PCD 5.103 ADC VREF bug
dluu13
PostPosted: Fri Apr 16, 2021 8:26 pm     Reply with quote
I've already solved the issue myself a couple of weeks ago, but I figured
I might post this here in case somebody else has a similar problem.
I'm using PCD 5.103 with PIC24FJ256GL408. I'm not too surprised, since
it's a new compiler with a new PIC (released in 2019, if I recall correctly).
Basically, if I set up ADC like this, the compiler does not correctly set the
positive ADC reference to VREF:
setup_adc(ADC_CLOCK_DIV_256);
setup_adc_ports(AN_DVOLT | AN_CVOLT | AN_WIP_VOLT_SNS |
            AN_WIP_CURR_SNS | AN_RPUMPCURR | AN_DPUMPCURR,
            VSS_VREF);
Instead, I get around it by setting the bits manually:
#bit PVCFG0 = getenv("BIT:PVCFG0")
#bit PVCFG1 = getenv("BIT:PVCFG1")
#bit NVCFG0 = getenv("BIT:NVCFG0")
            AN_WIP_CURR_SNS | AN_RPUMPCURR | AN_DPUMPCURR);
PVCFG0 = 1;
PVCFG1 = 0;
NVCFG0 = 1;
I emailed this to CCS support a couple of weeks ago but they never
replied, which is unusual. Hopefully they are working on a fix...
PostPosted: Sat Apr 17, 2021 12:48 am     Reply with quote
It's just an error with the defines in the .h file.
If you look:
// Optional Second argument:
#define VSS_VDD            0x0000 // Range 0-Vdd
#define VREF_VREF          0x6000 // Range VrefL-VrefH
#define VREF_VDD           0x4000 // Range VrefL-Vdd
#define VSS_VREF           0x2000 // Range 0-VrefH
These are the values to be put into the AD1CON2 register. VSS_VREF
actually needs to be 0x4000. According to the data sheet the NVCFG0
bit, doesn't actually work (the data sheet says the value used is the same
whether it is 1 or 0...). The chip doesn't actually show a Vref- pin (only
CVref-).
So the values actually useable are:
#define VSS_VREF           0x4000 // Range 0-VrefH
Substitute these and you should find it'll work. I just tried compiling with
this done, and it merrily puts the right value into the register.
It looks as if they must have 'meant' to have a Vref- pin, so included the
bit in the register, and then not actually implemented it!...
When CCS were setting it up, because of this oddity they miscounted the
bit number.
dluu13
PostPosted: Sat Apr 17, 2021 6:33 am     Reply with quote
Thanks!
Though I'll just put a comment in my code about that. I don't want to be putting "magic numbers" in the code, nor do I want to be modifying their header files.
There are actually a ton of neat features on this chip that aren't really supported in CCS right now and I'd have to do it manually.
For example this chip can be configured to have a dual partition on its program memory, and you can select which partition to "boot" from.
Maybe one day I'll have some time to try that out.
PostPosted: Sun Apr 18, 2021 9:54 am     Reply with quote
Just make your own 0x4000 define with your own name. Make a remark
on 'why'. The dual partition boot exists on quite a few chips and is
supported quite well.
dluu13
PostPosted: Sun Apr 18, 2021 10:03 am     Reply with quote
That's a good idea... I'll do that instead.
Re: dual partition boot, do you have any hints on where to start exploring first? I didn't see any particular fuses for that. Either that or I missed them entirely.
PostPosted: Mon Apr 19, 2021 1:45 am     Reply with quote
Have you looked at the dual partition bootloader example?.
ex_bootloader_dp.c (and the include files this loads).
dluu13
PostPosted: Mon Apr 19, 2021 6:49 am     Reply with quote
Hmm, it looks it just loads it into the first partition and the bootloader will manually stick the application into the second partition.
I guess if you want to get back into the bootloader you have to write something in your application that runs the bootswp instruction?
Is there even a way to choose which partition you flash into when you're using ICSP?
I also noticed that the help file provided with the compiler is not up to date, as it differs from the PDF version found on the CCS website...
