PIC24F RX2 doesn't work(SOLVED)
E_Blue
PostPosted: Wed Feb 03, 2021 4:24 pm     Reply with quote
CCS v5.091
MPLAB X IDE 5.15
ICD3
PIC24FJ1024GB606
I'm trying to receive data on pin RG9 at 19200bps but get nothing.
The PIC is connected to 3.3V and the GPS at UART2 send 2.8V data.
I get not even a single interrupt
I can send data correctly but not receive; so I think that the bps are set it correctly.
2.8V is not enough?
This is a reduced code.
#pin_select U2TX=PIN_D5
#pin_select U2RX=PIN_G9
#use rs232(UART2,stream=GPS,NOINIT)
output_b(0);
   output_c(0);
   output_d(0);
   output_e(0);
   output_f(0);
   output_g(0);
    set_tris_b(0b1001001001010110);
    set_tris_c(0b0110000000000000);
    set_tris_d(0b111100000011);//RTS=GSM OUT=D2 RTS=GSM_IN=D1 - RD4=SPI_DO - RD5=SPI_DI - RD6=SPI_CLK - RD7=SPI_CS
    set_tris_e(0b11000011);
    set_tris_f(0b10000000);
    set_tris_g(0b11001000000);
    SETUP_PMP(PAR_DISABLE,0);
    SETUP_PSP(PAR_DISABLE,0);
    SETUP_CLC1(CLC_DISABLED);
    SETUP_CLC2(CLC_DISABLED);
    SETUP_CLC3(CLC_DISABLED);
    SETUP_CLC4(CLC_DISABLED);
    SETUP_CAPTURE(1,CAPTURE_OFF);
    SETUP_CAPTURE(2,CAPTURE_OFF);
    SETUP_CAPTURE(3,CAPTURE_OFF);
    SETUP_CAPTURE(4,CAPTURE_OFF);
    SETUP_CAPTURE(5,CAPTURE_OFF);
    setup_uart(GPS_BPS1,GPS);
Should I configure something more?
Electric Blue
PostPosted: Wed Feb 03, 2021 4:42 pm     Reply with quote
You had the same issue about 1-1/2 years ago and it was solved in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=58305
E_Blue
PostPosted: Wed Feb 03, 2021 4:57 pm     Reply with quote
It seems like I'm running in circles. Confused
I'm the ones that need to kick the same stone twice. Embarassed
Thanks. Rolling Eyes
Electric Blue
PostPosted: Wed Feb 03, 2021 6:19 pm     Reply with quote
re:
Just to let you know....It gets worse the older you get !!!!!
PostPosted: Thu Feb 04, 2021 1:31 am     Reply with quote
and the circles get smaller... Sad
