Simple ADC program doesn't work as expected (SOLVED)
E_Blue
PostPosted: Wed Jul 01, 2020 4:51 pm     Reply with quote
I'm trying to run this simple voltage comparator. I'm applying 5V to AN5/RA5 but always seems to measure 0V because I always get Pout high and Tout low.
My code:
#include <16f18326.h>
#DEVICE ADC=10
#FUSES RSTOSC_HFINTRC,NOEXTOSC,NOCLKOUT,NOWDT
#use delay (clock=8M)
//#use fast_io(ALL)
#define Pout PIN_C4
#define Tout PIN_C3
    unsigned int16 CurrentVolt;
    set_tris_a(0b100000);
    set_tris_c(0x00);
    setup_adc(ADC_CLOCK_DIV_8);
    setup_adc_ports(sAN5,VSS_VDD);
    set_adc_channel(sAN5);
    output_high(Pout);
    output_high(Tout);
    delay_ms(1500);
        output_toggle(PIN_C2);
        CurrentVolt=read_adc();
        if(CurrentVolt>400)
            output_high(Pout);
            output_high(Tout);
            if(CurrentVolt<65)
                output_low(Tout);
                output_high(Pout);
                output_low(Pout);
                output_high(Tout);
I tried to manually put a value in CurrentVolt variable like 0x0098 but always fall inside the last "else".
What I'm doing wrong?
Electric Blue
PostPosted: Wed Jul 01, 2020 5:00 pm     Reply with quote
quick comments...
Is this correct .... Since I don't use that PIC,
#FUSES RSTOSC_HFINTRC ??
Maybe try the 1Hz LED program to confirm the PIC runs properly ??
Jay
E_Blue
PostPosted: Wed Jul 01, 2020 5:07 pm     Reply with quote
The PIC is running; I'm getting about 17KHz on pin C2.
I get RSTOSC_HFINTRC from 16f18326.h file.
Electric Blue
dluu13
PostPosted: Wed Jul 01, 2020 5:37 pm     Reply with quote
Instead of
I think it should be
set_adc_channel(5);
E_Blue
PostPosted: Wed Jul 01, 2020 5:48 pm     Reply with quote
dluu13 wrote:
Instead of
set_adc_channel(5);
YES! Now it's alive!
I know that must be something really silly.
Awww! What a relief!
Now I can breath!
Electric Blue
dluu13
PostPosted: Wed Jul 01, 2020 5:53 pm     Reply with quote
E_Blue wrote:
dluu13 wrote:
Instead of
set_adc_channel(5);
Now I can breath!
You're welcome. I also found this system confusing. You have PIN_xx as the I/O pin, sANx for setting up ADC channel, and then x for selecting which ADC channel to measure... Three different numbers to know in order to set up each ADC pin...
PostPosted: Thu Jul 02, 2020 12:50 am     Reply with quote
Yes, it is difficult though to see how they could do it any other way, since
the values are very different. Even worse on some chips, where the ANx
numbers don't stay in the same sequence as the pins (a couple of the PIC's
that have other things mapped onto the high PortA pins).
One to keep in your 'memory bank'... Smile
PostPosted: Thu Jul 02, 2020 4:42 am     Reply with quote
It's just another reason to pick a great PIC and stay with it. It allows you to concentrate on code and not the zillion 'background' details.
How CCS can code a compiler to work for 100s if not 1000s of different PICs has always amazed me.
dluu13
PostPosted: Thu Jul 02, 2020 5:14 am     Reply with quote
Oh yes, and on one of the PICs that I use, certain of the sAN ports need to be put into a second parameter in setup_adc_ports as opposed to just ORing them together.
