E_Blue
Printf not working as expected [Solved] |
Posted: Wed Sep 23, 2020 9:06 am |
I'm trying to print in a string but I see no changes after printf
What I'm doing wrong?
char IndexBufferCmdMain;
#define BufferCmdMainSize 15
char BufferCmdMain[BufferCmdMainSize][12];
#define AlarmRxBufferSize 16
char AlarmRxBuffer[AlarmRxBufferSize];//128bits
unsigned int16 EventoCid;
#define Part 0x09
#define User 0x0A
printf(BufferCmdMain[IndexBufferCmdMain][0],"%4LX A%1X A%2X\r\n",EventoCid,AlarmRxBuffer[Part],AlarmRxBuffer[User]);
_________________ Electric Blue
Posted: Wed Sep 23, 2020 9:15 am |
If you want to print to a buffer, you should use sprintf, not printf. |
Joined: 01 Jul 2010 Posts: 9503 Location: Greensville,Ontario
Posted: Wed Sep 23, 2020 9:24 am |
You need to post a real small program that comments what is expected and shows us what IS printed.
If you're trying to fill 'BufferCmdMain[IndexBufferCmdMain][0]' with 'EventoCid,AlarmRxBuffer[Part],AlarmRxBuffer[User])' data then you need to use the SPRINTF() function.
I'm thinking that's what you want to do. Look for Sprintf() in the manual, there is a small example listed.
E_Blue
Posted: Wed Sep 23, 2020 9:25 am |
Changed
Code: | printf(BufferCmdMain[IndexBufferCmdMain][0],"%4LX A%1X A%2X\r\n",EventoCid,AlarmRxBuffer[Part],AlarmRxBuffer[User]); |
to
Code: | sprintf(BufferCmdMain[IndexBufferCmdMain][0],"%4LX A%1X A%2X\r\n",EventoCid,AlarmRxBuffer[Part],AlarmRxBuffer[User]); |
doesn't work
Changed to
Code: | sprintf(BufferCmdMain[IndexBufferCmdMain],"%4LX A%1X A%2X\r\n",EventoCid,AlarmRxBuffer[Part],AlarmRxBuffer[User]);
and worked ok. _________________ Electric Blue |
Posted: Wed Sep 23, 2020 11:34 am |
sprintf, needs to be given the address where it is to put the data.
Is not an address.
to put the data into BufferCmdMain, you would just use
BufferCmdMain. If you want to put it to an offset location in this
buffer, then you need to use &, and the index, so:
&BufferCmdMain[IndexBufferCmdMain][0] |
