Round the number
MCUprogrammer
Round the number
PostPosted: Fri Jan 15, 2021 3:10 am     Reply with quote
CCS C 5.099
MCU 33EP512GM710
#use delay(clock=120MHz,crystal=16MHz)
Hello there
I encountered an interesting situation. I read values with the keypad. Then I put the value I read into the unsigned int16 value variable. Then I do the following on my float cal_value variable.
cal_value = value /10.0;
my value value is 6;
6 / 10.0 = 0.6. Doesn't come out. It turns out 0.59. I want to round it to the screen with% g. But rounding does not happen. What do you think I can do wrong. I used the ceil () function. it makes my value 1 instead of 0.6.
Also the debugger of the ccs c compiler does not work properly. It keeps giving an error. I don't understand how this work.
Also, isn't it possible to divide an unsigned int type variable into a Float type variable?
When I do value / 10 the code doesn't work.
 the code I used to print the screen;
                current_output = digit_1;
               calculated_value = current_output/10.0;
               glcd_rect(170,84,240,105,ON,OFF);
               sprintf(buffer,"current value:");
               glcd_text57(62,92,buffer,1,ON);
               sprintf(buffer,"%g",calculated_value);
               glcd_text57(182,87,buffer,2,ON);
Best Regards...
MCUprogrammer
_______________________________
Work Hard
PostPosted: Fri Jan 15, 2021 5:00 am     Reply with quote
Welcome to the limitations of float.
There are some numbers that the standard FP format, can never represent
accurately. So (for example) 0.45. Just as with decimal notation, where
1/3, needs an infinitely long sequence of digits, in binary, 0.45, requires
an infinite sequence to represent accurately. So using the standard
single precision format, 0.45's nearest possible value is 3EE66666 (in IEEE),
which represents 0.4499999. Now you can't 'round' this to get 0.45, since
if you add one to the representation (3EE66667), this gives 0.45000002.
So you can't actually 'have' a value of 0.45....
Now you can round in the output, by adding 0.0049, and then printing just
two digits. So:
   val=0.45;
   printf("VAL = %5.2F\n\r", val+0.0049);
Wiil display 0.45.
For three digits:
   val=0.45;
   printf("VAL = %6.3F\n\r", val+0.00049);
In each case, you add just less than 0.5 of the digit beyond where you
want to display, and limit to that digit.
ceil gives the integer above the starting value. Hence your '1'.
I posted a 'round' function, to round to a number of decimals a while
ago:
https://ccsinfo.com/forum/viewtopic.php?p=50803
However this is 'maths heavy' to do.
MCUprogrammer
PostPosted: Fri Jan 15, 2021 5:17 am     Reply with quote
Thank you so much. Problem solved. Very Happy
Best Regards...
MCUprogrammer
Work Hard
