#use rs232, DALI and manchester?
newguy
PostPosted: Mon Sep 14, 2020 1:19 pm     Reply with quote
I've consulted the help with v5.093 and I can't see any mention of whether the compiler's #use rs232() supports DALI/manchester? If not, no big deal, I can easily set it up myself.
For example, from the PIC18LF26K83's data sheet:
31.7 General Purpose Manchester
General purpose Manchester is a subset of the DALI
mode. When the UxP1L register is cleared, there is no
minimum wait time between frames. This allows full
and half-duplex operation because writes to the UxTXB
are not held waiting for a receive operation to complete.
General purpose Manchester operation maintains all
other aspects of DALI mode such as:
• Single-pulse Start bit
• Most Significant bit first
• No stop periods between back-to-back bytes
General purpose Manchester mode is configured with
the following settings:
• MODE<3:0> = 1000
• TXEN = 1
• RXEN = 1
• UxP1 = 0h
• UxBRGH:L = desired baud rate
• TXPOL and RXPOL = desired Idle state
• STP = desired number of stop periods
• RxyPPS = TX pin selection code
• TX pin TRIS control = 0
• RXPPS = RX pin selection code
• RX pin TRIS control = 1
• Input pin ANSEL bit = 0
• ON = 1
The Manchester bit stream timing is shown in
Figure 31-7.
It's just that it would be nice if the compiler supported this already.
PostPosted: Mon Sep 14, 2020 2:38 pm     Reply with quote
I'd email CCS support, ask them, maybe they'll add to compiler and send you the upgraded version !!
PostPosted: Mon Sep 14, 2020 11:46 pm     Reply with quote
Equally though it is very easy to just enable this yourself.
The UART operation is completely standard, the only thing that has to change is the mode setting.
So:
#bit UARTON=getenv("BIT:U1ON")
#byte UART1CON0=getenv("SFR:U1CON0")
#byte U1P1L=getenv("SFR:U1P1L")
#define LIN_MASTER 0xC
#define LIN_SLAVE 0xB
#define DMX 0xA
#define DALI_GEAR 9
#define DALI_DEVICE 8
void select_manchester(void)
   //Manchester mode is DALI mode, with U1P1L set==0
   UARTON=FALSE;
   UART1CON0=(UART1CON0 & 0xF0) | DALI_DEVICE; //switch to DALI
   U1P1L=FALSE;
   UARTON=TRUE; //re-enable UART
   select_manchester(); //switch UART to manchester mode
   //then your code....
