crc 16 calculation help
raman00084@gmail.com
PostPosted: Tue Dec 15, 2020 4:20 am     Reply with quote
I am using dspic33ep512mu810.
I am new to CRC kindly guide me how to calculate 16bit crc
for example the Modbus RTU data is
01 05 00 02 FF 00
and CRC for the above is 2D FA
CASE 1: 01 05 00 02 FF 00 how to get 2D FA (generate crc)
CASE 2: how to check 2D FA is correct for 01 05 00 02 FF 00 ( check crc)
PostPosted: Tue Dec 15, 2020 4:33 am     Reply with quote
If you look in the example physical layer. Modbus_phy_layer_rtu.c
it has a function modbus_calc_crc, that will calculate the CRC if called with
the data bytes one by one. You need to start the CRC set to 0xffff before
calling the first time. It does it quickly by using table look ups for the values.
By far the fastest and easiest way to do this.
You calculate the CRC as you receive the bytes, and then compare this
with what you receive for the CRC bytes.
kmp84
PostPosted: Tue Dec 15, 2020 9:56 am     Reply with quote
Here is sample test program for your example packet and how to setup serial port of this controller:
#include <33EP512MU810.h>
#device ICSP=1
#use delay(crystal=8MHz, clock=16MHz)
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                   //JTAG disabled
/* HW UART1 */
#pin_select U1RX=PIN_E1         // Rx Com1.
#pin_select U1TX=PIN_E0         // Tx Com1.
#define EN1_485 PIN_D1          // RE/DE Com1.
#use rs232(UART1,baud=9600,errors)
const unsigned int16 wCRCTable[] = {
0X0000, 0XC0C1, 0XC181, 0X0140, 0XC301, 0X03C0, 0X0280, 0XC241,
0XC601, 0X06C0, 0X0780, 0XC741, 0X0500, 0XC5C1, 0XC481, 0X0440,
0XCC01, 0X0CC0, 0X0D80, 0XCD41, 0X0F00, 0XCFC1, 0XCE81, 0X0E40,
0X0A00, 0XCAC1, 0XCB81, 0X0B40, 0XC901, 0X09C0, 0X0880, 0XC841,
0XD801, 0X18C0, 0X1980, 0XD941, 0X1B00, 0XDBC1, 0XDA81, 0X1A40,
0X1E00, 0XDEC1, 0XDF81, 0X1F40, 0XDD01, 0X1DC0, 0X1C80, 0XDC41,
0X1400, 0XD4C1, 0XD581, 0X1540, 0XD701, 0X17C0, 0X1680, 0XD641,
0XD201, 0X12C0, 0X1380, 0XD341, 0X1100, 0XD1C1, 0XD081, 0X1040,
0XF001, 0X30C0, 0X3180, 0XF141, 0X3300, 0XF3C1, 0XF281, 0X3240,
0X3600, 0XF6C1, 0XF781, 0X3740, 0XF501, 0X35C0, 0X3480, 0XF441,
0X3C00, 0XFCC1, 0XFD81, 0X3D40, 0XFF01, 0X3FC0, 0X3E80, 0XFE41,
0XFA01, 0X3AC0, 0X3B80, 0XFB41, 0X3900, 0XF9C1, 0XF881, 0X3840,
0X2800, 0XE8C1, 0XE981, 0X2940, 0XEB01, 0X2BC0, 0X2A80, 0XEA41,
0XEE01, 0X2EC0, 0X2F80, 0XEF41, 0X2D00, 0XEDC1, 0XEC81, 0X2C40,
0XE401, 0X24C0, 0X2580, 0XE541, 0X2700, 0XE7C1, 0XE681, 0X2640,
0X2200, 0XE2C1, 0XE381, 0X2340, 0XE101, 0X21C0, 0X2080, 0XE041,
0XA001, 0X60C0, 0X6180, 0XA141, 0X6300, 0XA3C1, 0XA281, 0X6240,
0X6600, 0XA6C1, 0XA781, 0X6740, 0XA501, 0X65C0, 0X6480, 0XA441,
0X6C00, 0XACC1, 0XAD81, 0X6D40, 0XAF01, 0X6FC0, 0X6E80, 0XAE41,
0XAA01, 0X6AC0, 0X6B80, 0XAB41, 0X6900, 0XA9C1, 0XA881, 0X6840,
0X7800, 0XB8C1, 0XB981, 0X7940, 0XBB01, 0X7BC0, 0X7A80, 0XBA41,
0XBE01, 0X7EC0, 0X7F80, 0XBF41, 0X7D00, 0XBDC1, 0XBC81, 0X7C40,
0XB401, 0X74C0, 0X7580, 0XB541, 0X7700, 0XB7C1, 0XB681, 0X7640,
0X7200, 0XB2C1, 0XB381, 0X7340, 0XB101, 0X71C0, 0X7080, 0XB041,
0X5000, 0X90C1, 0X9181, 0X5140, 0X9301, 0X53C0, 0X5280, 0X9241,
0X9601, 0X56C0, 0X5780, 0X9741, 0X5500, 0X95C1, 0X9481, 0X5440,
