W5500 Library
Goto page Previous  1, 2, 3
ressas
PostPosted: Tue Jul 28, 2020 11:56 pm     Reply with quote
Last question(maybe)
W5500 has Common Register, 8 Socket Register, TX/RX Buffer Block for each Socket.
(datasheet page 15)
What should I understand from 8 socket register expressions here.
their differences are not specified.
Is it a problem to use a single socket throughout the program?
I think I will use tx while writing, and rx when reading.
When I first read it, I understood that I could plug 8 different sockets into an integrated device.
https://lh3.googleusercontent.com/proxy/EDXUnW5sfh5Lw_susbi0RocW5QvbxgBsmd9xelYUlGy9ZWPeggCCmGXNVYOSvDYisEfmTxSTe1LBVXu4gsIvrdjTCZfXU_VCSkqMdKN4TrUtsyU4YE80aFO741_FSWkN_VuiWk_YirqejZfHrajQNBhTxYhH80sSBk6AByc_J0G-Q4gZFO08VBZ1cRNyB0E
AND
If I have something missing, please correct it.
unsigned int8 w5500_read(unsigned int16 address){
   unsigned int8 data;
   output_low(_pinSCS);
   spi_xfer(w5500,address,16);
   spi_xfer(w5500, BLOCK(0) | READ | VDMN,8);
   data = spi_xfer(w5500,0x0,8);
   output_high(_pinSCS);
   return data;
void w5500_write(unsigned int16 address,unsigned int8 data){
   spi_xfer(w5500, BLOCK(0) | WRITE | VDMN,8);
   spi_xfer(w5500,data,8);
PostPosted: Wed Jul 29, 2020 12:46 am     Reply with quote
These are not physical 'sockets'. These are logical connections.
In networking, a 'socket;, is a logical connection.
<https://www.quora.com/In-simple-terms-what-is-a-socket-in-networking>
Each connection setup to/from the device, is a separate 'socket'.
Once you setup a TCP connection for example, this is a 'socket'.
Now a single socket may be possible, but for a lot of things 'no'. If
for example you have a TCP connection and use UDP, this will be
two sockets.
ressas
PostPosted: Wed Jul 29, 2020 8:07 am     Reply with quote
One more thing.
The socket and Common registers provided in Datasheet have the same addresses. What should I do to separate them
#define MR    0x0000          //mode register
#define GAR1  0x0001          //Gateway IP Address 192.168.0.1
#define GAR2  0x0002
#define GAR3  0x0003
#define GAR4  0x0004
//////////////Socket Registers////////////////
#define Sn_MR    0x0000     //Socket n Mode
#define Sn_CR    0x0001     //Socket n Command
#define Sn_IR    0x0002     //Socket n Interrupt
#define Sn_SR    0x0003     //Socket n Status
#define Sn_PORT1 0x0004     //Socket n Source Port
#define Sn_PORT2 0x0005
Progress:
I proceed as shown on the page below. I am currently writing a value to a register and reading it. (A simple event.)
But I got stuck in the socket register section
https://wizwiki.net/wiki/doku.php/products:w5500:application:tcp_function
PostPosted: Wed Jul 29, 2020 8:16 am     Reply with quote
Yes, they have the same address. They are in different blocks....
Look at section 2.2.2 'Control Phase'.
Block 0 accesses the common registers.
Block 1 Socket 0 registers
Block 5 Socket 1
etc. etc.
The block locations for the Socket N register block is (n*4)+1. The RX block
(n*4)+2, the TX block (n+4)+3
ressas
PostPosted: Wed Aug 05, 2020 1:32 am     Reply with quote
Thank you Ttelmah. I look the control phase.
When I set Block select bits to 0x00, I access common registers. In other cases, I access socket registers. (As I understand).
By following the steps in the link below, I came to the "SOCKET Initialization" section.
I don't know how to write expressions like "OPEN" - "CLOSE" to the sn_CR register. And what path should I follow ?
