit is low on some clean restarts.
 --From Data sheet.
 RVREG Main LDO Voltage Regulator Reset Flag bit
 1 No LDO or ULP “ready” Reset has occurred; or set to ‘1’ by firmware
 0 LDO or ULP “ready” Reset has occurred (VDDCORE reached its minimum spec)
		| Ttelmah
				|  Posted: Wed May 04, 2022 3:09 am |   |
				| It will be low for most wake up's.
 It has to be set to '1' by your firmware, if you want it to have any real
 meaning.
 If your code uses 'restart_cause', this adds the code to set this bit. So:
  	  | Code: |  	  | ....................    int16 cause;
 ....................    cause=restart_cause();
 00030:  MOVF   STATUS,W
 00032:  ANDLW  60
 00034:  MOVWF  @00
 00036:  SWAPF  @00,W
 00038:  MOVWF  @01
 0003A:  RRCF   @01,F
 0003C:  MOVLW  07
 0003E:  ANDWF  @01,F
 00040:  BTFSC  PCON1.RCM
 00042:  BCF    01.2
 00044:  BTFSS  PCON1.RCM
 00046:  BSF    01.2
 00048:  BTFSS  PCON1.RVREG
 0004A:  BCF    01.3
 0004C:  BTFSC  PCON1.RVREG
 0004E:  BSF    01.3
 00050:  BSF    PCON1.RVREG ;//note this line
 00052:  BCF    PCON1.RCM
 00054:  MOVFF  PCON0,00
 00058:  BTFSS  PCON0.POR
 0005A:  BCF    00.0
 0005C:  BTFSS  00.0
 0005E:  BSF    01.2
 00060:  BTFSS  00.1
 00062:  BSF    01.2
 00064:  MOVLW  3F
 00066:  MOVWF  PCON0
 00068:  CLRWDT
 0006A:  MOVFF  01,cause+1
 0006E:  MOVFF  00,cause
 In the data sheet it says:
  	  | Quote: |  	  | Software should reset the bit to the Inactive state after restart. (Hardware will not reset the bit.)
 The compiler does not do this unless you read restart_cause, since unless
 you are using this the bit is effectively not being used.
 '0' is the normal state.
		| hmmpic
				|  Posted: Fri May 06, 2022 4:00 am |   |
				| Thanks for you post, but forget my first post, i was confused, and maybe this is confusing too, but take a look:-)
 Really try to understand the crazy function restart_cause();
 From CCS:
 #define CONFIG_CORRUPTION 0xB3F.
 How to be the B? It will look like this b1011.
 Run restart_cause(); and then we have
  	  | Code: |  	  | Byte          @1         @0 Bit Pos:  7654|3210 | 7654|3210
  	  | Code: |  	  | @1 b0=STATUS(b5) PD    ->H=Set at power up
 b1=STATUS(b6) TO    ->H=Set at power up
 b2=PCON1 (b0) RCM   ->L=Error Config corrupt
 b3=PCON1 (b2) RVREG ->L=Error LDO/ULP (Must be set H/1 by software)
 4,5,6,7 are 0
 To get the B, PD,TO,RVREG must be 1 and RCM must be 0.
 Look at my star* in the assembler from the CCS function restart_cause(), i have NOT changed anything, only grouped it and comment it.
 If it is wrong please help to clear it out?
  	  | Code: |  	  | .................... int16 restart,tvar; .................... restart=restart_cause();
 #After this STATUS bit PD and TO is b0 and b1 in the high byte of int16 from restart_cause()
 000E4:  MOVF   STATUS,W
 000E6:  ANDLW  60
 000E8:  MOVWF  @00
 000EA:  SWAPF  @00,W
 000EC:  MOVWF  @01
 000EE:  RRCF   @01,F
 000F0:  MOVLW  07
 000F2:  ANDWF  @01,F
 #Why invert the RCM bit? This can be the reason for the cold start showing 0x0Bxx can be an error?
 #It is b2 in the int16 from restart_cause()
 000F4:  BTFSC  PCON1.RCM * From a cold start this bit is 1
 000F6:  BCF    01.2 * clear bit
 000F8:  BTFSS  PCON1.RCM *
 000FA:  BSF    01.2 * set bit
 #look ok set is set and clear is clear. It is b3 in the int16 from restart_cause()
 000FC:  BTFSS  PCON1.RVREG
 000FE:  BCF    01.3
 00100:  BTFSC  PCON1.RVREG
 00102:  BSF    01.3
 00104:  BSF    PCON1.RVREG
 00106:  BCF    PCON1.RCM * Clear the bit for to detect on other/next use of restart_cause, on a reboot/reset
 #PCON0 is now LowByte of the int16 in restart_cause()
 00108:  MOVFF  PCON0,00 * load @0
 #if POR clear BOR
 0010C:  BTFSS  PCON0.POR Test POR_b1 for 0 and then Clear
 0010E:  BCF    00.0 Clear BOR_b0
 #if POR is clear, set PCM
 00110:  BTFSS  00.1 * Test PCON0 bit 1 POR if 0 set RCM
 00112:  BSF    01.2 * Set RCM
 #Preload PCON0 to be ready for next use of restart_cause() on a reboot/reset
 00114:  MOVLW  3F
 00116:  MOVWF  PCON0 0011 1111
 # Return
 00118:  MOVFF  01,restart+1
 0011C:  MOVFF  00,restart
 Confusing?
