Tm1637 CCS C
yakup1890
Tm1637 CCS C
PostPosted: Sun Aug 09, 2020 3:01 am     Reply with quote
Hello friends
I want to make a clock thermometer with TM1627, I couldn't drive.
I found a code written in c, I did not edit it
Could you help?
#include <tm1637_pic.h>
#include "DS1302.C"
#include "DHT11.C"
#include  "TM1637-BOLT.h"
#define bright MAX_BRIGHT
byte saniye,dakika,saat,gun,ay,yil,haftanin_gunu;
unsigned int  i=0;
char birler=0, onlar=0,yuzler=0,binler=0,sayi=0;
float sicaklik,nem;
long a=0;
unsigned char digits[]={0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f};
//port_a_pullups(0x0C);
rtc_init();
InitTM1637();
//displayValues(0,0,0,0);
output_high(pin_a3);
output_low(pin_a3);
    for(a=1;a<9999;a++)
       displayValues(digits[(a/1000)%10], digits[(a/100)%10], digits[(a/10)%10], digits[a%10]);
       delay_ms(250);
    displayValues(digits[(saat/10)%10], digits[saat%10] | 0x80, digits[(dakika/10)%10], digits[dakika%10]);
    writeRawDigit(digits[saat%10],1);
//TM1637.H
#define CLK pin_a0
#define DIO pin_a1
//#define CLK_HIGH  pin_a1
//#define DIO_HIGH TRISCbits.TRISC1 = 1
#define LOW_BRIGHT 0X00
#define MID_BRIGHT 0X02
#define MAX_BRIGHT 0X07
void InitTM1637(unsigned char BRIGHT);
void Delay_us(unsigned int useconds);
void start(void);
void ask(void);
void stop(void);
void writeByte(unsigned char oneByte);
void writeRawDigit(unsigned char segment, unsigned char nDigit);
void displayValues(unsigned char segment0, unsigned char segment1, unsigned char segment2, unsigned char segment3);
//   Inicializa y ajusta el brillo del display TM1637
void InitTM1637()
   start();
   writeByte(0x88 | 0X07);
   ask();
   stop();
//   Función de retardos ajustada a los requerimientos de la comunicación con el display TM1637
   unsigned int i;
   for(i=0; i < useconds; i++)
   Delay_us(20);
//   Función que inicia la comunicación en el display TM1637
void start(void)
   output_high(clk);
   output_high(dio);
   Delay_us(2);
   output_low(dio);
//   Función que permite saber si el dato o comando enviado al display TM1637 ha sido recibido y
//   procesado correctamente
void ask(void)
   output_high(dio);
   output_low(clk);
   Delay_us(5);
   while(dio==0);
   output_high(dio);
   Delay_us(2);
   output_low(dio);
   output_low(clk);
//   Secuencia de paro, necesaria para el correcto funcionamiento del protocolo de comunicación
//   con el display TM1637
void stop(void)
   output_low(clk);
   Delay_us(2);
   output_low(dio);
   Delay_us(2);
   output_high(clk);
   Delay_us(2);
   output_high(dio);
//   Envia por el pin DIO los bits de un byte, envia serialmente los datos
   unsigned char i;
   for(i=0; i<8; i++)
      output_low(clk);
      if(oneByte & 0x01)
         output_high(dio);
         output_low(dio);
      Delay_us(3);
      oneByte = oneByte >> 1;
      output_high(clk);
      Delay_us(3);
//   Esta función envía al módulo TM1637 un byte con la representación en 7 segmentos en la
//   posción nDigit
   start();
   writeByte(0x44);
   ask();
   stop();
   start();
   writeByte(0xC0 | (nDigit & 0x07));
   ask();
   writeByte(segment);
   ask();
   stop();
//   Envía 4 caracteres al módulo TM1637 desde la posición 0 hasta la 4 de los segmentos
   start();
   writeByte(0x40);
   ask();
   stop();
   start();
   writeByte(0xC0);
   ask();
   writeByte(segment0);
   ask();
   writeByte(segment1);
   ask();
   writeByte(segment2);
   ask();
   writeByte(segment3);
   ask();
   stop();
[url="https://ibb.co/SVhS0tZ"][/url]
[url="https://ibb.co/94z2Yqm"][/url]
[url="https://ibb.co/s3fQS29"][/url]
okumadığın gün karanlıktasın
PostPosted: Sun Aug 09, 2020 4:37 am     Reply with quote
comments
1st line of every PIC program must be the processor type. I don't see that in your program. Something like..
#include <18f46k22.h>
2nd. can you get an LED to blink at 1Hz ? This is th efirst program you should write as it wll confirm you can compile/download code and the PIC hardware does function.
3rd. probably most important is this REAL hardware or a 'simulation' ?
Real hardware, we can help. If a 'proteus 'simulation', sorry I can't help. proteus is a very poor, defective simulator, well known to NOT be reliable or trustworthy.
yakup1890
PostPosted: Sun Aug 09, 2020 7:04 am     Reply with quote
First of all, thank you for your comment.
1-#include <tm1637_pic.h>
available in
2-
I wrote in the program
output_low(pin_a3);
3-
I tried both in proteus and real
temtronic wrote:
comments
PostPosted: Sun Aug 09, 2020 9:20 am     Reply with quote
You don't show us what is in tm1637_pic.h
It needs it's very first line to have:
Then the fuses and the clock definitions. The code cannot work without
these.
yakup1890
PostPosted: Sun Aug 09, 2020 1:34 pm     Reply with quote
#include <12F683.h>
#FUSES PUT                      //Power Up Timer
#use delay(internal=4MHz)
#use FIXED_IO( A_outputs=PIN_A5,PIN_A4,PIN_A2,PIN_A1,PIN_A0)
I did flash to test the code is working.
output_low(pin_a3);
these.