0X9C01, 0X5CC0, 0X5D80, 0X9D41, 0X5F00, 0X9FC1, 0X9E81, 0X5E40,
0X5A00, 0X9AC1, 0X9B81, 0X5B40, 0X9901, 0X59C0, 0X5880, 0X9841,
0X8801, 0X48C0, 0X4980, 0X8941, 0X4B00, 0X8BC1, 0X8A81, 0X4A40,
0X4E00, 0X8EC1, 0X8F81, 0X4F40, 0X8D01, 0X4DC0, 0X4C80, 0X8C41,
0X4400, 0X84C1, 0X8581, 0X4540, 0X8701, 0X47C0, 0X4680, 0X8641,
0X8201, 0X42C0, 0X4380, 0X8341, 0X4100, 0X81C1, 0X8081, 0X4040 };
unsigned int16 CRC16 (BYTE *nData, unsigned int16  wLength){
   BYTE nTemp;
   unsigned int16  wCRCWord = 0xFFFF;
   while (wLength--)
      nTemp = *nData++ ^ wCRCWord;
      wCRCWord >>= 8;
      wCRCWord ^= wCRCTable[nTemp];
   return wCRCWord;
void main(void){
   delay_ms(1000); // some starup delay
   printf("\r\n ModBus RTU CRC Example.\r\n");
   unsigned int16 CalcW_CRC = 0;
   unsigned int16 RecW_CRC = 0xFA2D; // MSB,LSB swapped!
   BYTE data[] = {0x01,0x05,0x00,0x02,0xFF,0x00}; // 0x2DFA - Received wCRC sum.
   CalcW_CRC = CRC16(data, sizeof(data));  //
   printf("\r\n Recived CRC=0x%lX, Calc.CRC=0x%lX",RecW_CRC, CalcW_CRC);
   if(CalcW_CRC == RecW_CRC)
      printf("\r\n CRC-OK!");
      printf("\r\n CRC-ERROR!");
   while(TRUE){
      //User Code ...
Best Regards,
steve__p
PostPosted: Tue Dec 15, 2020 11:33 am     Reply with quote
For your info, here is my version without table, used with PIC24FJ128GA306:
uint16 modbus_crc(uint8 *data,uint8 size)
   uint16   crc;
   uint8    i,z;
   crc=0xFFFF;
   for(i=0;i<size;i++)
      crc=crc^data[i];
      for(z=0;z<8;z++)
         if(bit_test(crc,0))
            crc=crc/2;
            crc=crc^0xA001;
         else crc=crc/2;
   return(crc);
PostPosted: Tue Dec 15, 2020 11:33 pm     Reply with quote
kmp84 wrote:
your code works great thanks for the help bro.
i have one doubt, what is the maximum number of bytes i can check.
wlength=?
PostPosted: Wed Dec 16, 2020 2:10 am     Reply with quote
Potentially 32KB!....
wlength is an int16, which on a PIC24/33 is a signed int16, so maximum
supported length would be 32767 bytes, However obviously real limits on how
much data you can actually store would override this. Modbus itself limits
the maximum packet size.
kmp84
PostPosted: Wed Dec 16, 2020 4:20 am     Reply with quote
Here is Modbus specification:
https://www.modbus.org/docs/Modbus_Application_Protocol_V1_1b3.pdf
I think max. data field length are 125 registers x 2 bytes =250 bytes, but read info from link above. It's also depend from external factors like line length, baud rate if using rs485 interface etc.
P.S. CCS's modbus rtu driver work very well for me, but when packets are long they don't use transmit interrupts! I don't know why.Rolling Eyes
Best Regards!
PostPosted: Thu Dec 17, 2020 3:42 am     Reply with quote
sir where can i find CCS's modbus rtu driver?
any link ?
PostPosted: Thu Dec 17, 2020 3:56 am     Reply with quote
It is with the compiler.
Sub-directories of the the compiler directory. Examples, and drivers.
There is a master and slave modbus example. The physical hardware driver
changes for RTU, and is modbus_phy_layer_rtu.c This is automatically
loaded if you specify the MODBUS_SERIAL_TYPE as MODBUS_RTU.
