		| Author | Message |
		| dyeatman
				| IOC Port E DsPIC33CH512MP508 |
				|  Posted: Wed Feb 02, 2022 2:31 pm |   |
				| PCWHD 5.107 After hours of searching I am unable to find compiler support for IOC for Ports
 D&E and I am looking at having to access the CNSTYLE/CNEN1/CNEN0 bits
 directly.  Anyone see something I am missing other than INT_Default?
 Google and Forum Search are some of your best tools!!!!
		| jeremiah
				|  Posted: Wed Feb 02, 2022 3:36 pm |   |
				| There's no #INT_CNI or enable_interrupts() options?  all of my dspics have those normally.
 edit:  I usually have:
  	  | Code: |  	  | #int_cni void cni_isr(){
 // stuff
 and in the main stuff like:
  	  | Code: |  	  | enable_interrupts(INTR_CN_PIN | PIN_B1); enable_interrupts(INTR_CN_PIN | PIN_B2);
		| dyeatman
				|  Posted: Wed Feb 02, 2022 4:27 pm |   |
				| Thank you Jeremiah, I found CNIE but could not make it work so I figured I was interpreting the name wrong.  BTW, how did you set up the (neg/pos)
 edge triggering?  The edge setting options don't seem to support this.
 I can make it work by defining and setting the registers directly but I prefer
 using the CCS options if possible.  With your confirmation I'll play with it some
 more.
		| jeremiah
				|  Posted: Wed Feb 02, 2022 6:49 pm |   |
				| Most of the chip drivers that support it have other enable_interrupts() options.  One of my chips (not the same as yours) has
  	  | Code: |  	  | #define INTR_CN_PIN              0xC000  // or in a PIN_xx constant #define INTR_CN_PIN_L_TO_H       0x8000  // or in a PIN_xx constant
 #define INTR_CN_PIN_H_TO_L       0x4000  // or in a PIN_xx constant
 For example.  If your H file doesn't have it but your chip is supposed to support it, you might try pinging CCS support via email for an updated header file.  They may have just missed it.
		| Ttelmah
				|  Posted: Thu Feb 03, 2022 2:11 am |   |
				| Several parts:
 On this particular chip, there are separate interrupts for each port.
 So CNIA, CNIB, CNIC, CNID & CNIE.
 Then on the DsPIC's, interrupt on change needs several registers to
 setup. You can specify whether the interrupt is triggered by level, or
 by the edge. This is controlled by the CNSTYLE bit, and the contents
 of CNEN1x and CNEN0x. Which pin has triggered is in the CNFx register
 for each port.
 There are five registers for each pin on these chips. I think CCS gave
 up on trying to set all of these, so leave it to you to do the configuration
 of these. They offer the enable for the pins as Jeremiah shows, but not
 control of whether this handles edges or levels. They default to just
 handling levels setting the CNEN0X bits, and the master enable. Detection
 of the bits in the flag register is left up to you.
 Set them up as Jeremiah shows in his first post, using the CNIE
 interrupt (for your port E), and then should work. However you have
 to manually read/clear the CNFE register.
		| dyeatman
				|  Posted: Thu Feb 03, 2022 7:40 am |   |
				| Thanks to both of you!  With your help I now have a hybrid of CCS functions and direct register accesses but it works.  Hopefully they will get this cleaned
 up more later.
		| Ttelmah
				|  Posted: Thu Feb 03, 2022 8:48 am |   |
				| Point the lack out to them. This particular chip family is unusual in supporting the extra edge detect
 option, and having separate IOC's on each port. I think the person writing
 this originally at CCS put in the parts that the functions used on the other
 chips had, but didn't get involved in adding support for this chip's 'extras'.
		| jeremiah
				|  Posted: Thu Feb 03, 2022 9:37 am |   |
				|  	  | dyeatman wrote: |  	  | Thanks to both of you!  With your help I now have a hybrid of CCS functions and direct register accesses but it works.  Hopefully they will get this cleaned
 up more later.
 Just keep in mind that they don't monitor these forums aside from general moderation.  You definitely want to email them and let them know (or call if you don't like email)
