Maxs conde
How to calculate the ADC value ? |
Posted: Thu Oct 01, 2020 9:13 am |
"You want to design a digital thermometer, for which you must use a PIC18F4550, a 2-line LCD and a 10KΩ thermistor. The circuit must give a welcome message for 1s, then present the student's data for 2s".
THIS PART ALREADY DONE IT.
"Then it will present the temperature value in °C, for the conversion.
Consider that the temperature is proportional to the voltage generated by the thermistor, that is, for 0V you have 0 °C and for 5V you have 100 °C."
HOW CAN I CALCULATE THIS PART OF 0 - 100 °C WITH 0 - 5v ?
#include <18F4550.h>
#device adc=10 // Define the number of bits of the converter
// This is used when using an A/D converter
#fuses XT, WDT, NOPROTECT, NOPUT, NOPBADEN // fuse configuration
#use delay (clock=4000000) // Fosc = 4 MHz
#include <lcd.c> // lcd library
// FOR YOU TO RECOGNIZE THE COMMANDS BELOW
float valor, valor_conversion; // value and conversion_value are variables that I can modify for example by voltage
setup_adc_ports(AN0); // We tell it to use port 0
setup_adc(ADC_CLOCK_INTERNAL); // we told it to use the internal clock
set_adc_channel(0); // select analog channel 0
// we are putting channel 0
lcd_init(); // we are saying with this command that the LCD is activated
lcd_putc("\f BIENVENIDO \n"); // command or sentence that will allow us to display on the screen at startup
delay_ms(1000); // Delete the message in the requested time
lcd_putc("\f"); // Clear screen
// Wait 1 second while the screen is cleared.
lcd_putc("\f ESTUDIANTE GQT\n"); // Here can go the name
lcd_putc(" Max's Conde");
delay_ms(2000); // Delete the message in the requested time
// Wait 2 seconds while the screen is cleared.
while(true){
valor = read_adc(); // Reads the analog value and assigns it to the 16-bit variable
valor_conversion = valor*5/1023; // Formula for equivalent voltage value
lcd_gotoxy(4,1); // Cursor goes to column 1 row 2 as the LCD is 2 lines
printf(lcd_putc,"TEMPERATURA ",); // print a message
lcd_gotoxy(4,2); // Cursor goes to column 1 row 2 as the LCD is 2 lines
printf(lcd_putc,"%6.1f C ", valor_conversion); // To put its equivalent in voltage of what the cursor reads: ADC
_________________ Quiero ser apoyado en algunas consultas sobre mis practicas en la universidad |
Posted: Thu Oct 01, 2020 10:19 am |
0v = adc value of 0.
5v = (theoretical) value of 1024.
The ADC cannot actually read '5v', is gives it's maximum of 1023, just on
5mV below this input.
So for 0 to 100, multiply by 0.0976.
1024 counts * 0.0976 = 100.
In fact though for the likely accuracy of the sensor, just *.1 or /10. |
Joined: 01 Jul 2010 Posts: 9160 Location: Greensville,Ontario
Posted: Fri Oct 02, 2020 2:32 pm |
re: Quote: | In fact though for the likely accuracy of the sensor, just *.1 or /10.
YES ! Especially since unless you design the PCB for 10 bit ADC, 'noise' alone will negate 2-2 bits of data. Getting reliable, repeatable ADC readings over 8 bits is quite a challenge ! Noise comes from the PSU, airborne, wiring, wrong caps (or missing), power surges (turn an LED on or off...), EMI, etc...... |
Posted: Sat Oct 03, 2020 12:08 am |
Yes. There is also more, since I cannot think of a basic thermocouple
circuit that will actually give 0 to 5v for 0 to 100C, without a huge amount of
analog signal processing.... ![Sad](images/smiles/icon_sad.gif) |
