PIC16F18346 to PIC16F18346 I2C Communication
Goto page Previous  1, 2
PostPosted: Tue Jul 06, 2021 7:02 am     Reply with quote
Regarding the R/W bit, you're not doing it correctly. Look at the
sample code in the link below. Look at the section where it reads
from the slave board. See how it does it:
http://www.ccsinfo.com/forum/viewtopic.php?t=32368&start=3
PostPosted: Tue Jul 06, 2021 7:33 am     Reply with quote
Slave addresses are required to be even. Cannot be odd.
L.T.
PostPosted: Tue Jul 06, 2021 11:14 pm     Reply with quote
Hi Ttelmah,
What did you mean? I dont understand.
PostPosted: Tue Jul 06, 2021 11:40 pm     Reply with quote
You said
But if I change it to 0x13(00010011)
Slave addresses can _only_ be even numbers. They cannot be odd numbers.
A slave set with an address of 0x12, responds to address bytes of both 0x12,
and 0x13. The actual 'slave address', is the upper 7 bits of the byte sent.
L.T.
PostPosted: Wed Jul 07, 2021 12:18 am     Reply with quote
and 0x13. The actual 'slave address;, is the upper 7 bits of the byte sent.
Hii Ttelmah,
I didnt want to say to change the slave address as 0x13. When the slave address is 0x12 and I want to send data from the master and send 0x12 as address+r/w from the master, I can send data from the master and read from the slave. 0x12 is 00010010. When I send 0x12 from the master, isn't it the slave address information from the 7th bit to the 1st bit (0001001), and the r/w bit if the 0th bit (0) is? Isn't it necessary to give a write command (1) before sending data from the master? When I send 0x13 as address+r/w from the master, the write command must be given, the last bit is 1. Why can I send data at 0x12 and not 0x13?
L.T.
PostPosted: Wed Jul 07, 2021 2:00 am     Reply with quote
Hi PCM programmer,
I did some changes in my code as the link you sent. I can send data from master and slave read correctly. But when master sent to slave request data order, master didnt read correctly. Slave sent 4, master read 0x26. Why?
When I debugged in the slave code, I've seen it never go inside if(state==0x80).
#include <16F18346.H>
#fuses XT,NOWDT,NOPROTECT,NOLVP,PUT
#define Slave_Read   0x12
#define Slave_Write   0x13
/* Delay for 4 mhz crystal */
#use delay(clock = 24MHz)
/* Setup I2C */
#pin_select SCL1OUT = PIN_C3
#pin_select SCL1IN  = PIN_C3
#pin_select SDA1OUT = PIN_C6
#pin_select SDA1IN  = PIN_C6
#use I2C(MASTER, I2C1, SLOW)
main()
   int8 OKU;
   setup_oscillator(OSC_HFINTRC_24MHZ,OSC_CLK_DIV_BY_16);
   set_analog_pins();
   int8 i2c_command = 66;
   while (true)
      OKU=0;
        i2c_start();      // Start condition
        i2c_write(0x12);   // Device address
      i2c_write(0x00);
        i2c_write(4);   // Write Command
        i2c_stop();      // Stop condition
      output_toggle(pin_C0);
        i2c_start();
      i2c_write(0x00);
      i2c_start();
        i2c_write(0x13);
        OKU=i2c_read(0);
        i2c_stop();
        if(OKU==4)
            output_toggle(pin_A2);
/* Setup I2C */
#use i2c(SLAVE, I2C1, address=0x12, FORCE_HW)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
   int8 incoming, state;
   state = i2c_isr_state();
   if (state <= 0x80)   //Master is sending data
      incoming = i2c_read();
      if(state == 1)                    //First received byte is address
         address = incoming;
      if(state == 2)                    //Second received byte is data
         buffer[address] = incoming;
         if(buffer[address] == 4)
   if(state == 0x80)  //Master is requesting data
       i2c_write(buffer[address]);
main()
      set_analog_pins();
      enable_interrupts(INT_SSP);
      while (true)
PostPosted: Wed Jul 07, 2021 2:18 am     Reply with quote
OK. The problem was you referred to a slave address of 13, and this can't happen. The R/W bit is not actually part of the 'address'...
Anyway, going on to your code. The problem is how address==80 is
handled. I again refer you to the example. The point is that when you
do the read on address 0x80, you must do I2c_read(2), not the standard
read. If you do the standard read, it releases the bus, and then the slave
does not have time to load the reply.....
So:
#INT_SSP
      if (state==0x80)
         incoming = i2c_read(2); //critical - reads without releasing clock
      if(state == 1)                    //First received byte is byte address
         address = incoming;
      if(state >= 2 && state!=0x80)    //Second received byte is data
    if(state >= 0x80)  //Master is requesting data
I've also changed it so it can handle more than one byte sent or
received. You were only handling state 2, not 3, 4, 5 etc..
L.T.
PostPosted: Wed Jul 07, 2021 2:49 am     Reply with quote
Thanks a lot Ttelmah! It works.
Page 2 of 2
