SOLVED 18f47k40 ADC problem on D5
alan
PostPosted: Tue Feb 15, 2022 3:16 pm     Reply with quote
Compiler 5.106
When using Pin D5 as analog, on some boards it read it correctly and on other reads 0 only, replaced the PIC, no difference.
If I short out D5 and D6 and changed the analog port to D6, it works on the boards that don't work on D5. Checked continuity OK.
I know this is probably a hardware question, although I don't rule out software
Here are the test program
#include <18F47K40.h>
#include <stdint.h>
#device ADC=8
#FUSES NOEXTOSC                //External Oscillator not enabled
#FUSES NOMCLR                  //Master Clear pin used for I/O
#FUSES PUT                     //Power Up Timer
#FUSES LPBOR                   //Low-Power Brownout reset is enabled
#FUSES BORV27                  //Brownout reset at 2.7V
#FUSES NOSCANE                 //Scanner module is not available for use
#FUSES NOLVP                   //No low voltage prgming, B3(PIC16) or
#FUSES NOPROTECT                 //Code protected from reads
#FUSES NOCLKOUT
#FUSES NOWDT
#use delay(internal=64MHz)
void main() {
  setup_adc_ports(sAN29);
  setup_adc(ADC_CLOCK_DIV_128 | ADC_TAD_MUL_4);
  setup_dac(DAC_OFF);
  set_adc_channel(29);
  while (TRUE){
    if (read_adc()) output_high(LED); //if value higher that 0 switch on LED
    else output_low(LED);
    delay_ms(250);
Regards
PostPosted: Tue Feb 15, 2022 4:09 pm     Reply with quote
Ok, I don't use that PIC but
are there any internal peripherals attached to that pin that need to be disabled ?
this if (read_adc()) output_high(LED); //if value higher that 0 switch on LED
may not be correct ?
read_adc() returns a value(0...255)
but.. there's no 'condition' for the 'if'
I'd expect something like
if(read_adc()>0) output_high(LED);
maybe it's OK, but I'd like to see the assembler to understand how/why it works.
PostPosted: Wed Feb 16, 2022 7:49 am     Reply with quote
Using the adc value as a test is perfectly OK. This is 'standard C', where
and non zero value is treated as 'TRUE'. I must admit though if I was
testing the value from the ADC, I would have a little margin (a count or
two), since many of the PIC ADC's will still return a count intermittently
when the input is shorted to 0v...
Looking at the code generated by 5.105 (haven't got 5.106, I had a couple
of issues with this version), the ADC setup and operation looks correct.
It has got the errata implemented for the ADC.
You might want to see if it changes with *OPT 0. A couple of problems
seem to have been introduced on the latest couple of versions with the
optimiser being too enthusiastic and optimising away some needed bank
switches. However this isn't obvious in the 5.105 code.
Is this a DIL PIC, or a SM version?. If the latter, I would be looking very
carefully to make sure the connection actually is being made correctly.
PostPosted: Wed Feb 16, 2022 8:55 am     Reply with quote
re: Using the adc value as a test is perfectly OK. This is 'standard C', where
interesting, glad to be educated ! See you CAN teach an old dog new tricks !!
Right about the 'margin' ! There's lots of reasons why an analog pin may not be 'ZERO' when read so a margin of say 4 -5 counts would be safer.
PostPosted: Wed Feb 16, 2022 11:23 am     Reply with quote
The silly thing is that lots of people use the non zero test, without even
realising it. For instance:
if (val & 4)
(or 2, 8 etc.), as a test
PostPosted: Wed Feb 16, 2022 11:51 am     Reply with quote
hmm.
to me
if(val & 4)
is a 'proper' IF statement as 'something ' is done inside the brackets to decide a 'condition.
whereas
if(val)
doesn't do anything for the 'if' condition.
though now that I'm typing this,if val was 0,val doesn't exist kinda makes sense , as I see this ,now, like if(TRUE).
some dayze code is clear as mud......
alan
PostPosted: Thu Feb 17, 2022 7:07 am     Reply with quote
Thanks for all the replies, seems to be hardware after all, were a bit enthusiastic with my gain of the op amp, and on some of them it didn't work. Just funny that is were always the same 1 on the board, there are 4 low side current amplifiers with just an op amp. Needed to go cheap and now it bites me.
PostPosted: Thu Feb 17, 2022 7:16 am     Reply with quote
Glad you have found it. Very Happy
glad you FOUND it !!
I learned the hard way decades ago..back then,afte rspending 2 dayze on a 'bad' board,I put all chips into sockets(DIPs). It cost less to socket 100 boards than to troubleshoot which of the 20 chips had fried on one PCB.
I've always been a firm believer of paying a little more 'upfront'.Often people don't consider true repair costs(TIME)....
