andresteff
| PIC24F - watchdog fail on SLEEP-IDLE-Mode |
Posted: Tue May 11, 2021 11:09 am |
I want to use the IDLE-Mode in sleep. The time-out of the wdt is 256ms.
The problem:
If the timer5 interrupt is enabled the wdt works wrong in sleep-idle, but correct in sleep-full!
If the timer5 interrupt is disabled the wdt works correct in sleep-idle and correct in sleep-full! All ok!
I tested also timer4 and timer3, they have same behavior.
What's wrong?
CCS Version: 5.080 with IDE
PIC: PIC24F16KA301
ICD3
This a complete test program.
The wdt works wrong. I measure 8,3kHz on the toggle led for test.
When timer5 interrupt is disabled, the code works correct.
#include <24F16KA301.h>
#device ADC=8
#device ICSP=3
#use delay(internal=500000)
#fuses LPRC //Internal low power RC Oscillator
#fuses LPFRC_DIV //Low-Power FRC oscillator with divide-by-N
#fuses LPRCLOW //Low-Power FRC Low Power and Low Accuracy
//#fuses CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#fuses CKSNOFSM //Clock Switching is enabled, fail Safe clock monitor is disabled
#fuses OSCIO //OSC2 is general purpose output
#fuses WDT_SW //No Watch Dog Timer, enabled in Software
//#fuses WDT //Watch Dog Timer
#fuses MCLR //Master Clear pin enabled
#fuses PUT //Power Up Timer
#fuses SOSC_DIGITAL //SOSC pins set for Digital mode for use with external clock or Digital I/O. Um RA4 und RB4 als dig out zu nutzen.
#define LED_gr PIN_B4
#INT_TIMER5
void TIM5_Int(void)
setup_oscillator( OSC_LPFRC , 500000);
#use delay(clock=500000)
delay_ms(10);
output_low ( PIN_A3);
setup_timer5( TMR_INTERNAL | TMR_DIV_BY_8 );
set_timer5(49911);
enable_interrupts(INT_TIMER5);
disable_interrupts(GLOBAL);
Setup_wdt(WDT_256MS);
sleep(SLEEP_IDLE); // with sleep(SLEEP_FULL); , it works
output_toggle(LED_gr);
Posted: Wed May 12, 2021 12:22 am |
It's working right.....
In the idle modes, the timers keep running. If the interrupt triggers (if
enabled), this wakes the chip up. So it'll execute the timer code, toggle the
pin and go back to sleep. The act of entering sleep mode resets the
watchdog. So the watchdog will never trigger.
Remember on the PIC24's, you can put a 'limit' value for the timer count
as an extra value after the clock source etc., in the timer setup. So you can
program the timer to tick at an exact interval (within the accuracies of
the clock source). If you want it to keep ticking, choose a value that suits,
and then have a counter updated in the tick, and only toggle the pin
when this gets to the total time you want. |
andresteff
Posted: Mon May 17, 2021 3:18 am |
Ok, thanks for the info. They "opened my eyes".
My "mistake" was the GLOBAL interrupt was disabled. And the timer interrupt enabled. When by an timer overflow the flag is set, the chip goes out of the idle mode - set the led - goes in idle, and then immediately out of the idle,
because the interrupt flag of the timer is always still set!
Therefore the frequency of 8,3kHz!
If the GLOBAL interrupt is enabled, the chip goes in the ISR, and the interrupt flag of the timer is cleared.
The chip stay until the next timer overflow in idle-mode. |
andresteff
Posted: Mon May 17, 2021 3:20 am |
| A nice feature of the PIC24 is still, that the peripheral can enabled/disabled in Idle-Mode. |