Please look this link:
Secondly, I'm not sure about "Set socket memory information".
wiznet.h
#define _pinCLK  pin_C3
#define _pinSDI  pin_C4
#define _pinSDO  pin_C5
#define _pinSCS  pin_D0
#define BLOCK(x) (x<<3)
#define WRITE 4
#define READ  0
#define VDMN  0
#define FDL1  1
#define FDL2  2
#define FDL4  3
// Common Register
#use SPI(MASTER, DO=_pinSDO, DI = _pinSDI, CLK=_pinCLK, baud=1000000, bits=16, MODE=2, stream=w5500)
#define GAR2  0x0002
#define GAR3  0x0003
#define GAR4  0x0004
#define SUBR1 0x0005          //Subnet Mask 255.255.255.0
#define SUBR2 0x0006
#define SUBR3 0x0007
#define SUBR4 0x0008
#define SHAR1 0x0009          //Source Hardware Address 00.08.DC.01.02.03
#define SHAR2 0x000A
#define SHAR3 0x000B
#define SHAR4 0x000C
#define SHAR5 0x000D
#define SHAR6 0x000E
#define SIPR1 0x000F       //Source IP Address 192.168.0.2
#define SIPR2 0x0010
#define SIPR3 0x0011
#define SIPR4 0x0012
#define INTLEVEL1 0x0013   //Interrupt Low Level Timer
#define INTLEVEL2 0x0014
#define IR    0x0015      //Interrupt
#define IMR   0x0016      //Interrupt Mask
#define SIR   0x0017      //Socket Intterrupt
#define SIMR  0x0018      //Socket Interrupt Mask
#define RTR1  0x0019      //Retry Time-value
#define RTR2  0x001A
#define RCR   0x001B     //Retry Count
#define PTIMER 0x001C    //PPP Link Control Protocol Request Timer
#define PMAGIC 0x001D    //PPP Link Control Protocol Magic number
#define PHAR1 0x001E     //Destination Hardware Address Register in PPPoE mode)
#define PHAR2 0x001F     //00:08:DC:12:34:56
#define PHAR3 0x0020
#define PHAR4 0x0021
#define PHAR5 0x0022
#define PHAR6 0x0023
#define PSID1 0x0024      //Session ID Register in PPPoE mode)
#define PSID2 0x0025      //
#define PMRU1 0x0026        //Maximum Receive Unit in PPPoE mode
#define PMRU2 0x0027
#define UIPR1 0x0028        //Unreachable IP Address
#define UIPR2 0x0029
#define UIPR3 0x002A
#define UIPR4 0x002B
#define UPORTR1 0x002C    //Unreachable Port
#define UPORTR2 0x002D
#define PHYCFGR  0x002E    //W5500 PHY Configuration
#define VERSIONR 0x0039    //W5500 Chip Version
#define Sn_DHAR1 0x0006 //Socket n Destination Hardware Address
#define Sn_DHAR2 0x0007
#define Sn_DHAR3 0x0008
#define Sn_DHAR4 0x0009
#define Sn_DHAR5 0x000A
#define Sn_DHAR6 0x000B
#define Sn_DIPR1 0x000C      //Socket n Destination IP Address
#define Sn_DIPR2 0x000D
#define Sn_DIPR3 0x000E
#define Sn_DIPR4 0x000F
#define Sn_DPORT1 0x0010     //Socket n Destination Port
#define Sn_DPORT2 0x0011
#define Sn_MSSR1 0x0012      //Socket n Maximum Segment Size
#define Sn_MSSR2 0x0013
#define Sn_TOS   0x0015      //Socket n IP Type of Service
#define Sn_TTL   0x0016      //Socket n TTL
#define Sn_RXBUF_SIZE 0x001E //Socket n RX Buffer Size
#define Sn_TXBUF_SIZE 0x001F //Socket n TX Buffer Size
#define Sn_TX_FSR1 0x0020     //Socket n TX Free Size
#define Sn_TX_FSR2 0x0021
#define Sn_TX_RD1  0x0022
#define Sn_TX_RD2  0x0023
#define Sn_TX_WR1  0x0024    //Socket n TX Write Pointer
#define Sn_TX_WR2  0x0025
#define Sn_RX_RSR1 0x0026    //Socket n Received Size
#define Sn_RX_RSR2 0x0027
#define Sn_RX_RD1  0x0028    //Socket n RX Read Data Pointer
#define Sn_RX_RD2  0x0029
#define Sn_RX_WR1  0x002A
#define Sn_RX_WR2  0X002B
#define Sn_IMR     0x002C      //Socket n Interrupt Mask
#define Sn_FRAG1   0x002D      //Socket n Frafment
#define Sn_FRAG2   0x002E
