multisource project overwritten by IDE
webgiorgio
PostPosted: Thu May 06, 2021 2:59 am     Reply with quote
I use to organize my projects in multiple files like:
- main.ccsprj
- main.c
- variables.c
- functions.c
- serial.c
- defin.c
And use folders to organize the projects and versions like:
C:/prjectA/ver1
C:/prjectA/ver2
C:/prjectB/ver1
What happened is that I opened project B, and click save, the files of project B were overwritten with the content of same-name-files from project A (except main).
What happened?
I always open the projects by opening the file main.ccsprj
If I open the ccsprj with notepad I see that there is the list of the project files to open in the IDE tabs.
PostPosted: Thu May 06, 2021 3:15 am     Reply with quote
When I work with separate versions like this I always delete the ccsprj file.
Then simply open the main .c file of the project.
This then forms a new .prj file pointing to the files in the current directory.
Result no problem.
If you open the ccsprj file this is a complete 'description' of the current
'project' including what files are associated with it.
So long as you worked with separate .prj files in each version directory, and
opened the one for that project there would not be a problem. However if
you made a 'ver2', by copying the files from 'ver1', and included the prj
file, then this would be pointing to the old files. Problem.