		| Ttelmah
				|  Posted: Fri May 06, 2022 4:39 am |   |
				| It's history. They attempt to keep the bits in the same locations in the return from
 restart_cause. So they migrate bits to match where they were in older
 chips,and also invert bits that will be one on a normal restart, so you get
 zero for the normal power wake up.
		| hmmpic
				|  Posted: Fri May 06, 2022 6:54 am |   |
				| What i show explain why the RCM is not set (L or 0=Error Config corrupt) This is an error in the way CCS handle it. So Complex to understand.
 #define CONFIG_CORRUPTION 0xB3F. And i get it on cold boot.
 I will ask CCS what they think about the RCM is 0 on boot.
		| Ttelmah
				|  Posted: Sat May 07, 2022 2:11 am |   |
				| The reason for the problem is the data sheet is wrong....
 Read it. They says that RCM being '1' means a reset due to the config
 being wrong has occurred. But they also say that from a cold start the
 bit is '1', which is then saying that an error has occurred!...
 Aargh.
 No wonder CCS had problems....
		| hmmpic
				|  Posted: Sun May 08, 2022 3:07 am |   |
				| Thanks for you hints, and i came up with something like, used so much time one this. Now i just ignore the bit, i find it not reliable. Or error in Microchip documentation, or one more Errata to all the others:-)
 This simple test are not using CCS function, just to have control over what is going on.
 I use a clean program with only minimum to run in hw.
 Cold restart
 PCON1.RCM, bit 0 always set
 reset_cpu() from sw, after cold start show the same.
 Cold restart
 PCON1.RCM, clear bit 0
 reset_cpu() from sw
 now the bit is always cleared.
  	  | Code: |  	  | void RestartTest(){ int8 pc0,pc1,st;
 #byte PCON0 = getenv("SFR:PCON0")
 #byte PCON1 = getenv("SFR:PCON1")
 #byte STATUS = getenv("SFR:STATUS")
 pc0=PCON0;
 pc1=PCON1;
 st=STATUS;
 fprintf(debug,"[PC1:%X PC0:%X ST:%X]\r\n",pc1,pc0,st);
 //bit_set(PCON1,0);
 bit_clear(PCON1,0);
 while(1){
 reset_cpu();
 delay_cycles(4);
		| Ttelmah
				|  Posted: Mon May 09, 2022 1:10 am |   |
				| Do report it to CCS. They need to handle this bit by setting it after boot, just as with RVREG.
		| hmmpic
				|  Posted: Tue May 10, 2022 1:44 am |   |
				| All the problem is two different datasheet from Microchip (date are at the most left on every page), one from 2019 and one from 2020. **
 In the one from 2019:
  	  | Code: |  	  | Bit 0 – RCM Configuration Memory Reset Flag bit Reset States: POR/BOR = 1
 All Other Resets = q
 Value Description
 1 A Reset occurred due to corruption of the configuration and/or calibration data latches
 0 The configuration and calibration latches have not been corrupted
 In the one from 2020:
 Value Description
 1 The configuration and calibration latches have not been corrupted
 0 A Reset occurred due to corruption of the configuration and/or calibration data latches
 At my desk i have printed the one from 2019, and on my dev. comp i have opened the one from 2020.
 Some time i read at my desk the 2019, one and sometime i read at the dev. comp the one from 2020.
 Therefore i have used days to be so confused:-(
 The bit must be set all time for to be a good boot. And i have tested that to be true in my prev. post:
 Cold restart, PCON1.RCM, bit 0 always set. reset_cpu() from sw, after cold start show the same.
 *CCS have a error in there restart_cause();
 They invert the bit10 it is the PCON1.RCM bit and therefore the 0xBxx will show up.
 After that they clear the bit, BCF PCON1.RCM for get ready to next detection, and this is right, because they invert it. But it is all wrong!!!
 They have used the old data sheet from 2019 i think. I will try to report it but this is a hard one.
 This was not for fun, or maybe a little:-)
		| Ttelmah
				|  Posted: Tue May 10, 2022 3:56 am |   |
				| Thing to do is point out that it is 1 on a good boot, and the conflict in the data sheet. It also conflicts with it's 'name' (/RVM) - this says it
 is low for active.
		| hmmpic
				|  Posted: Tue May 10, 2022 9:14 am |   |
				| CCS will fix the bug in the next release. |  |
		| Ttelmah
				|  Posted: Wed May 11, 2022 12:11 am |   |
				| Good.  |  |