#define Sn_KPALVTR 0x002F       //Socket n Keep Alive Time
 unsigned int8 w5500_read(unsigned int16 address, unsigned int8 blockData);
 void w5500_write(unsigned int16 address,unsigned int8 data, unsigned int8 blockData);
 void start_setting();
 void basic_setting();
 void network_setting();
 void socket_setting();
wiznet.c
#include "w5500.h"
unsigned int8 w5500_read(unsigned int16 address,unsigned int8 blockData){
   unsigned int8 data;
   delay_cycles(1);
   spi_xfer(w5500, BLOCK(blockData) | READ | VDMN,8);
   return data;
void w5500_write(unsigned int16 address,unsigned int8 data, unsigned int8 blockData){
   delay_cycles(1);
   spi_xfer(w5500, BLOCK(blockData) | WRITE | VDMN,8);
void start_setting(){
     //start setting
     w5500_write(PHYCFGR,0xB8,0x00); //step 1  PHYCFGR config
void basic_setting(){
     //basic setting
     w5500_write(MR  , 0x00 , 0x00); //step 2 MR  config
     w5500_write(IMR , 0x00 , 0x00); //step 3 IMR config
     w5500_write(RTR1, 0x0F , 0x00); //step 4 RCR config
     w5500_write(RTR2, 0xA0 , 0x00);
void network_setting(){
     //Network Information setting
     w5500_write(SHAR1,0x00,0x00); //step 5 SHAR config
     w5500_write(SHAR2,0X08,0x00);
     w5500_write(SHAR3,0xDC,0x00);
     w5500_write(SHAR4,0x01,0x00);
     w5500_write(SHAR5,0x02,0x00);
     w5500_write(SHAR6,0x03,0x00);
     w5500_write(GAR1,0xC0,0x00); // 192 . 168 . 0 . 1
     w5500_write(GAR2,0xA8,0x00); // 168
     w5500_write(GAR3,0x00,0x00); // 0
     w5500_write(GAR4,0x01,0x00); // 1
     w5500_write(SUBR1,0xFF,0x00); // 255 . 255 . 255 . 0
     w5500_write(SUBR2,0xFF,0x00); // 255
     w5500_write(SUBR3,0xFF,0x00); // 255
     w5500_write(SUBR4,0x00,0x00); // 0
     w5500_write(SIPR1,0xC0,0x00); // 192 . 168 . 0 . 2
     w5500_write(SIPR2,0xA8,0x00); // 168
     w5500_write(SIPR3,0x00,0x00); // 0
     w5500_write(SIPR4,0x02,0x00); // 2
void socket_setting(){
//do{  //Sn_CR = CLOSE;
     start:
     w5500_write(Sn_MR ,  0x01,0x00); //
     w5500_write(Sn_PORT1,0xAB,0x00); //
     w5500_write(Sn_PORT2,0x00,0x00); //
     w5500_write(Sn_CR ,  0x01,0x00); //
     if(Sn_SR != "SOCK_INIT"){
     //Sn_CR = "CLOSE";
     goto start;
//}while(Sn_SR != "SOCK_INIT");
wiznet_main.c
#include <18F46k22.h>
#device  ADC=12
#fuses   NOWDT,NOBROWNOUT,PUT,NOWRT,NODEBUG,INTRC_IO, NOMCLR, NOPROTECT, NOWDT, NOLVP,PLLEN
#use     delay(internal=64000000)
#use     rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include "w5500.c"
unsigned int16 S0_RXMEM_SIZE = 0;
unsigned int16 S0_TXMEM_SIZE = 0;
#locate S0_RXMEM_SIZE = 0x80
#locate S0_TXMEM_SIZE = 0x82
   setup_oscillator(OSC_64MHZ , OSC_PLL_ON);
   setup_adc_ports(NO_ANALOGS,VSS_VDD);
   start_setting();   //start setting
   basic_setting();   //basic setting
   network_setting(); //Network Information setting
   //socket_setting();  //SOCKET REGISTER
   unsigned int16 r1,r2,r3,r4;
   while(true)
   r1 = w5500_read(GAR1,0x00); // 192 . 168 . 0 . 1
   delay_us(20);
   r2 = w5500_read(GAR2,0x00); // 168
   delay_us(20);
   r3 = w5500_read(GAR3,0x00); // 0
   delay_us(20);
   r4 = w5500_read(GAR4,0x00); // 1
   delay_us(20);
   printf("V: %ld %ld %ld %ld\n",r1,r2,r3,r4);
   printf("%ld\n",Sn_SR);
   delay_ms (2000);
ressas
PostPosted: Wed Aug 05, 2020 8:35 pm     Reply with quote
any answers Question
PostPosted: Thu Aug 06, 2020 1:31 am     Reply with quote
Seriously, this is called programming.
