Empty strings to end of the LCD automatically
pekka1234
PostPosted: Fri Mar 25, 2022 8:32 am     Reply with quote
I try to create empty strings to end of LCD, but it doesn't succeed.
Otherwise I must always put empty string to end of each printat- sentence.
I use macro found lately in this discussion forum.
void LCD_PUTC(char in_data);
 // I want to  create empty strings to the end of the LCD, but it came error:
void fillempty (int16 lenx)
int8  x;
 for ( x=0; x<lenx; x++)
   printf(lcd_putc," ");
#define printat(x,y,_str,...) do{ \
  lcd_gotoxy(x,y); \
  printf(lcd_putc,_str,__VA_ARGS__); \
  fillempty(strlen(_str)); \ // error: Attempt to create a pointer to a constant
  }while(0);
Can somebody help?
Pekka
PostPosted: Fri Mar 25, 2022 9:36 am     Reply with quote
I modified your program as shown below to make it work.
It displays the following output in the Output Window of MPLAB
vs. 8.92, when the program is run in the simulator.
Hello Worldeeeee
I assumed you actually want to write spaces to the end of the line.
I used 'e' to represent a space for testing purposes. 'e' = empty.
#include <18F46K22.h>
#device PASS_STRINGS=IN_RAM
#fuses NOWDT
#use delay(internal=4M)
#use rs232(UART1, baud=9600, ERRORS, stream=PC)
#include <string.h>
#define LCD_LINE_LEN  16
// Send output to console for testing.
void lcd_putc(char c)
putc(c);
// Stub, not used for testing.
void lcd_gotoxy(int8 x, int8 y)
// Fill to end of line with spaces.
// Use 'e' for empty, for testing.
int8  x;
   printf(lcd_putc,"e");
#define printat(x,y,_str,...) \
  lcd_gotoxy(x,y); \
  fillempty(LCD_LINE_LEN - strlen(_str));
printat(1,1,"Hello World");
while(TRUE);
PrinceNai
PostPosted: Fri Mar 25, 2022 11:49 am     Reply with quote
Very nice.
Does something similar exist for OLED displays?
pekka1234
PostPosted: Fri Mar 25, 2022 12:36 pm     Reply with quote
PCM Programmer
I tried your code in my PIC 18F27K40 and CCS 5.092 compiler.
It worked well.
I have not tried with real LCD, but I believe it will work.
Thanks for Saturday work!
PostPosted: Sat Mar 26, 2022 1:51 am     Reply with quote
PrinceNai wrote:
Very nice.
Just use the same code, with the corresponding putc.
PrinceNai
PostPosted: Sat Mar 26, 2022 10:39 am     Reply with quote
Will try to do it. On the first look, one additional check must be added to deal with the "NORMAL" or "LARGE" size of the font.
PostPosted: Sun Mar 27, 2022 3:18 am     Reply with quote
I'd suggest you have a flag 'large_font', and in the code that selects the
font size, this is set true/false. Then in the code to clear the line, the line
length is changed according to whether this is set or not.
PrinceNai
PostPosted: Sun Mar 27, 2022 3:56 am     Reply with quote
I'm using 1306.h driver found on this forum, where this is already defined, so it is even easier:
//   size=NORMAL;                                        // 21 characters in a row, 8 rows, total 168 chars
   size=LARGE;                                           // 10 characters, 4 rows. Use rows 0,2,4,6 to avoid overlapping
Probably only need to change LCD_LINE_LEN to 21 or 10 depending on "size" variable, either through #define or on the fly if different sizes of fonts are used.
