EX_RS485.c CCS C [Solved]
Goto page Previous  1, 2
PostPosted: Wed Jun 17, 2020 1:26 pm     Reply with quote
nice...
another 'trick' I've learned over the years...
when editing a program ..
1st. copy it,naming new one 'programnameVxxx.C'
where x is the version number
2nd edit the new copy
3rd compile/run/see what happens.....
4th, keep doing 1-2-3 until it really works !
By doing this you'll ALWAYS have a few previous versions to go back to a KNOWN program.
It's way to easy to make 3,4 or more 'minor' changes to a program and then NOTHING works properly and you can't SEE where the problem is.
Yes, this system takes up a lot of harddrive space but HDs are cheap and HUGE,so really space is not an issue.
When the project is done, you can always go and delete all but say the last 3 versions.
I also have a 'fuses file' that has EVERY fuse, 1 per line, with comment. I use #include '46k22fuses.c' to insert it into the program. Doing this keeps the program 'cleaner' and easier to read. If a program needs different fuse settings from the basic, simply copy the base version, name after the project, and include that version. Generally though , if you stick to one PIC, the fuses don't really change....
diode_blade
Solved
PostPosted: Thu Jun 18, 2020 3:26 am     Reply with quote
I do the version thing temtronic but the fuses file great tip thanks for that.
Thanks Folks.
PostPosted: Thu Jun 18, 2020 3:57 am     Reply with quote
That 'style' helps a lot, especially when running multiple versions.
I tend to do a 'config' file, that contains the fuses, clock settings, PPS, &
the UART/I2C/SPI setups. I usually include in this a 'description', which
says which pins do what. So a typical one would be:
//Peripherals I2C C5/C4 SCL/SDA
//Feeds 24FC512, DS1338-C, * MCP23008
//relays on top two bits of this, then six solenoid drivers.
//PWM on B4/C0 for 4-20mA
//Opto coupled logic inputs B10, B12, B14 ,A10
//Analog in B0, A1, VREF B1
//CO2 C7 TX, C8 RX
//Vinculum C1 TXD, C2 RXD
//Display RX B5, TX B6
//Square wave interrupt from clock = input on RA8
//Servo controller now separate board
//Using A7(TX) & B11 for it's serial interface.
//B15 control switch (pullup).
//A0, A4, A9, B8, B9, C3, C6 unused.
That way I can check at any point 'what pin does what', and all the stuff
that configures the chip is in one place.
I then usually have a file containing the #DEFINES, and data type
configurations (structures etc.).
'Standardising' on how you store this stuff, makes it vastly easier to
go back to a project in months or years time. As an example, I just did
an update on some code I first wrote about 14 years ago, currently on
version 39!. Yet I was able to write the changes needed in only a few
minutes, and send them back for test. Most versions of this are just
small modifications for specific customers, but if you didn't have an
'archive' of versions, and a standard format. catch back up with this
would be much harder....[/code]
diode_blade
PostPosted: Thu Jul 23, 2020 9:42 am     Reply with quote
SOLVED: 23-7-20
Thank you guys for the help, after a few other teething troubles including some HW, laptop and SW problems, I have now got things working the way I want and can expand on from there.
Again thank you very much for the help.
Dave
Cenatronics
PostPosted: Tue Jul 28, 2020 9:24 am     Reply with quote
//CO2 C7 TX, C8 RX
Wouldn't it be a good education for beginners if you could make these tips and file structures into a template and publish them?
Very Happy Very Happy
Namik
dluu13
PostPosted: Tue Jul 28, 2020 11:17 am     Reply with quote
Good candidate for the "best of" forum?
Cenatronics
PostPosted: Tue Jul 28, 2020 3:17 pm     Reply with quote
Absolutely!
PostPosted: Wed Jul 29, 2020 1:04 am     Reply with quote
Hmm. Perhaps privately, some of the posters would like to send me some
suggested 'layouts', then I can have a little 'assemble, and build something.
Very Happy
diode_blade
PostPosted: Wed Jul 29, 2020 2:20 am     Reply with quote
//CO2 C7 TX, C8 RX
Namik
Excellent Idea. Again thanks for the help.
Dave
Cenatronics
PostPosted: Wed Jul 29, 2020 5:56 pm     Reply with quote
I am using Altium for my designs. While planning the folder structure for the customer projects I developed, I found the folder structure designed and published by Robert FERANEC for his own use. It has a very useful and organized structure. This is the address https://welldoneblog.fedevel.com/2013/10/14/hardware-design-directory-template/
This video also explains in detail: https://www.youtube.com/watch?v=q-4F9zoZ7fs
Not for Embedded Software, but hopefully it will help your business.
Namik
Page 2 of 2