You are going to have to get the existing library from the Wiznet site, and
modify this for the PIC:
<https://github.com/Wiznet/ioLibrary_Driver/tree/master/Ethernet>
The code is 99% directly portable, just the hardware comms part needs
to change.
The .chm file provides a complete manual to the functions provided.
You need the stuff that is in the root directory there, and then the W5500
drivers in the sub-directory.
These give complete API functions to actually open a socket, handle data
I/O using this etc. etc..
Then in the directory above:
<https://github.com/Wiznet/ioLibrary_Driver/tree/master/Application>
There are examples showing these drivers being used for a loopback
and multicast.
ressas
PostPosted: Sat Aug 22, 2020 2:51 am     Reply with quote
Well alright.
I downloaded the Wiznet libraries from the place you said.
It would take me time to adapt to CCS c. But after a few minor fixes for Mplab IDE it was fixed. (Compiled without an error)
Later I found a code adapted for ARM.
https://www.carminenoviello.com/2015/08/28/adding-ethernet-connectivity-stm32-nucleo/
I watched a video showing the code working fine:
https://www.youtube.com/watch?v=zsLQm6SgL_c
  void cs_sel() {
   CS_SetLow(); //CS LOW
void cs_desel() {
   CS_SetHigh(); //CS HIGH
uint8_t spi_readb(void) {
   uint8_t rbuf;
   rbuf = SPI1_ExchangeByte(0x00);
   return rbuf;
void spi_writeb(uint8_t b) {
   SPI1_ExchangeByte(b);
    // Initialize the device
    SYSTEM_Initialize();
    SPI1_Open(0);
    uint8_t retVal, sockStatus;
    int16_t rcvLen;
    uint8_t rcvBuf[20];
    uint8_t bufSize[] = {2, 2, 2, 2};
  wizchip_init(bufSize, bufSize);
                              //80-A5-89-62-0A-19
  wiz_NetInfo netInfo = { .mac    = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef},   // Mac address
                          .ip    = {192, 168, 1, 50},               // IP address
                          .sn    = {255, 255, 255, 0},               // Subnet mask
                          .gw    = {192, 168, 2, 1}};               // Gateway address
  wizchip_setnetinfo(&netInfo);
  wizchip_getnetinfo(&netInfo);
 // 0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef
  //PRINT_NETINFO(netInfo);
  reg_wizchip_cs_cbfunc (cs_sel, cs_desel);
  reg_wizchip_spi_cbfunc(spi_readb, spi_writeb);
void cs_sel() {
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_RESET); //CS LOW
void cs_desel() {
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_SET); //CS HIGH
uint8_t spi_rb(void) {
uint8_t rbuf;
HAL_SPI_Receive(&hspi2, &rbuf, 1, 0xFFFFFFFF);
return rbuf;
void spi_wb(uint8_t b) {
HAL_SPI_Transmit(&hspi2, &b, 1, 0xFFFFFFFF);
The part I show as "QUOTE" is the part given in the link. I guess I couldn't adapt that expression properly in my code.
SPR_writeByte // SPI_ExchangeByte // SPI_ExchangeBlock
I'm not sure which one of the expressions I should use.
Why am I asking for an edit of MPLAB IDE in CCS C block?
Because I rely on your deep knowledge. Laughing
And I don't like MPLAB's Blog page.
If you can help me with this part, I will share all the codes here in case the code works. And I was already sharing my other apps.
I'm waiting for your answer
and I'm tired
Page 3 of 3
