PIC18LF27K40: rs232- Rx working, TX never sends
asczarnecki
PostPosted: Thu Mar 10, 2022 4:23 pm     Reply with quote
Hello, I'm using a pic18lf27k40. The issue is I have setup rs232 the following pins and am able to receive a byte and do a long or short flash, but the response byte is never sent. If anyone has insight it would be greatly appreciated.
NOTE: I cannot change the pins b/c boards are already in production. These pins are in use for i2c but we want to be able to switch to uart and add a bootloader to all new boards
#define IO_RX  PIN_C3
   #define IO_TX  PIN_C4
   #use rs232(STREAM=UART_BOOT,BAUD=9600,xmit=PIN_C5,rcv=IO_RX,  ERRORS, DISABLE_INTS, FORCE_SW)
   uInt8 data,st = 0;
   while(1){
         data = 0;//fgetc(UART_BOOT);
         switch(data){
            case 0xAA:
               fputc(data+1,UART_BOOT);
               //fputc(data + 1, UART_BOOT);
               LedPulse(100);
            case 0xDD:
               LedPulse(500);
            default:
               //#use rs232(STREAM=UART_BOOT,BAUD=115200,xmit=IO_TX,rcv=IO_RX,  ERRORS, DISABLE_INTS, FORCE_SW)
               fputc(0xEE,UART_BOOT);
              //st ? LedSetPwm(100) : LedSetPwm(0);
              LedSetPwm(st ?100:0);
               st = !st;
               //output_toggle(PIN_C4);
               //printf(UART_BOOT, "%d",data+1);
               //fputc(0x01, UART_BOOT);
         delay_ms(50);
PostPosted: Thu Mar 10, 2022 6:32 pm     Reply with quote
Where are your #pin_select statements ?
PostPosted: Fri Mar 11, 2022 1:40 am     Reply with quote
If you look, he is using software RS232.
However he talks about using a UART....
However there seems to be a likely problem on what pin is actually used.
He has an 'IO_TX' pin defined as C4, but actually sends on C5. Which one
is right, and is being tested?.
On the C4 pin, if the PPS is setup for this to be an I2C pin, he needs to
turn this off before he can use it for normal I/O.
#PIN_SELECT NULL=PIN_C4
Otherwise the peripheral always has priority over normal I/O....
asczarnecki
Solved!
PostPosted: Fri Mar 11, 2022 9:28 am     Reply with quote
Thank you for your response! The pin change from C4 -> C5 was for testing with the scope on a more accessible pin.
The solution did come from selecting the pins to null before initializing rs232 has fixed the issue!
pin_select("NULL", PIN_C3);
pin_select("NULL", PIN_C4);
This other post you responded to had some helpful stuff too.
http://www.ccsinfo.com/forum/viewtopic.php?t=57581
Thanks again!
PostPosted: Fri Mar 11, 2022 10:58 am     Reply with quote
Good.
It is an important point, that on most of the chips supporting PPS, the
'peripheral' overrides the normal pin operation, so if a pin is setup with
PPS for one peripheral, to use it for anything else you need to either
remove the PPS assignment, or make a new assignment.
Glad you have it working now.
I'd have expected you to actually make new assignments to a UART,
if you intend to use this for a bootloader.
